How do I delete music files in sansa fuse? - Audio Players & Recorders
  • 7,482 Answers
Deleting Files,Pictures,etc from MP3 Player
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Good Luck,
I hope this helps
Posted on Nov 14, 2009
Testimonial: "Thanks that did it! I will become gadget literate. With help. thanks"
5 Suggested Answers
Syd_
  • 47 Answers
SOURCE: Empty folder
There may be possible reasons why your Sansa E250 would display an message on the LCD even when you've downloaded files to it: (1) The music file type is not supported by the player. Sansa players support only MP3 and WMA files. To determine what file type your have, right click on the file type and it should display the "properties" dialog box. Check if it is MP3 or WMA. For example, iTunes music files will not work with the player, nor will WAV or MIDI files. (2) Your music files are supported but the bit rate is not within the range that the player supports. Sansa players support MP3 files up to 128 KBPS and WMA files up to 64 KBPS. You may need to use a 3rd party music file editor to convert the files to a supported bit rate (3) You may have saved your music files in a folder and copied the folder to the player. Your Sansa E250 will not recognize folders. Either save them in the root directory or inside the "Music" folder -- your player's default folder for music files. Hope this info helps :)
Posted on Apr 24, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: SANSA c140 not sychronizing
Reformat
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
SOURCE: All the music files seems to be deleted, Sansa e250 isn't resetting,..
any new reset
Posted on Aug 15, 2008
  • 4 Answers
SOURCE: SANSA M230
go to http://www.sandisk.com/Retail/Default.aspx?CatID=1376 and download the firmware updater, reboot and all worked fine for me.
Posted on Aug 23, 2008
How do I remove a song or songs from my Sansa SanDisk mp3 player model m240?
There are 2 ways to delete music files. You can delete them from the player directly or
using the computer.
To delete music files directly from the Sansa player, follow these steps:
1. In playback mode, press Submenu button.
2. Select the Delete Song item.
To delete music files using the computer, follow these steps:
1. Connect your Sansa to the computer.
2. Select Open device to view files using Windows Explorer on initial connection.
3. Locate the folder where your music files are stored.
4. Highlight and delete the music files or folder.
I hope this helps.
Thanks.
gylacz
Sep 01, 2011 | SanDisk Audio Players & Recorders
How to delete music from the device
open sansa e200 file when attached to your pc. open file you want to delete, eg music. click on folder you want to delete, right click and go to delete, should delete file.
Jun 11, 2010 | SanDisk Sansa e250 MP3 Player
How do I delete multiple songs from my sansa fuse mp3 player?
HI,
To delete multiple songs you need to connect your Sansa Fuze to your computer and delete the files from the Music folder.Just press hold CTRL and select the song files with your mouse which you want to delete and then press the DEL button.
If you need any more help let me know.
Thank you
Aug 13, 2009 | SanDisk Sansa e260 MP3 Player
I want to erase every thing off my sansa
Ok, plug it in your computer, open "My Computer," open up your Sansa, open up the file named "Music," select all the files, right click them and click delete. Now go to the Recycling Bin and delete all the music files that were on your Sansa. Sometimes the Sansa doesn't realize that files are gone until you delete them from the Recycling Bin, crazy I know, but it's true.
Hope it helps!
Jun 07, 2009 | SanDisk Sansa e250 MP3 Player
Deleting songs.
Your DB might be corrupt. Folow the delete procedure one more time:
Delete Music Files
1) Connect your Sansa to the computer.
2) Select Open device to view files using Windows Explorer on initial
connection.
3) Select the place where you want to delete music files from
4) Highlight and delete the music file/s or folder from My Computer\Sansa
e200\...\MUSIC
folder. (You can also select from a variety of music
software programs to transfer/synchronize your files).
If that fails, go ahead and update the firmware - it will delete everything, and allow you to start over from scratch among other things.
-Tha Mp3 Doctor
Feb 16, 2009 | SanDisk Sansa E280 MP3 Player
My sansa 1gb won't let me delete songs
To delete files directly from the Sansa player, follow these steps:
1. In playback mode, press the Submenu button.
2. Select Delete.
connection.
3. Locate the folder where your files are stored.
NOTE: Music files are stored in the MUSIC folder. Voice recording files
are stored in RECORDING folders. Photos and Videos are stored at PHOTO
and VIDEOS folders, respectively.
4. Highlight and delete the desired files.
Dec 07, 2008 | SanDisk Sansa m240 MP3 Player
How do i delete music off my sansa mp3 player?
Source: http://www.ehow.com/how_2023687_delete-files-sansa.html
Step 1Connect the USB cable to your Sansa MP3 player, then hook the other end to a free USB port on your computer. Step 2Give the computer time to recognize the Sansa MP3 player. Once it has, double-click on the MP3 player’s icon to view the music files stored to memory. Step 3Scroll through the list of audio files until you find the ones that you wish to delete from the Sansa MP3 player. Step 4Click on single items or click and lasso multiple files. Step 5Right-click on the highlighted files to pull down an action list and from there select Delete. The computer will ask if you really want to throw the file away. Select OK. Step 6Exit from the window, then disconnect the USB cable from the Sansa MP3 player. The player will automatically turn off. The memory will update the first time you turn the player on after deleting songs. Tips & Warnings
  • Optionally, you can left-click on a file and drag the file icon to the Recycle Bin. Either way, you can delete music that you don’t want from your Sansa MP3 player.
  • Unlike other documents and files, once the music file hits the Recycle Bin, it’s gone. Make sure that you are deleting the correct file.
For more help: http://www.supportrix.com/
Jul 30, 2008 | Audio Players & Recorders
I WANT TO DELETE ALL SONGS OFF MY MP 3 PLAYER SO I CAN ADD ALL NEW ONES
To delete files using your computer,
1. connect your sansa to the computer,
2.select open device to view files using windows explorer on inital contact,
3.select the place you want music deleted from,
4.highlight and delete the music files or folder (if your lucky),from
My Computer/Sansa e270/Internal Memory/ Music folder!
you can also manually delete files from the device if this does'nt work..........
May 11, 2008 | SanDisk Sansa e200 MP3 Player
Sandisk Sansa e250r - cannot delete mp3 files
I have had this problem for some time now and finally got through to tech support for Sansa and now have the solution:Worked for both 230 and 240.
Take out the battery in the Sansa player; Put on lock on back side of Sansa player; Connect Sansa to the computer, Once computer recognizes device cancel out of that media program; Go to my computer on desk top; Right click on recognized Sansa device; Click format; Click ok to delete files.
Jan 13, 2008 | SanDisk Sansa e200 MP3 Player
Don't know how to delete files
1. Open the file browser on your computer and navigate through the folders to the drive assigned to your Sansa MP3 Player. 2. Select the music files that you would like to delete by clicking once on the file, if you want to delete more than one file hold your control(ctrl) key down as you click each file. When you have clicked on all the files you want deleted release holding down the control key. Then push the delete key. The files will be deleted. You also can use Rhapsody and other software to save or delete files directly to your player.
Jul 14, 2007 | SanDisk Sansa e140 MP3 Player
229 people viewed this question
 Grubhead
Grubhead
