Question about Mcintosh MC300 Amplifier
I have a MC2205 mcitosh amp sr. # AX6581. There
I have a MC2205 mcitosh amp sr. # AX6581. There is a thermistor with no identifying marks between the power in and the 10 amp 250 volt fuse holder. Can you tell me what it is ?
  • 5,807 Answers
You can use this temporarily
THR part number is NTC 5D -9
these might be near or similar to yours ST2R503B
http://www.ussensor.com/prod_inrush_power.htm
Posted on Nov 14, 2009
  • Rommel Cana
    Rommel Cana Nov 14, 2009
    you can also series 100w incandescent bulb just to test if really the
    thermistor you are really having problem with, if the bulb glows bright
    then it is on the load , not on the thermistor
How do you replace the fuse?
Push the black cap in and turn.
I doubt that the fuse will fix it, though. Static sounds and then shutting down is a sign that something has gone wrong in the amp. It needs servicing by a competent tech.
May 26, 2015 | Mcintosh MC2205 Amplifier
MCINTOSH MC2205 LEFT POWER PC BOARD
Check www.mcintosh.com contact customer support and the technical department, also! www.ebay.com Type make and model, and scroll through the list.
Jun 20, 2012 | Mcintosh MC2205 Amplifier
Where do i see the fusing unit thermistor,thermoswitch &heaterlamp
I do not know which model of copier / printer you have, but generally the fusion units are on the sides of the machines, covered with a lid that can be opened easily, can be easily identified by the labels of caution have to be very hot.
The thermistors, heater lamp and thermoswitches are components that make up the fusing unit, the lamp is in charge of heating rollers, thermistors regulate temperature and thermoswitches turn on and off according to heat in the fuser.
They can sell separately or sell the whole unit, it will depend on the suppliers and the model of your printer or copier.
Good luck ...
Feb 27, 2012 | Office Equipment & Supplies
Its copier (ir2016j)to desply writh system error. wath is this problem?
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание E000 0000 Fixing temperature abnormal rise E001 0000 Fixing unit temperature rise detection (by main thermistor) 0001 Fixing unit temperature rise detection (by sub thermistor) E002 0000 Fixing unit temperature insufficient rise E003 0000 Low fixing temperature detection after standby (by main thermistor) 0001 Low fixing temperature detection after standby (by sub thermistor) E007 0000 Fixing film rotation error E010 0000 Main motor rotation err
Dec 17, 2009 | Canon Office Equipment & Supplies
Canon IR 2200 manual
Canon iR2200 / iR2800 / iR3300
Некоторые ошибки зависят от того, какая опция установлена: например, ошибки E514 для Saddle Finisher-G1 и Finisher-J1 имеют разные причины.
Код ошибки Субкод Описание E000 0000 The reading of the main thermistor does not reach 30oC 1 sec after the main power switch is turned on. Or, it does not reach 70oC 2 sec thereafter E001 0000 The main thermistor detects 250oC or higher 0001 The main thermistor or the sub thermistor detects overheating (hardware circuit detection) 0002 The sub thermistor detects about 295oC or higher E002 0000 The temperature of the fixing film is as follows:
  • has exceeded 100oC, but does not reach 115oC within 1 sec thereafter.
  • has exceeded 140oC, but does not reach 150oC within 1 sec thereafter.
  • has exceeded 160oC, but does not reach 165oC within 1 sec thereafter
  • E003 0000 The main thermistor reading is lower than 140oC when paper is moved 0001 Low fixing temperature detection after standby (by sub thermistor) E007 0000 An error in the rotation of the fixing film is detected.
    The reading of the main thermistor is 100oC or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven E010 0000 After the main motor drive signal is generated, the clock signal does to arrive within 1.3 sec
    Sep 13, 2009 | Office Equipment & Supplies
    Water Temp on heater reads 126 degrees F
    I am not sure if you have resolved this issue, or not, but just in case. Yes, the problem is the Thermistor. This is a sensor that "reads" the incoming water temp. It is really easy to replace as well.
    Jun 29, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
    Com terminal on MC2205
    Typically the black is common and the red positive. The only difference will be the direction in which the speaker cone moves. Either it will move outward or inward. In the correct connection polarity, the cone should move outward. Be careful that both speakers are connected the same way. This is actually just as important. If they are hooked up differently, they will be out of phase and you will notice a significant DROP in low end response.
    Dan
    May 12, 2009 | Mcintosh MC300 Amplifier
    NEC vt460
    It does in fact appear to be a thermistor and the TH1 board marking seems to confirm that.
    What markings are on the component (it appears to be a power transistor of some kind) adjacent to it?
    If we can find a standard part number for it and you own some kind of meter, perhaps we can either eliminate or identify it as the original culprit.
    The failed thermistor is either acting as a temperature sensitive clamp to prevent lamp failure or regulates lamp intensity dependent on temperature.
    Maybe an email to NEC would get you the value of it (TH1) since I suspect a schematic or parts list will be hard to acquire.
    Jul 01, 2008 | NEC VT460 Multimedia Projector
    62 people viewed this question
    Top Mcintosh Audio Players & Recorders Experts
    sean tan
    Level 1 Expert
     Grubhead
    Grubhead
    Jay Plesset
    Are you a Mcintosh Audio Player and Recorder Expert? Answer questions, earn points and help others
