Question about Garden
Have a North Star belt driven pressure washer 3500 psi 4 gpm that stalls out when you release the wand trigger. Runs great as long as you hold down the trigger.
  • 2,841 Answers
When you release the trigger the unloader valve senses the buildup of pressure or the interruption of the flow and is supposed to go into bypass mode and the flow will loop through the unloader valve. The water will heat up very quickly and will then exit through the thermal relief valve if you run it this way very long. You should never leave a pressure washer running for more than a few minutes or damage can occur. It appears your unloaded is not functioning as it should and it is not unloading. This will cause the engine to stall on some units. Check the bypass hose to make sure it is not clogged or collapsing, More than likely you need to purchase a new unloader as they are usually not repairable. You may be able to purchase a repair kit and rebuild the unit which I have done myself but in my experience you are better off just buying a new unloader. I have rebuilt a couple but the rebuild does not seem to work well for very long. Just get a new unloader for your pump.
Posted on Nov 14, 2009
Motor will not idle down
Your carburetor is the problem. Either have it serviced or get a new carburetor. You can service it yourself, you will need carburetor cleaner, very thin gauged wire, air compressor if you have one to blow out the ports etc..
Also you can check out you tube for videos on how to clean a 4 cycle carburetor
Nov 05, 2015 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
Power boss pressure washer stops when trigger is released
The unloader on yoru pump is bad.. Pressure washer parts catalog quick links Pressure Washers High Pressure... go here with your model number on your pump and they can guide you to your new unloader. Good luck
Apr 17, 2014 | Powerboss 20309 3,000 PSI 2.5 GPM Gas...
Let go of wand trigger pressure will not come back
spill valve is stuck and needs to be cleaned and greased common problem....also check all connections for blockage in line
Jul 21, 2010 | Karcher 2500 PSI Pressure Washer
New Troy-Bilt 3000 psi - Very Hard to Hot Start
When you run the unit and shut if off, release the pressure from the spray wand before trying to restart the engine. This built up pressure will cause it to be very hard to start as you have found out. If it does not start on the second pull release the pressure again. Another option is do do what I did on mine. I simply put a pull tie on the handle so I can pull the trigger back and use the pull tie to hold the trigger open. Make sure if you do this, that you remove the high pressure orifice from the end of the wand before attempting to start the engine. Otherwise the pressure will come on abruptly and could injure you or do property damage.
Apr 25, 2010 | Briggs & Stratton Prosumer 20324 Gas...
PWER WASHER RUNS PERFECT, WHEN WATER COMES ON, IT STALLS. BUT IF YOU PULL TRIGGER BACK ON WAND, THEN SPRAYER WORKS. THE MINUTE YOU LET GO OF TRIGGER, IT STALLS OUT.
hi you have got a fault with the unloader it's not unloading so its going a bove the 13amps and knocking the thermol overload out or blowing a fuse you could cable tie the trigger open or get a new unloader kit costing about £70.00 regards
Feb 17, 2010 | RTO 1800 PSI Pressure Washer
I just bought a 2nd hand honda excell psi max vr 2522 2.2 gpm max 5.5 hp gvc160. i put gas and oil and it wouldn't start?
Have a helper hold the trigger of the wand open while you try it again. If it starts that way you have a sticky unloader valve in the pump. DO NOT RELEASE the trigger for more than 10 seconds if the engine continues to strain when released! If the engine doesnt run freely when you let go of the trigger, pull it again and shut down the unit!
Add some power steering fluid to your supply hose (about 3 or 4 ounces at a time) and restart the unit with the trigger pulled. Allow the oil to flow through the pump for 1 - 2 minutes for each treatment. Several treatments should make the pump and valve happy again.
Hope this helps.
Sep 25, 2009 | Karcher 2500 PSI Pressure Washer
No high pressure no leaks motor runs off and on when trigger is released
check filter in wand and clean out nozzle hole for starters
May 04, 2009 | Garden
Pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Apr 19, 2009 | Campbell Hausfeld Garden
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
