Question about Radio Communications
How do you recharge a Motorola sp10 I need to know how to recharge it. I lost the manual.
  • Radio Commun... Master
  • 1,654 Answers
There are three methods of charging the HNN9044 battery used in an SP10 radio:
1) Use the HTN8232 10-hour wall charger. It plugs into a jack under the flap on the side of the radio (opposite side from the PTT button).
2) Use the drop-in style charger by setting the radio in the charger (this works if your radio has silver battery contact showing on the bottom.)
3) Use the drop-in charger to charge the battery alone. (The battery will set in the charge crossways to the way a radio would set.)
Lastly, if your battery will not charge by one of the above methods it might need replaced.
Best regards.
Posted on Nov 15, 2009
Trying to program sp21 to a sp10
If your SP21 and SP10 are both either VHF or UHF, it is possible to program them to match one another.
The SP10 is limited to 16 available channels, programmable by 4 dip switches behind the battery compartment of the radio. Great care must be used in removing the entire battery tray to get to the dip switches. Many times we see radios which have damaged mylar battery leads when someone attempts to get to the dip switches by removing the thin plastic/copper liner behind the battery. DO NOT remove this piece. It will come out with the battery tray. The tray is somewhat of a picture frame which holds the battery in place. In the SP10 radio it is removeable by slipping a small screwdriver or thin car key in the slot at the bottom of the radio and gently prying up. This will begin to dislodge the tray and you can pick it up and pull it out of the radio. (The upper battery contacts near the center of the radio will remain with the radio. The bottom battery contacts, if any, will come out with the tray.) At this point you should be able to see the 4 dip switches. The four most common VHF settings are:
ALL ON = GREEN DOT
ALL OFF = BLUE DOT
2 ON 2 OFF = RED DOT
2 OFF 2 ON = PURPLE DOT
Your preference on these should be limited to green and blue dot, as they are license-free, and are the only wideband frequencies still okay to use after Jan. 1, 2013, when the narrowband change takes place.
If your SP10 is UHF, or has 8 additional dip switches in the lower left below the main component board, you have PL. It would be best if you call someone who can help you with programming, as it is too lengthy to type more about this here.
The SP21 is PTT programmable. You hold in the PTT button while turning the radio on, and it will announce its frequency, press the monitor button once, and it will both lock in your frequency setting and announce the PL code setting. Either of these is changeable by pressing the PTT, followed by pressing the monitor button to lock in the new setting.
The primary VHF settings for the SP21 are as follows:
Freq 1 = Red dot
Freq 2 = Purple dot
Freq 3 = Blue dot
Freq 5 = Green dot
Once again, your preference, if you are VHF, should be toward Blue and Green dot frequencies.
Best regards.
Sep 28, 2012 | Motorola Walkie Talkie 2-Way Radio
I can't wind the bobbin tightly enough on my sp10 toyota sewing machinene
it's possible that the machine has a internal problem & that's why you can't wind a bobbin, or it could be warped, the machine needs to be serviced
Mar 06, 2012 | Toyota Sewing Machines
Looking for a 21" antenna for a Motorola SP10
There are custom made antennas for portables. But the better solution is by eradiostore, use a mag mount.1) custom portable antenna, expensive.2) Motorola adaptor to BNC to longer antenna (portable, car type or base station).
3) NO power increase, not only are those frequencies designed for low power the board inside the radio cannot handle the heat and is not changeable or adjustable.
Feb 02, 2011 | Motorola Walkie Talkie 2-Way Radio
Rotel processor bypass for Audio Research SP10
If I understand you, the 'sound' of the AR preamp is what you're trying to preserve. Presumably you're just running a phono through it as nothing else needs a preamp these days.
The multichannel inputs bypass all of the Rotel's processing except the volume. Use the Front L and R.
Mar 12, 2010 | Audio Players & Recorders
Maual for Motorola H350 bluetooth headset
The default pin for bluetooth devices is 0000 and the manual should be on Motorola's site. I found your manual on Motorola site. http://www.motorola.com/support/v/index.jsp?vgnextoid=e780462d3080e110VgnVCM1000008806b00aRCRD&vgnextchannel=248ae66506e9d110VgnVCM1000008406b00aRCRD click the quick start guide manual link on the right hand side to download the PDF
Jan 06, 2009 | LG VOYAGER VX10000 Cellular Phone
Hi - You can download the manual from the link underlined in blue below:
Motorola H350
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 15, 2008 | Motorola Mobility H350 Wireless Headset
Motorola h500
Delete it from your Razr, turn off the bluetooth and recharge it to full. Try pairing it again. Make sure you enter the passkey correctly. Check the manual for the bluetooth if you dont know what it is. It is usually 0000.
Dec 30, 2007 | Motorola Mobility Bluetooth Hands Free...
LG Bluetooth HBM -500 Passcode for pairing
I HAVE LOST MY Bluetooth H500 Manual, can you assist with passcode.
Dec 11, 2007 | Motorola Mobility HS850 Consumer Headset
Radio Communications Logo
288 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
