Question about Proview HV-207 20 in. HD-Ready LCD Television
PROVIEW 19" LCD TV - FLATSCREEN - KV SERIES
I have no picture or sound, just blue screen. I have reset, but still no picture or sound. The TV is 2 yrs old & out of warranty.
  • 3 Answers
I have same problem, im goin to try this fix i found on youtube.. different tv but same problem
http://www.youtube.com/watch?v=_0175VbmV9M&feature=channel
Posted on Sep 18, 2009
6ya staff
SOURCE:
32inch proview lcd tv has a green square instead of a picture,but i get the sound .?
if you are getting color on the screen, chances are that you might have a cable loose. I'm not sure if you are using component cables but sometimes when the blue cable is loose, it will cause a green screen. or if you are trying to watch something above your TV's capabilities, this will happen as well.
May 04, 2010 | Proview HX303 30 in. HD-Ready LCD...
Image goes to black on Sharp flatscreen.
An LCD unit? Sounds like the backlight is failing. When it goes black next time, use a strong light next to the screen and look for a faint image on the screen....
If it is the backlight, its a service shop issue.
Mar 23, 2010 | Sharp 19 in. LCD HDTV
Comes on ,but no pic or sound.light blue screen. i think the blub is gone
You can tell if the bulb is out by powering up the TV and holding a flashlight to the tv. Put the flashlight close to the screen and see if you can see any picture. If you can see picture, then it's the backlight. If you can't see pictures it is probably a more serious issue and would likely need to be repaired by the manufacturer.
Feb 24, 2010 | Proview PA-32JK1A 32 in. LCD Television
TV turns on for about 5 minutes the the picture cuts out but sound stays on. Its a Proview 19 inch LCD TV
mrhackshack, Part of "switch-mode-power-supply" is going into SHUTDOWN mode having detected FAULT with other circuit (INVERTER) maybe???? Inverter lights-up the "cold-cathode-fluorescent-lamps" that provide RAW WHITE LIGHT so you can see all the pretty colors on the LCD GLASS PANEL. Technician will need to evaluate it!! Try YOUTUBE for vids on LCD TV repair and see if you can pull-off a DIY repair. Also see vids of LCD monitor repair and LCD monitor disassembly FYI. 12fixlouie Hope this points you in direction you need to go?????
Dec 10, 2009 | Proview PL926WBi 19" LCD Monitor
My sony 24in flatscreen has green color on right
dont power your tv near sound box or machines with magnet,
switch off tv, get a magnet and pass it all round your screen, it will clear with no time
Mar 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Proview 3200 Flatscreen with HDMI Problem
Maybe the input on the tv needs to be adjusted to work with the cable tv for example in the tv menu where you can adjust the sources for the inputs maybe it is set to something like RGB instead of HDMI. If you have a user manual consult it on how to change the input devices. Good luck.
Sep 17, 2008 | Proview HX303 30 in. HD-Ready LCD...
Proview 3200 HD TV
as you are using the ch3 , have you previously scanned and locked in all the channels for cable,
Apr 25, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
ProView 19'' Widescreeen LCD Monitor problems
It guess it is upon the logic board is having problem.
Feb 10, 2008 | Proview PL926WBi 19" LCD Monitor
Proview HV-207 20 in. HD-Ready LCD Television Logo
515 people viewed this question
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
Duncan Mutch
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
