Sounds like a Lid Switch
Lid switch assembly part# 134101800 replaces older switches 131675600, 3205646 & 131595100
Some installation tips.....
Free standing washer,
~ disconnect the washer from the electrical supply
~ raise and brace the top panel
~ disconnect the wire harness from the lid lock assembly
~ using a 1/8" drill bit, drill out the rivets securing the mounting bracket to the washer top panel and remove the original switch ( not all have rivets, some are just screws )
~ remove and save the screws securing the lid lock switch to the mounting bracket
~ install the new lid lock switch using the previously removed screws. If you require more infor comment back. Best of luck.
SOURCE: 14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
SOURCE: my maytag neptune front load washer won't spin all the water out
does the door lock light still come on, ???place in a spin cycle to check, if need be( it will take a min or so to light), if hte light never comes on i would remove three phillips screws from across teh top of machine console, there will be a circuit board mounted to the back wall, slightly left of center of the board youll find a light blue box,tiny maybe 1/2inch rectangle. interested in the resistor directly above that box, is theres abig burn mark around it??? if so there is your problem , youll need to replace the machine control board and also the wax motor in hte latch assembly( do not change one with out the other
SOURCE: Kenmore front load washer will not spin. Clothes come out wet.
The clothes are wet after spinning
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
SOURCE: Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
SOURCE: My CRTR9300ASO Frigidaire Front Load Washer makes
if you lucky, you have a broke shock absorber on the bottom. if your luck is not so good......well we will find out.
open the door on your washer. locate the big silver basket in the middle. put your hand in side and push up. now this will move but we are looking for it to feel very loose, not springy. if your luck is bad you will hear and feel it freely clunck around as if the inner basket is coming loose. if this is the case then you will be looking at a very expensive repair. like $350 and up
levi
Lebarchrigen Appliance Repair
www.lartoday.com
Problems
with a washing machine not spinning or not draining are often inter
related..
If you are having a problem with your top load
washer then check out this tip...
Washing
Machine
does not Pump or Spin
If you are having problems with your
front load washing machine then checkout this tip...
Front
Load Washing
machine not draining and or not spinning
heatman101
