Your washing machine could of had now died on you guys and is not working anymore.It would be cheaper just to buy a new washing machine than to repair the washing machine that is 10 years old now. The drain hose might be clogged or kinked or lid switch or the belt is not working in your washing machine.
HI it may be that the fuse in the plug has gone, sometimes this can happen and its the last place you would look, sometimes the cable wire in the plug has come loose please only do this if you are Shure of what you are doing I hope this helps cheers eric
it seems the washer's inlet solenoid isn't responding to the diagnostic computer on the washer and needs of replacement contact samsung to have it serviced
1. No AC
2. Blown house or machine fuse.
3. Bad AC cord.
4. Bad on/off switch.
5. Bad Timer.
6.Broken Belt or Gear.
7. Bad Motor.
8. Clogged pump.
9. And more
If you can't find the problem Get professional service or replace it!
I have a problem with the Samsung WA80U3 washing machine. The safety stop button is activated and I cannot cancel it even though I tried to press the water level + function for more than 5 seconds and there is no solution. Please help.
