Question about O2 Samsung SGH-E250 Cellular Phone
I can not get down load songs and pichers usein the usb lead do i need a disk?
How do I down load the music to my MP3 player
You should connect your playes to the computer using the USB cable it has. It should appear as a Retrivable Disk. Depending on bran, some has a folder called music, Copy your mp3 files to that folder.
Dec 08, 2014 | Audio Players & Recorders
When I down load videos to my Go Gear Vibe, they down load but when I go to videos, it shows NO VIDEOS FOUND.And it says it will hold 900 songs, 1600 pics, and 8 hours of videos, but the disk shows full...
To answer part of your question, the reason the disk shows full is probably because it can hold 900 songs OR 1600 pictures OR 8 hours of video. It depends on the size of the disk itself.
Hope this helps.
May 25, 2011 | Computers & Internet
Mp3 player
  1. plugg it with USB cord.
  2. go to my computer.
  3. check for removable disk
  4. open it
  5. drag music to it or copy/past files procedure
  6. focus on MP3 and WMA music files.
  7. give me a good rating so i can help others :)
Feb 02, 2009 | iLO (2 GB) MP3 Player
No disk
i need to know how 2 put songs on my mp3 player
Apr 15, 2008 | SanDisk Sansa m240 MP3 Player
YP-F1Z DEAD ??? ANY WAY TO REVIVE email billxw@gmail.com
I did get it fixed and posted elsewhere here how It happened and how to replace ther battery as well.
Bill MacLLean
Billxw@gmail.com
Apr 12, 2008 | Samsung Yepp YP-F1Z MP3 Player
Downloading to an mp3
connect the mp3 player it to the computer with a supplied/correct usb lead, then find the song you want to download using windows explorer as you need to know where the file is located/saved, right click on it then go to send to and the mp3 player should be listed, either as mp3 player or e:/f: - removable disk, chose this and then the song will be sent.
if you need to download songs to your computer in the first place go to limewire, this is a file sharing site which let's you download whatever song you want for free, it's totally legal and because of this site i have over 500 songs, all work perfectly and if you are using broadband only takes 2-3 minutes per song. once you have downloaded the songs you want follow the above instructions.
Feb 02, 2008 | iLO (2 GB) MP3 Player
How to delete songs from phillips mp3player
SOUNDS LIKE YOU NEED TO CONNECT YOUR MP3 player to your computer open the music folder from the mp3 delete every song then try and down load the music from your computers music library
Dec 02, 2007 | Philips LM1200 PHILLIPS 12" 2GB OPTICAL...
Annoying Songs!!!!
Try the USB connection. Shut down the Yepp, press and hold the "back arrow" button, plug it in the USB (with the arrow button still pressed). After a few secons your system will recognize the Yepp as a USB disk, so you can go to the folders and delete all the junk.
Feb 11, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
How to load songs in i-Bulldog IMP-90 (256 MB) MP3 Player
it is either one of the removable disks put the songs on to your desktop and drag them into the removable disk file in my computer soon enough you will have songs in you ibulldog.
Sep 24, 2006 | i-Bulldog IMP-90 MP3 Player
GPX MW6815DT trouble
For those that still use this mp3 player here are some things you need to know.
the gpx mw6815dt can operate as a media player or a usb storage device.
you need to change which state it is in via the System option.
Enter (Sys) from (Mode) go to (Online Device) enter (Mode) select USB Disk or Media Device. When you connect it as a USB Disk you will see all files not shown when connected as a Media Device using windows explorer. Also I suggest you make sure if you format the GPX you stay with the FAT 16 file system.
Note: DRM only works when the gpx is in Media mode.
If you have an SDcard installed you can access it via windows explorer or media player as a usb device only. With media player 11 you can still sync both the internal and sd drive with your library however you won't have drm options since your in usb device mode.
Note: in order to have both usb drives avaiable you need to use the Multi Drive option under (Online Mode) in the (System) menu, other wise you won't see the sdcard.
Feb 15, 2006 | GPX MW6815DT MP3 Player
O2 Samsung SGH-E250 Cellular Phone Logo
18 people viewed this question
Top O2 Cell Phones Experts
Computer Repairing
Computer Repairing
ivan georgiev
ivan georgiev
Are you an O2 Cell Phone Expert? Answer questions, earn points and help others
