Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
SAMSUNG 46IN. When we unplug or the lights go out the tv will take days to come back on again. What do we need to go, can we fix it?
    President:
  • 4,402 Answers
These have been know to have bad convergence ic but that would only be a guess as to whats wrong i would have someone give you and est.
Posted on Jan 22, 2008
Vertical lines
I would contact customer support and find a manager.
Make him aware that they are dropping the ball.
They are giving you back usede problem equipment.
May 23, 2014 | Samsung UN46C7000WFXZA - 46in Led Hdtv...
Purple and blue screen on dlp tv
Sounds like a problem with the Vertical Video Card.
Have fun finding one. If your TV is still under warranty... send your TV off for repair.
Oct 03, 2012 | Samsung HL-R5656W 56" DLP HDTV
I have a 46in. Samsung LCD TV. It worked lastnight now I tryed to turn it back on and all it does is the power light flashes and it make's a clicking sound can you help thank's very much.
The clicking noise indicates that its a power supply related issue. When the relay switches turn themselves off you will hear that sound. The first thing you should try is to unplug the set and hold for 5 minutes before plugging it back in and turning it on? Why? Because a power surge may have triggered these relays and unplugging them will reset them so that you can see if the set turns on. Otherwise we will proceed accordingly and troubleshoot the components provided you can follow a schematic.
Sai.
Mar 23, 2010 | Samsung 46IN LCD 1200:1 460DX BLACK 8MS...
Red light flashes but TV wont turn on
If you dont have the led light on when plugged go ahead and replaced the powerboard, but if your led light is on when plugged then you will need to replace the mainboard.
Hope this info help you.
Jul 01, 2009 | Samsung LN32A330 32 in. LCD TV
Samsung slimfit keeps turning off
When the TV is on, how about the back light(you can check that on your TV's back side)
If the back light on -- need to replace Main Board.
no back light -- need to replace Power Board
Feb 19, 2009 | Samsung SlimFit TX-S2783 TV
Samsung LNT4665FX 46in flat screen LCD power supply cycles on/off, with audible que. Blue light at bottom of screen remains lit, but screen remains black. Does not respond to manual on/off or remote...
Check out the fixYa solution for the Samsung LNS4051D- it sounds like the same problem. Defective capacitors. You may need different part though.  We just fixed my mom's LNS4051D with that problem. I have the LNT4665 and although it hasn't failed yet, I am tempted to get some capacitors just in case.
Nov 07, 2008 | Televison & Video
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
Samsung 46in.
This is a Plasma TV set, there is no convergence adjustments on this set. the convergence adjustments are for tube type projection TV sets. You could have a few problems with your TV. You could have a bad color whell assembly, a bad light engine assy. or a problem with the main board. This is not a set a that some who is not trained on plasma TV sets should attempt to troubleshoot and or repair. depending on how old this set is, it may still be under warranty. if it is not, call out only a Samsung authorized servicer, as they will have the boards and proper tools to service this TV. Good Luck
Mar 21, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
TV won't turn on
sounds like the main board has an issue
Jan 18, 2007 | Samsung LTM1775W 17 in. LCD Television
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
15 people viewed this question
Jerry Greenberg
Jerry Greenberg
