Question about RCA R52WH73 Projection Television
I have a blue red and green image. the image is smaller than the screen. is this something I can fix myself?
    Genius:
  • RCA Master
  • 1,689 Answers
These are faults in the scan amplifiers. I have my doubts you can fix this yourself! You will require the proper training, and troubleshooting instruments to determine the fault. Then you will have to be able to change the parts, and re-calibrate the scan amplifiers.
In servicing these sets, there are serious safety issues. I don't recommend any non qualified person to go inside of their TV set!
Get a professional estimate first. I am sure you will find the cost will be expensive. There may also be an availability of parts issue depending on what has failed.
Jerry G.
Posted on Nov 14, 2009
I have and 65" Mitsubishy HDTV model WS-65511 serial :118393 I never had a problem before but las week i was watching a program and sudenly a second blue image was on the scrren, i decided to open the...
there just might be a slight chance an adjustment of g2 high voltage to the blue tube might help however there is a good chance there is a problem with the tube
Oct 15, 2010 | Mitsubishi WS-65511 65" Rear Projection...
I have a great picture but only shows red and blue also the glare screen needs to be fixed, Is this something I can do myself?
Sounds like the Green CRT drive board is defective. You can get a CRT drive board from www.tvrepairworld.com you can also get the replacement screen assembly there also.
Jul 06, 2010 | RCA D52W23 52" HDTV CRT TV
Samsung CRT HDTV - Red, Blue, but No Green.
If their is no green chances are the chip for RGB on the tubebase has packed up its usually something like a TDA 6107Q
Jul 06, 2009 | Samsung TXJ3676 36" TV
Problem with RGB color...registering as green and image distorted
did u fix your tv cuz thats the same thing thats happening to me
Apr 15, 2009 | Philips 60PP9202 60" Rear Projection...
RED GREEN BLUE CONVERGENCE IS OUT.
if you have a rca hd56w66 chasis itc222 you may have the common fl231 fuse problem. I see this everday at the shop. to determine if you may have this problem. i have written a little article on this subject. Consult tips and tricks section under my profile. Going into maintence mode might have reset some settings.
Nov 24, 2008 | RCA HD56W66 56" HDTV
PT-47WX53G green convergence and wave on bottom of screen
Had same problem with Red. Could not adjust. Funny broken lines. Found this link:
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Replaced the ICs. Was disappointed at first 'cause it was still all bowed out, but then realized that the Convergence 2 "target" can be changed with the number keys. Working thru 1-9 and going back to readjust as necessary adjusted each one into perfect alignment.
Problem solved. TV works great.
I should add that while I am reasonable technically adept, I am a software geek and never soldered before... hardest part was getting up the courage to dive in and do it myself. Glad I did.
Sep 24, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Pink colour everywhere
Assuming all power supplies are OK, you most likely have a bad CRT grid, and that respective (red) tube must be replaced. I'm sorry that it went that way, as this repair is not cheap....accordianman
Sep 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
LG Rear projection tv help... Red, Blue and Green horizntal line through screen.
The complaint may be dry solderig or yoke ,horizontal or vertical oscilator
Dec 29, 2007 | Televison & Video
Blue Halo, Tried to adjust on Projection TV
The convergence issue you have will not adjust out....repair
of the convergence circuit will be necessary....then adjust...T.
Dec 01, 2006 | GE 46GW947 46" Rear Projection Television
RCA R52WH73 Projection Television Logo
41 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
