Question about Sony Acid Music Studio 7 Full Version for PC (SAMS7000)
Every time i try to lay a track over another it has a lag how do you fix it? like i record the drumbs and then try the guitar and try to play with it i am on time and then play it back it has a lag
Under preferences in the option button on the top, go to audio devices and look at the recording part, it should say auto adjust lag but u want to maunally do it. The easiest way to adjust lag is to use a mic and talk into it like 1...2....3...4 and get the latency as close as you can.
Hope that helps
Posted on Dec 25, 2009
Alesis io2 guitar inpu and mute playback for backing track in audacity
Audacity is a copyrighted audio source and does not permit you to record tracks or playback of any kind. you will need to D/L the audio file you are trying to record in tangent and then play them together through an audio remixing app, like Ableton live or FL Studio
Jan 28, 2014 | Alesis iO 26 Sound Card
When i lay two tracks down they dont match up how do i fix this problem
your question implies you are recording.
if you are recording from a line in or mic, when you select to record a track a window pops up with a couple of options (radio buttons) in the lower left.
the options offer from project start or current position.
i always select from the start since i only ever record a complete track. however, the selection in the bottom left offer you an opportunity to start recording a track at another point on the time line. (i.e. maybe where the lead guitar comes in)
Jan 17, 2010 | Sony Acid Music Studio 7 Full Version for...
I was just wondering if its best to record seperate tracks at different times of if its ok to mic my guitar and mic the vocals using two inputs but recording at the same time?
Whichever works best for you is best. You can always lay down a scratch track for each like this and then lay down another track to replace whatever you didn't like using the scratch track as a guide. Erase the scratch tracks that you don't need before you mix down. I hope this helps.
Nov 26, 2009 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Recording guitar tracks on my computer are out of sync help
Most recording programs have a some way to keep tracks in sync. It is usually some type of begining and end marker. When you press record for the second track it starts the begining marker. What is the program your using?
Mar 14, 2009 | Dell Dimension 2400 PC Desktop
Slow Playback
Sounds to me that the computer is way out of date. Chances are the computer doesn't have enough processing power to support what you're trying to throw at it.
It might help stop/uninstall all other programs running at the same time to give Cakewalk the best chance of working.
Nov 15, 2017 | Cakewalk Guitar Tracks Pro 2 Classic
Tascam DP-02cf
You've got two inputs on the DP-02 so you can record two sources at once.
Depending on how you want the electric guitar recorded (mic the amp, or direct line in) you can in the first case plug your guitar mic into one of the mic inputs on DP02 and plug your vocal mic into the other mic input. You also have the option of plugging the guitar directly into the DP02 (using the hi-z input - I believe it is labelled 'guitar' or something on the DP02. I any event I believe it's the one on the left). This way you only need one mic for use recording the vocal part.
To avoid any 'bleed' between channels you can use the headphones while recording this way and you'll avoid having the unamplified guitar sound coming through over the vocal mic.
Once you have the mics or guitar and mic plugged into two inputs, you need to assign the inputs to a channel (track) to record on. You do this by pressing the select button for the input and then pressing the select button for the track where you want to record the input. Do this for both inputs so that they are recording on different tracks. Then arm the tracks for recording by pressing the record button for each track and the lighted buttons will flash above each armed track. Then just press play and record and you'll be recording. You can go back and redo it as many times as you like and record over what is there, or preserve a take and assign a new track (or tracks) for another take. You've got 8 to play with.
Hope this helps.
bd.
Sep 01, 2008 | Tascam 2488 Portastudio Multitrack...
Drum track
From your description it sounds like you recorded the midi drum patterns to a track first and then playback from that track is giving you problems. If this is the case it sounds a lot like a bug that existed in the firmware prior to release 1.02 where edits could cause gaps on tracks. You can check your firmware version on bootup and if you don't have version 1.02 installed you can get the firware and instrustion on how to upgrade it here:
http://www.tascam.com/details;8,16,5,19.html
Feb 13, 2008 | Tascam 2488 Portastudio Multitrack...
Lagging in Guitar Hero and now others
What kind of TV do you have? I've noticed that when I played GH 3 on my plasma TV it lagged until I calibrated it. You might need to change the TV scale to 480p since wii isn't high def. Hope this helps.
Jan 15, 2008 | Nintendo Wii Console
Lexicon lambda
push the monitor button to go mono instead of stereo.
Oct 11, 2007 | Lexicon Lambda Usb Desktop Recording...
Sony Acid Music Studio 7 Full Version for PC (SAMS7000) Logo
237 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
