Question about Sony KDF-E42A10 42 in. LCD Television
The screen lights up but no picture. I have cycled through the tv/video and channel manual controls and there has been no change in the blank screen. Any suggestions?
You most likely need to replace the Bulb. It is an easy fix that you can do yourself and will cost you $150 to $200 for the part.
Posted on Nov 17, 2009
My t.v. picture goes dark when watching programmes
is it by any changes an LG ? if so its the main av board at fault LG's and some other tv makes have a brightness control that is controlled only by the tv, its to stop light flicker when changing channels and accessing menus. its because the channel change changes screen out put from say 1080i/p to 470 in a split second.
Jun 21, 2017 | Televison & Video
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Have a westinghouse lcd tv 50inch model ew50t5kw and would like to know before changing any parts or boards what causes a blue screen no sound or picture
  1. Frank: Verizon. com says try this: Change your VCR's Channel to 3 or 4. Most blue screen issues are caused by the VCR not being set to Channel 3 or 4. If changing the VCR's channel (using the channel buttons on the VCR or from the VCR remote control) did not change your TV screen, go to step 2.
  2. Make sure your TV is not in Video mode. There are three possible ways to change your TV's mode using your TV remote control: 1) Press a Mode button, toggle through the options and select TV, 2) Press a Video button to change your TV's mode from Video to TV or 3) Press Menu, locate Mode or Audio/Video setup and select TV from one of the options. If you are not sure how to change your TV's mode, see your TV's user guide for more information.
  3. Check to make sure your set-top box is plugged in and turned on.
  4. Check to see if other TVs (connected to different outlets) have a blue screen. If they do, contact the Verizon Fiber Solutions Center.
May 21, 2015 | Westinghouse Televison & Video
How to change the channel my Sony Trinitron TV turns on to?
hit menu button on your remote, navigate to channel setup menu. on the sub-menu, set channel fix to your channel that you require. now when your tv powers up this will be the default channel. if this doesn't fix your issue then try cycling through video inputs tv/video button on your remote.
Nov 10, 2013 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Samsung tv power cycles when I get to higher channels pass 40. I attempt to change channel. Doesn't change and then front led blinks, tv screens goes blank, led flashes again and then screen is normal. I'm...
We have a similar problem when changing channels/surfing, the TV will begin to power cycle, until you unplug THE CABLE TV input, then it will turn on again and stay on as you rehook the cable and change channels....till it decides to do it again, DTV channels seem to trip it up, but not sure....if I leave it on the same channel it will run for days. Yep and the cable TV is grounded outside
Dec 19, 2009 | Samsung LN40A630 40 in. LCD TV
Blank Blue Screen
If you go to menu do you get that on the screen?
Nov 21, 2017 | Samsung CXN2085TP 20 in. TV/VCR/DVD Combo
We have sound but no picture i have sound but no picture. when you change inputs the word input is doubled up and distorted
There were not much info in the manual but it did suggest trying this.
1st- Unplug for a few minutes and then plug it back in. Or use the reset button look it up in the manual. MANUAL
2nd- Blank screen troubleshooting
• If you're trying to watch TV, change channels or press the ANTENNA button to switch tuners.
• If you're trying to watch something that's playing on a component connected to the TV (like a DVD or a VCR tape), press the TV
button on the remote, then press INPUT until you get to the correct video input channel.
• If you're trying to watch a component (like your DVD player or VCR), make sure the component connected to the TV is turned on.
• If you're trying to watch a component (like your DVD player or VCR), make sure the component is connected correctly.
Post back if non of these ideas work and explain if there are any lights flashing or changing colors on the front where the green light usually is. A fixya rating would be appreciated, thank you for stopping by Fixya!
Feb 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
TV input
it is likely that your tv is interpreting a random button on your remote as a signal sent for it to change inputs, next time this happens turn the tv off and back on and note what comes up on the screen, for example video 1,
Aug 04, 2008 | DISH Network IR Remote Control
TV blank, sound okay, picture comes for half a second while switching channels
i am a technician and i too have this issue. if any of you can get a schematic and service notes, send them to trae3@live .com and i WILL find the problem and report to each of you. i cant get any help from sears all i need is to speak with a technician who actually works on these things, get the paperwork and then i am sure it is a matter of a module swap. any info will help us!
Jun 23, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
Sony KDF-E42A10 42 in. LCD Television Logo
46 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
