Question about Acer Aspire 3680 Laptop
My hard drive crashed and I had to replace it. I
I have an Acer Aspire 3680...My hard drive crashed and I had to replace it. I made a recovery cd when I first got my laptop..but when I insert it into the drive it doesn't do anything. Is there a certain way I need to do this? Also does this cd I made have my Vista OS on it? Thanks so much for the help!
  • Acer Master
  • 8,404 Answers
I don't know about what might be on your recovery CD.
Did you format the new drive and make it a bootable device? The CD that came with your new drive should have taken care of this. You may want to run this again.
Please press F8 on bootup (or what ever other key they direct) to enter the BIOS "set-up" and check the boot sequence. You want your computer to check the CD drive for bootable device before it checks the hard drive (presumably the C: drive)
I hope this helps you out.
Thank you for your interest in FixYa.com
Please vote.
thanks
a
Posted on Nov 14, 2009
    Brigadier General:
  • 10,406 Answers
Insert the recovery CD into your computer.
Restart your computer, and choose "boot from CD".
Yes, the CD should include everything to reset your computer back to the "factory" settings.
I have an Acer Aspire 3680, I had to do wipre my
sounds like the hard drive still when i re install on mine i take out hard drive re instert juast to be sure its in nice and straight no bent pins ect pop in your windows disc and turn on it normally says press any button to boot from cd so tap a button then you should follow the guide for install not repair then do quick format it wont take as long and is goos enough let it go to the point ware you can see a basic list of size of your hdd and partions just allow delete every thing then you should just see unpartioned space if 40gb then it would be 39000mb ect then install there that makes sure that nothing else is on you hdd that could mess with the boot if you are still not sure email me and i can send you a more detailed set by set guide its shaunhoop1981@googlemail.com
Jun 05, 2010 | Acer Aspire 3680 Laptop
Is there another way to access erecovery than using ALT + F10 on an Acer Aspire 3680?
only other way is to use your recovery disks
So for this you need to change the boot process to cd/dvd rom.
the recovery disk set normally has 3 cds and 1 system cd
system cd first to activate the recovery mode
then other cds 1-3 will do a complete reinstall like a new machine
lastly you will need to put the system cd in to close the reinstall
CAUTION
this will erase all data from your c drive
and replace it with a factory default set up
I have done it plenty of times,works well.MISTERDJ
Mar 24, 2010 | Acer Aspire 3680 Laptop
Acer Aspire 3680 startup, blue screen & cursor only
  • prior to the recovery... have someone pull your hard drive and recover the "precious" files & pics on the drive... It's expensive at Best Buy... so watch out!!!
  • System recovery shouldn't have you loose all files.. if a recovery point is there... the trick is to only recover to the most recent point that you can. When Windows updates the software to Service Pack X for example, a recovery point would have been created automatically
Sep 13, 2009 | Acer Aspire 3680 Laptop
Black screen.
A few questions up ahead please:
a. Is the power button lighting up when you press it or power on your laptop?
b. Is the battery fully charged?
c. is the power cable/charger still good when you connect to mains supply?
**If you answered YES to all the above...
Your laptop screen may be bad and as such must be replaced.
Otherwise, The windows operating system may have CRASHED.
If this is so, then you can try out this system recovery tips as the last resource:
1. try remove the hard drive which you can access by opening the back cover as shown in the owner's manual.
2. next, connect this through an external usb casing to another system and backup all files on the hard drive.
3. if you don't have an acer recovery cd(s) for your laptop, try get someone who has and can help you burn the software for your model and make.
4. next, format the hard drive before you reinstall it back into your laptop.
5. power on your laptop and continously press F8 to enter the bios setup.
6. Select bootup sequence and select boot from cd drive.
7. first reinstall a lower version windows os by inserting a bootable system software.
8. after installation, keep the cd rom drive open and shut down your laptop.
9. insert the acer system recovery cd into the cd rom drive and close shut.
10. Restart your laptop then, Follow the instructions and prompts.
Your laptop will be restored to the way it was originally from the manufacturer.
Jul 08, 2009 | Acer Aspire 5050-3242 Notebook
Acer aspire 3680 can't find op system
THE CMOS BATTERY IS BAD REPLACE IT AND REBOOT SYSTEM.
THE SYSTEM DOESNT SEE A HARD DRIVE, CHECK THE CABLES TO THE HARD DRIVE CHECK THE POWER CONNECTIONS
FILL THE HARD DRIVE SEE IF YOU FILL MOVEMENT, IS IT WARM,
POWER SUPPLY MAY BE ANOTHER ISSUE
NO OPERATION , NO SYSTEM, NO CONFIGURATION, CMOS CLEARED, POWER SURGE, LOSS OF POWER,
ROD
Jan 11, 2009 | Acer Aspire 3680 Laptop
Cd/dvd drive problem
Try with another brand of disk; the Matsushita UJ870 drive of our 5315 burn my Sony CD's but not my Philips CD's (my Compaq V2617LA with an older Matsushita UJ840 drive has burned Phillips CD's in the last two monts)... Remember: CD and DVD lassers are different. I think because of that, i haven't see problems with Sony, Philips and Samsung DVD's... only with CD's...
Jun 04, 2008 | Acer Aspire 5315 Notebook
Acer aspire 3000
try booting the hard drive, and pressing F8 and booting to last known good configuration. If that doesnt work gheck out SUPER GRUB, it can fix your MBR if needed.
Jan 29, 2008 | Acer Aspire 3680 Laptop
ACER ASPIRE 3680 WINDOWS ERROR RECOVERY
hi
you said u did try to press F2 or F8 to get to bios setting, are you saying pressing these would not open bios setting windows?
shakeel
Nov 06, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
108 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
