Question about Andis 01690 Hair Trimmer
I have only used my andis ag2 several times but already it is not cutting. I have oiled it and kept is cleaned but it just doesnt want to cut. The motor works fine but it just wont take the hair off my cocker spaniel. I am using a #10 blade. Could it already be dull? When I go to cut her hair, the blade slows down a lot in her hair and gets stuck.
    Genius:
  • 1,044 Answers
Sure enough the blades have become dull. Change them
Posted on Nov 14, 2009
My toutliner cutting too sharp
Adjust your blade. Remove it from the clipper, and then loosen (don't remove) the two screws that hold the blade and cutting edge together. Use a FLAT surface, like a ceramic sink top or flat piece of tile, and push the cutting edge down and angle the blade with the cutting edge facing the flat surface down to about a 30 to 35 degree angle. Use your thumb to hold in place until you can retighten the screws. Under a light, inspect to see if it is level (it will be noticeable if it isn't) or oil the blade and touch it to a clean dry piece of paper. If it is level, replace the blade on the trimmer, and edge your beard. It should be better than brand new. This also works when it doesnt seem like the blade is cutting sharp anymore. ALWAYS make sure the cutting edge is lower than the blade or you WILL CUT YOURSELF or YOUR CLIENT!
Mar 29, 2014 | Andis T-Outliner Hair Trimmer
I have an Andis 10 blade model MBG2 that i use on my border collie and miniature schnauzer. When i go to cut my dogs hair it works perfectly for a few seconds (which leads me to believe the blade is still...
When is the last time you cleaned and oiled your blades? Or if you have been using them for a long time they may need to be sharpened? Blades experience wear and tear and require regular maintenance.
Aug 08, 2013 | Pets - Others
Andis master clippers lose power
Oil the blades and then adjust them. You will need to add oil while grooming from time to time and then clean & oil them again when finished.
Sep 23, 2012 | Andis Improved Master Clipper/Trimmer...
When i cut hair my andis master clipper seems to get stuck while cutting hair causing me to take longer with the fade how do i go about fixing it to where it doesnt get stuck in hair & by the way im...
mcdevito75 here, Sounds like the blades need to be sharpened, refer to the shavers brand name plus .com for blade replacement or replace the shaver.
Jun 19, 2010 | Andis 01690 Hair Trimmer
It keeps geting hot every time i cut my hair
you should put clipper oil where the blade contacts it's base (near the middle of the base) and spray kool lube or a similar product on the cutting edge.
Aug 08, 2009 | Andis T-Outliner Hair Trimmer
Andis Ag2 clipper blades-I dropped the 4fc blade and now it will not cut. How do I adjust it so it will cut?
can you move the cutter blade (this is the smaller blade) side to side easily with your fingers if so the tension on the cutter blade has loosen. you need a special tool to reset the tension and the spec' on how much tension. send the blade to mannyssharpening.com they have fast return service and return shipping is included in the sharpening price.
Jul 12, 2009 | Andis 01690 Hair Trimmer
Shaver no longer cutting well
Have you been keeping the blades cleaned and oiled well? How long have you had the clipper it may be that you need a new blade? This trimmer is not truly intended to do a complete clip on a poodle it is for trimming. Please call Andis customer service at 1-800-558-9441 for further instruction.
Dec 14, 2008 | Andis 18050 Hair Trimmer
My andis clippers are experiencing blade not moving. it is not cutting.
Push top blade to right side right with finger,then turn clipper on and dip  into 3 in one oil,blades only,let clipper run for one minute,clean excess oil off blades,if clipper still want vibrate,take blades off the clipper and clean them,then place back on clipper, I've had this problem many times,i also repair clippers,adjust blades,etc...
Oct 09, 2008 | Andis 01690 Hair Trimmer
Andis 01690 Hair Trimmer Logo
338 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
