Question about Refrigerators
On September 26, 2009 we purchased a Frigidaire refrigerator, model FPHC2399KF. The temperature variation inside the refrigerator is 8 to 13 degrees. The middle shelf can read 32 degrees (with frozen food) and the top shelf 40 degrees when the controls are set to their lowest. When set at 38 degrees the middle shelf is 35 degrees and the upper shelf is an unsafe 47 degrees. We have had 4 service calls but no resolution.
  • 6,784 Answers
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control (diffuser) for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. WARNING: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. thsi will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, are controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
This will conclude the most common issue with a under preforming unit.
Posted on Nov 14, 2009
How can I deterine if there is a problem with refrigerator, and not the power line, when the 'Power Failure' alarm keeps going off?
Hi friend, that's a great question!
I understand that your refrigerator FPHC2399KF is consistently reading a power failure. It might possibly be an issue with the control board or with your power source. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair.-Matt
Jul 18, 2014 | Frigidaire Professional Series FPHC2399KF...
What should the freezer temps be on Frigidaire Galaxy models
Good Afternoon Friend,
I understand you want to know what the freezer temperature should be set on for your Frigidaire refrigerator, model# FGHB2844L. Per the manual, the suggested temperatures should be 37 degrees F for the refrigerator and 0 degrees F for the freezer. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
Refrigerator condensation inside
Whether on the outside of the cabinet or the inside it is because you have warm moist air hitting the coldness of the refrigeration. It can also happen if you put hot food into the cabinet.
Also at the back of the inside of the cabinet there is often a small drain that empties the water from the defrost cycles. Check that they are clear.
Feb 02, 2018 | Frigidaire Refrigerators
The Frigidaire Galaxy Series Model GLHS37EHSB6 is not cold. The temperature shows freezer at a temperature of 65 degrees and refrigerator at 77 degrees. I have lowered the temperature and it would beep and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 02, 2011 | Frigidaire Refrigerators
Frigidaire Professional 22.6 Cu. Ft. Counter-Depth Refrigerator - Model: FPHC2399KF I have ice that is collecting in the bottom of my freezer. My understanding is that this ice is caused by a buildup...
There is a chance that the drain hole is pluged or clogged with frozen ice.This can usually be cleared with hot water to melt the ice then dry off any remaining water with a towel.
the drain is located in the bottom rear of the freezer cabinet just behind the panel with the vent holes
Jul 06, 2010 | Frigidaire FPHC2399KF (226 cu ft) Side by...
My refridgerator keeps cycling on and off. temperature is50 degrees . where do i put r-134 in on high side at? thanks.
Hi katdaddy,
Welcome to fixya,
You said,
Your refrigerator keeps cycling on and off. temperature is50 degrees .
This means either you have a leak that must be detected befrore you re establish freon pressure or your thermostat is bad.
What is the model # and age of the refrigerator?
Sep 28, 2008 | Frigidaire Refrigerators
Temperature variation in freezer on Whirlpool ED22TQFXN
need your model number for unit reply but dont rare me till we are done get model num off serial plate in fridge
Jan 02, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
