I have an Acer Aspire 3680. My hard drive crashed and I had to replace it. I made a recovery disc when I first got my laptop. When I put the disc in it doesn't do anything. Is there a certain way that this must be done...also this disc will have my vista os on it correct? Any help is much appreciated...thanks so much!
  • 4,924 Answers
Probably you have to run it ...or better boot from cd ...to do this you have to go to bios and rearrange the boot order such as to boot from cd first ...after that f10 to save changes and restart with the cd on ...it will prompt you to press any key to boot fromcd ...do it and follow instructions...
the other way is to restart and press F8 to select manually the boot priority ...select cd and enter to restart ...will also ask you to press any ket to boot from cd....if the disk it OK ..this will restore the system to that settings ...but ...keep in mind that will not format the C partition ...and if any viruses present it probably not go away ...to format the C partition you need to boot from a windows cd ..with partition magic in it ...or just run a xp installation to the point where you format the partition ..than reboot with the disk for recovery ...and it will be ok ...
Posted on Nov 14, 2009
2 Suggested Answers
Bear411
  • 4 Answers
SOURCE: I need a recovery disk
You can use a hard drive imaging program such as Norton Ghost to create a recovery DVD(s). Norton Ghost is available as part of System Works or as a stand alone program. Power Quest's Drive Image is also an alternative, however it is too old to be compatible with Vista - you could do a Drive Image outside of Windows - booting off the Floppy.
Posted on Sep 09, 2008
0xa0000002 acer aspire 5315 recovery after new hard drive. Replaced the hard drive. got the system and recovery discs. system disc asks for language, then kicks out and asks for recovery. recovery disk...
make sure disc is clean wash gently with warm soapy water going from middle to outer edge then dry with soft cloth going from middle to outer edge make sure cdrom is set to boot first then put RECOVERY DISC in first when finished put system disc in.
hope this helps.
Apr 28, 2010 | Acer Aspire 5315 Notebook
How do set my aspire 3680 back to factory setting
If you have a Recovery Partition on your computer then you will have to boot into the Recovery Partition to reformat your hard drive and reinstall your operating system. If you don't have a Recovery Partition then you will have to reinstall your operating system from a disc; if you have one. If you don't have the disc either, then you can get one from Acer. Otherwise you will have to go out and buy the version of Windows that you want from a store or from an online business. That will likely cost you at least $150, and then you will have to go thru the hassle of finding the drivers for all the devices on you laptop. So.......If you don't have a recovery partition or the factory recovery discs, then you should try getting a recovery disc from Acer. If you don't want to wait that long and you don't want to spend over $100 on getting it done, then you should see if a local computer repair shop will do it for you.
Apr 21, 2010 | Acer Aspire 3680 Laptop
I have an acer aspire 3680. I started up my computer and it said replace hard drive, immenident failure possible. It gave me the option to run startup repair but as is going thru the process, its keep...
Sounds like a virus. Remove the drive from the laptop and connect it to another computer using a USB cable. These cables can be purchased for around $20 from tigerdirect.com or compusa.com. After it is connected, scan the drive for viruses using your desktop antivirus program. If you do not have an antivirus program, I recommend that you download Microsoft Security Essentials for free from Microsoft's download site. http://www.microsoft.com/Security_Essentials/
Nov 17, 2009 | Acer Aspire 3680 Laptop
Insert the recovery CD into your computer.
Restart your computer, and choose "boot from CD".
Yes, the CD should include everything to reset your computer back to the "factory" settings.
Nov 14, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 3680 startup, blue screen & cursor only
  • prior to the recovery... have someone pull your hard drive and recover the "precious" files & pics on the drive... It's expensive at Best Buy... so watch out!!!
  • System recovery shouldn't have you loose all files.. if a recovery point is there... the trick is to only recover to the most recent point that you can. When Windows updates the software to Service Pack X for example, a recovery point would have been created automatically
Sep 13, 2009 | Acer Aspire 3680 Laptop
Acer aspire 3680 can't find op system
THE CMOS BATTERY IS BAD REPLACE IT AND REBOOT SYSTEM.
THE SYSTEM DOESNT SEE A HARD DRIVE, CHECK THE CABLES TO THE HARD DRIVE CHECK THE POWER CONNECTIONS
FILL THE HARD DRIVE SEE IF YOU FILL MOVEMENT, IS IT WARM,
POWER SUPPLY MAY BE ANOTHER ISSUE
NO OPERATION , NO SYSTEM, NO CONFIGURATION, CMOS CLEARED, POWER SURGE, LOSS OF POWER,
ROD
Jan 11, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 3680 start up
This is generally caused by a hard drive failure. You can try to repair or reinstall the operating system with your recovery or operating system disc. If you have any issues or problems during or after the repair/reload then the hard rive has failed and will need to be replaced.
Jul 20, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Complete Restore
http://www.acerpanam.com/us Go to that website and click on "eRecovery Disc Purchase". Acer does not come with recovery discs. It only comes with a recovery partition from which you can make recovery discs. If they discs were not made you'll find the provided website useful. If you're trying to recover from your recovery partition, then continuously hit the F11 key at startup. This F11 option is not always displayed. If this doesn't work then your hard drive is corrupt or damaged and you will need the discs (and potentially a new hard drive).
Apr 13, 2008 | Acer Aspire 3690-2196 Notebook
ACER ASPIRE 3680 WINDOWS ERROR RECOVERY
hi
you said u did try to press F2 or F8 to get to bios setting, are you saying pressing these would not open bios setting windows?
shakeel
Nov 06, 2007 | Acer Aspire 3680 Laptop
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
