Question about Samsung Televison & Video
My Samsung TV Model TXS3082WHX/XAA VR.SA01 is about 3-4yrs old, and has just started having trouble powering on (both manually and with the remote). Sometimes the problem is solved by unplugging the television for several hours, plugging it back in (which makes a sound like the tv has been turned 'on') and powering it back on (remote or manually both work). However, if I turn it back off-- trying to turn it right back on doesn't work (the red light just blinks rapidly and nothing happens). Re-plugging in the television is the only real way to initiate turning it on at this point... and that only works sometimes. Help?
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
SOURCE: won't turn on
Problem is caused by Diode Ref.#D620.
Sony Part#871907443.Cost $5.00
Posted on Oct 15, 2007
SOURCE: black screen no sound
Look at this
Phillips/Maganavox TS3258 Dead, HOT shorted R&R Flyback, HOT
Transistor,#3610- 22k, #6328 SMD diode, #7325 SMD Transistor and Check
#3611/3608 190 ohm resistor by #3610
TELEVISION MAGNAVOX TS3258 Flyback Bad Replace fly -
R3610,22K-R3331,47K(SMD)-D6328(SMD)-Q7325(SMD)-IC7150
TELEVISION MAGNAVOX TS3258C101 DEAD Shorted flyback, will also damage
IC7150, R3610, R3331, D6328, and Q7325.
Posted on Nov 13, 2007
ctf1800
  • 4402 Answers
SOURCE: tv. does not turn on sometimes? philips 63pf9631d/37
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
Well I think that if you would have a service manual for this set that would help a lot, I can send it to anyone who wants it via email/gmail. Let me know if anyone want one.
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Posted on Dec 06, 2007
  • 191 Answers
SOURCE: TV won't turn on, please help......
change your power suply
Posted on Nov 02, 2008
Trying to program an old one for all remote to a
One-For-All (One4All) remote codes - chose your remote first! - Go to http://www.oneforall.co.uk/support/result/?cat=8
If the remote is an old model, then it won't be programmed with a specific code for your exact model of TV. Try any of the Samsung codes, or do an Auto code search.
Sep 06, 2014 | Televison & Video
Samsung TXS3082WHX/XAA
The relay cuts inside the TV after swich on. Should be some short circuited component/board inside it. Check and replace it. The click sound you hear is of the clicking of the relay. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Nov 29, 2012 | Samsung Televison & Video
I have a old 2001 samsung tv model no. TSK2066 - GX/XAA. I am using a universal by TV Guide . I need the 3 digit code for this tv
Hello
Three digit universal remote codes for Samsung TV are:
004/ 005/ 009/ 015/ 104/ 105/ 106/ 109/ 133/ 172 OK.
Jul 25, 2011 | Televison & Video
I have a HDTV Samsung TV, Model #TXS3082WHX/XAA and I would to connect my desktop to the TV. Do you know what cables are needed?
Look for a monitor cable with 15 pin RGB plugs on each end, that will transmit the video portion of the signal so you will need an audio cable with 3.5mm plug on each end also, there are RGB cables that have the audio cable together as one big cable.
Good Luck !
Feb 09, 2010 | Samsung SlimFit TX-S3082WH 30" TV
Purple dots on HD LCD samsung model LNT4661FX/XAA when on.
http://www.youtube.com/watch?v=Mm51C_RDIZE
-and-
http://www.youtube.com/watch?v=BNHHrgX_6cs
Jan 27, 2010 | Samsung Televison & Video
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
My tv txs3082 blink constantli
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
Jul 22, 2009 | Samsung TX-R3080WH 30" TV
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
Televison & Video Logo
504 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
