Question about Whirlpool Duet GHW9150P Front Load Washer
Will not spin fast, only goes cw and ccw at medium speed during spin cycle
  • Anonymous Mar 23, 2014
    the spin cycle on normal at medium speed goes into super spin
I took the stainless steel basket out and found the aluminum spider to be rotted. The basket was dragging and that made the motor overload.
I made up a stainless steel plate, took the original shaft and pressed it in.
Re-assembled and now is fine
Posted on Nov 15, 2009
Tip
Fan Clutch R&R With Confidence Using Griller....Glitter Tool
...ever found you self asking which way to turn a mechanical fan clutch's inline coupling nut to remove clutch-fan assembly (It) without mangling a thread or special wrench? Well then, consider the Griller...Glitter mnemonic system described below and never fail to be "thread-wise in the know."
If you know or can bump the starter to see which way the fan spins viewed from the radiator, then knowing any or all of the easy-to-remember devices below will let you get that clutch off, or on, with confidence. For instance, with a left thread clutch nut, the installed clutch-fan assembly will always spin right/clockwise.
Remember, you only need to remember the ones that are easy to remember.
    ·GRILR
    ·GOES RIGHT? IT LOOSENS RIGHT.
    ·If fan clutch spins right/CW, turn its nut right/CW to loosen.
    ·GRITL
    ·GOES RIGHT? IT TIGHTENS LEFT.
    ·If fan clutch spins right/CW, turn its nut left/CCW to tighten
    ·GLILL
    ·GOES LEFT? IT LOOSENS LEFT.
    ·If fan clutch spins left/CCW, turn its nut left/CCW to loosen.
    ·GLITR
    ·GOES LEFT? IT TIGHTENS RIGHT.
    ·If fan clutch spins left/CCW, turn its nut right/CW to tighten.
on Jan 12, 2015 | Vehicle Parts & Accessories
What would cause a nasty metal nashing sound when machine goes from medium spin to high speed spin during spin cycle?
Hi dear,
As I know it happens to other Asko washer models as well. From 800 rpm going up to 12-14 or 1600 rpm. That sounds happens due to vibration generated from motor. I do not thing you can do much about it unless changing motor,which is costly remedy. Thanks.
Jan 09, 2016 | Asko Washing Machines
Cae2743bq will not turn on all lights on and lid lock is lit up
Try this, worked for me! :)
New WHIRLPOOL Top Load Washer
Model #'s CAE2743BQ, CAE2763BQ
Cycle Selector Knob key dance: [CCW=Counter Clockwise and CW = Clockwise]
Start On "NORMAL"
1 step CCW (Left)
2 steps CW (Right, Right)
1 step CCW (Left)
1 step CW (Right)
Stay on "HEAVY DUTY"
(If unsuccessful LEDs will not flash, and you must return the selector to the Normal Cycle position and
wait 4-5 seconds before retrying. )
If you are successful in the process, all LEDs will be flashing
Toggle between HEAVY DUTY and NORMAL until ONLY the RINSE light is on, then press the
START button for about 30 seconds. Machine will then enter CALIBRATION mode for about 2 - 4
minutes. DO NOT RAISE THE LID
Sep 01, 2013 | Whirlpool Washing Machines
Hello. i would like to know the direction drive shaft spins looking from rear of bike cw ccw
If the drive shaft is on the right side of the bike it will spin counter clockwise (ccw) when the cycle is moving forward.
If the drive shaft is on the left side of the bike it will spin clockwise (cw) when the bike is moving forward.
Jan 26, 2011 | Honda VF 750 C Magna Motorcycles
Will not spin during spin portion of cycles. it rotates slowly cw and ccw but no fast spin
It's either a bad door switch, or motor control board. Definitely easier and cheaper to try changint he door switch first, as it fails much more often. Part number is 131763202
Apr 06, 2010 | Frigidaire Affinity ATF7000E Front Load...
I just replaced (new) the clutch on my FAV9800AWW, and machine goes through most of regular cycle, but at some point (reverse or tumble?), it tries to do something between the motor and clutch and the belt...
Hey gunsmoke55,
Let’s collect some info. and I will try to help. I own the FAV6800A the LED flavor of the machine and as you can tell from my nick name I DIY all repairs on the machine.
1. Did your FAV9800A signal an unbalance statement to the display to trigger the clutch replacement?
2. How badly rusted up was the One-Way Roller clutches bearing? Did you follow my clutch maintenance/repair post to replace your new clutch? Clutch Fix Post .
3. When you removed the original clutch did your series of the machine use the Upper One-Way Roller clutches bearing ring? From pulling info. from other FAV6800A owners I have been able to confirm series 10 and 11 used the Upper One-Way Roller clutches bearing ring. Info from FAV9800A owners is very lean. What is your series of machine (the first two digits of your serial number) and did it use the Upper One-Way Roller clutches bearing ring?
4. You should be able to rotate the wash basket with one finger CCW with very little resistance. Try that and let me know if the wash basket will rotate CCW with one finger . The wash basket must not rotate CW by hand. With the front cover removed (pull the 120VAC power cord) you should be able to rotate the Clutch Pulley CCW and CW with light resistance.
“”I just replaced (new) the clutch on my FAV9800AWW, and machine goes through most of regular cycle, but at some point (reverse or tumble?), it tries to do something between the motor and clutch and the belt just squeals very loudly and burns. Ideas? SW””
If you machine used the Upper One-Way Roller clutches bearing ring it may not be seated in the wash tub base properly. It is a very tricky fitment process to re-install it and the Clutch Pulley assembly correctly. Let me know what you find and we will go from there.
Some insight into normal operation of the machine you may be aware of this; In the wash/agitate cycle the Control Board signals the Motor Control board to power the Motor CW turning the Clutch Pulley CW driving the agitator shaft which drives the transmission to rotate the tumblers only.
In a Spin Only cycle or the Spin Cycle of a Wash Cycle the Control Board signals the Motor Control board to power the Motor CCW turning the Clutch Pulley CCW. The One-Way Roller clutches lock up solid driving the Spinner assembly CCW spinning the wash basket CCW. When the One-Way Roller clutches do not lock up rock solid and slip you get tumbler movement as the wash basket begins to spin up. This causes the wash basket load to go off balance and if the TDS is working properly it’s signal input to the Control Board exceeds design limits of Outer Tub movement and the Control Board fails the Spin Cycle wit a dC or uC unbalance error or in your case an unbalance statement to the LCD display.
Also during the initial water fill cycle of the wash cycle the Control Board will signal the Motor Control Board to power the wash basket CCW slow RPM. I believe the Maytag design team did this to wet the wash basket load on initial water fill…..Rich 5a647fe.jpg
Feb 01, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Spin cycle locks up
it is the clutch and be repalced fairly easily
Oct 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Tub rotates CW during agitation, out of balance, hits side of metal cabinet, but no error code
Hello srcoray,
Did you replace the clutch, just trying to get a feel for your hands on experience with the machine? If you did the work did your machine use the upper roller clutch bearing along with the clutch pulley mounted roller clutch bearing?
The FAV6800AW uses a reversing motor and motor controller that powers the motor and clutch pulley to rotate CW in Wash/Agitate cycle and CCW in Spin Cycle.
In Wash/Agitate cycle the roller clutch bearing should rotate freely CW allowing the agitator shaft to drive the transmission in wash cycle driving the tumblers to rotate only not the wash basket. In spin cycle the roller clutch bearing will lock up (one-way roller clutch bearing) driving the spinner shaft to rotate the wash basket and transmission CCW. Unless my thinking is wrong it sounds like the one way roller clutch bearing is frozen or dragging and not rotating freely in wash cycle rotating the wash basket CW. I’m an owner like you and will try to help.
Just a few other questions;
If you have a load of wet clothes in the wash basket and you select Spin Only cycle will the spin cycle complete with out dc/UC errors?
With the lid raised can you rotate the wash basket CW? It should not; it should only rotate CCW and do that with very little resistance.
Rich
May 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Clutch bearing question - tub not spinning
Hello jpdarrish,
“” Having similar problem as many with machine not spinning and stalling at the first spin cycle and never completing. I opened the lid during the cycle and see the tumplers will spin ok but the tub will not spin and cannot move in either direction by hand.”” Was this the original issue before you removed the clutch? Were you taking dc or UC errors to the display?
“”As a note, the tub will turn freely by hand while the clutch is disengaged. As soon as it's seated, it's impossible to turn the tub by hand.”” By disengaged do you mean that the clutch pulley was removed from the machine and the wash basket rotates CCW freely?
With the Clutch pulley installed properly the wash basket will only rotate CCW it will no rotate CW that is normal operation. You should beable to rotate the wash basket CCW with one finger and very little resistance with the clutch installed.
""I did remove the clutch assembly. The sping mechanism looks good. I used WD-40 and some bearing lube on the needle bearings. But the bearings will only turn in one direction. Is that normal? Anyway, I reassembled (took a bit of work to get it completely seated) and tried but still having same issue.""
Yes this a Drawn Cup Roller Clutch designed to rotate one way only clockwise for our FAV6800A/FAV9800A machines.
My description of how I believe the Roller clutch bearing engages the spinner shaft to spin the clutch basket.
This write up is my understanding of how this clutch system works in the FAV6800AW/FAV9800AW. I could be wrong and would invite any comments from the forum to help me better understand how the clutch works in wash and spin cycle;
The clutch in the FAV6800AW/FAV9800AW incorporates a Drawn Cup Roller clutch bearing. This roller clutch bearing will allow one-way rotation freely in clockwise rotation. The FAV6800AW/FAV9800AW washer uses a reversing motor which has power supplied by the motor controller. In wash cycle the motor controller powers the motor to produce clockwise rotation which turns the clutch pulley CW. The Roller Clutch Bearing spins freely in the CW direction so only the agitator shaft will rotate driving the transmission to rotate the tumblers. In spin cycle the motor controller powers the motor CCW. This rotates the clutch pulley CCW and the Roller Clutch Bearing locks up and drives the spinner shaft CCW. At the start of a spin cycle the tumblers will rotate ¼ to ½ turn of rotation and no more as the clutch spring is wound to tension. Once the spring is wound to tension the spinner shaft begins rotating the spinner plate which rotates the transmission and wash basket CCW. Because the transmission is spinning at the same rate as the wash basket the tumblers do not rotate. This will happen if the clutch spring is broken and in spin cycle the wash basket will spin very slowly with no clothes in the wash basket and the tumblers will rotate. You will need to replace the clutch.
Dose you clutch look like the one on the left or right? My is on the right and my machine is a series 16 1st digits of my s/n are 16.
If your Roller Clutch bearings rotate freely in CW direction and you installed the clutch pulley correctly you should beable to rotate the washbasket CCW with the lid open with one finger. If it dosent we have some binding issues with the clutch install. This is from a post of a forum member I helped. He has a good install fitment process. This is a challange but I can no do to it in less then 5 min. after a dozen or so clutch removal and installs of my machine.
""The Service manual download was very helpful because it has a few pictures to show the 1/16"-1/8" gap from the shaft to the clutch face. What this really is telling you is that "if" you get all the three parts (clutch plate- bearing sleeve and cream colored plastic piece with 2 raised projections) to the clutch assembly back in correctly, you will end up with the 1/16"-1/8" gap. I also did my repair by tilting the machine back and working on it in place. Test the fit of each of the 3 pieces seperately so you will have a better idea what you are trying to fit. The cream colored plastic piece with 2 raised projections "seats" into the bottom of the tub. The bearing also seats onto the shaft in the notches. The clutch simply fits on the square shaft. The trick is getting the 3 piece assembly on with every piece seated correctly. By no means impossible, but working in limited space it was the most difficult part to do. Something that I thought of (after the repair) was to actually cut out the sheet metal directly below the clutch. This would allow easy access for the reassembly.’”
Again I believe your original clutch uses the upper bearing piece, as pipespike states you have to get the fitment of the upper bearing assembly the bearing sleeve I call it the coupler and the clutch seated properly to get that 1/16"-1/8" gap shown in the Service manual page 47.
Try a reinstall of the clutch after reviewing the above comments. After the clutch reinstall first try to rotate the wash basket CCW with one finger it should offer very little resistance and not rotate in a CW direction.
Post back for any additional help. Rich
Apr 20, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
94 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
