Question about Hitachi 51S500 51" Rear Projection HDTV-Ready Television
Attach laptop to hitachi 51s500 tv
I have model 51s500 hitachi tv, i would like to attach my laptop to it to watch movies. what cables do i need. i was thinking it could be hooked up in front but wonder if it has to be through back thanks
    Genius:
  • Hitachi Master
  • 1,667 Answers
See if on the back of the TV, and on the computer you have an external type VGA type connector. You then have to purchase a long VGA interface cable to go between the laptop and the TV set.
The TV must be compatible to receive the VGA and external audio from your computer, and the computer must be capable to drive external audio/video devices.
Another issue that must be worked out is both the TV and computer must have compatible screen resolution rates. You will have to get the information about the display card in the computer, and compare it to the specs of the TV set. If these do not match up in to proper range you will either have a very stretched or compressed picture, or you may not be able to have any results at all.
If the scan rates are too far out, it is possible to damage the TV set!
If everything is technically correct, you will also have to purchase compatible cables to go from the lap top external audio output to the correlated audio input connectors on the TV. This is an adapter type audio cable.
For these cables, you will have to determine the connector end types on each of the units, so that you can go to any audio/video supply store and properly pick them out.
There is a simpler solution, but it will not have good picture quality. You can buy a VGA to baseband video converter box (if these are still available). These are not cheap but they can work if set up properly and the scan rates can be matched. You attach the converter box to the external VGA port on the computer, and then use its output via the proper baseband video cables to drive the TV set. The scan rates will still have to match. The quality will be very poor.
Jerry G.
Posted on Nov 14, 2009
Testimonial: "helpful but you still have to be a brain to find the right cables...."
Connect hp laptop to tv to watch Netflix downloaded movies
how do i hook up my hitachi tv to my hp laptop to get netflix?
Jul 23, 2010 | Hitachi 51F59 51" HDTV Projection...
Not working
Did you try to physically unplug the TV? Leave it unplugged for a few minutes then plug it back in.
Apr 03, 2010 | Hitachi 51S500 51" Rear Projection...
What is the replacement lamp part # for a Hitachi Rear Projection 51S500
You have 3 Tubes RED/GREEN/BLUE you do not have a Lamp your TV is projection not DLP Go to Encompass Electronics.com 1-800-638-3328 they have a list of all parts to your TV.
Oct 04, 2009 | Hitachi 51S500 51" Rear Projection...
My Hitachi 51S500 is showing a black screen
Did you unplug the set from the wall and wait 5 min. replug and try. Cusult your owner manual regarding parental Locks?
Sep 17, 2009 | Hitachi 51S500 51" Rear Projection...
Connecting Hitachi VCR to my Direct TV.
Connect your Direct TV to the Ant. In connection on your VCR. When you want to watch TV, just tune the TV to channel 3 (or whatever channel the Receiver is set for). When you wish to record, set your VCR to that same channel and set your TV to the channel that your VCR outputs to. For simplicity sake, I would suggest setting both systems to channel 3 and just watching your program through the VCR. If you are still using an "off air" antenna, then connect that antenna to the ANT. IN connection on your Direct TV receiver and when you turn off the dish, it will pass the signal through just like the VCR would.
Jan 28, 2009 | Hitachi VTF392A VCR
Blue-ray Player HDMI jack to existing TV DVI-HDTV connector
Unless your TV is HDCP compliant (sorry, don't have to research this for you), you may not be able to watch Blu-Ray movies from your Blue-Ray player in 1080p. So first find out if your TV can do HDCP via the DVI port (i doubt it). If it can, you can get an HDMI-to-DVI adapter (you can find them real cheap off Amazon.com)
-Eddie V.
Dec 31, 2008 | Denon AVR-485 Receiver
Hitachi 51S500 51 in.
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Aug 11, 2008 | Hitachi 51S500 51" Rear Projection...
Center of my T.V. is black.
Turn off all closed captioning in menu and change it from text to caption.
Jan 16, 2007 | Hitachi 51S500 51" Rear Projection...
Hitachi 51S500 51" Rear Projection HDTV-Ready Television Logo
400 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
