Question about Garden
How do we service the blade / brake clutch assembly on John Deere 14SB lawn mower .
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 197 Answers
No serviceable parts,you can only buy complete clutch.To replace you remove blade and blade adapter.Use a very large vise-grip to remove spring and then you can remove bolt holding clutch arm.Disconnect cable from top side of machine.Remove engine mounting bolts,have another person pull engine away from frame while you slide clutch off.Going back together you may have a tuff time getting large spring back on hook under deck.I've been working on these for some time and have yet found an easy way to get large spring back on.
Posted on Nov 15, 2009
Will not change speed... keep as one speed.
Posted on Oct 08, 2013
John deere d140 lawn mower shoots of when i ingage the blades
Here's the link and I'm sure you will get the solution of your problem.
JOHN DEERE D140 SERVICE REPAIR MANUAL
May 04, 2017 | John Deere Garden
Why does one blade spin after mower is stopped on my John Deere LA135?
check your blade brake for that blade,supposed to rub against top blade pulley when blades are disengaged,if its a manual engage vs electric clutch
Jul 30, 2014 | John Deere Garden
How do you replace the clutch on John Deere 14sb walk-behind mower
I dont know if this is servicable.you may have to chuck it out and buy a new one. phone a small engine lawn mover repair shop and get a expert oponion
Jul 15, 2014 | Garden
My john deere 14sb mower starts but kills when I engage the blade
Check your safety seat switch. Unplug the wiring harness to the switch and place a paper clip into the harness. This will bypass the switch unless you have a continuity tester to test the switch.
Aug 07, 2013 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
My 1979 111 john deere lawn tractor deck blades shut off
If it has a clutch, that would be the problem. An electric clutch will kick on and off when it is hot if it is bad.
Sep 27, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Aug 10, 2009 | John Deere Mower Blade 5 each
John Deere 14SB (with Kawasaki FC150V motor). It
sounds like the valve clearences need adjusting they should be set at 0.004 thou you should be able to find an exploded view at pats small engines site.
Aug 09, 2009 | Garden
Blade wont stay engaged john deere 14 sb mower is 20 years old i have not replaced the belt could this be the problem
I have a john deere 14sb lawn mower that will start and run for about one minute and die wont start again until later.
Jul 01, 2009 | Garden
John deere model 14sb lawn mower repair
Check for bad bearing in clutch immediately, Remove belt, try and turn the clutch pulley if it is hard to turn or feels rough, replace the bearing in the clutch. If you do not replace bearing immediately you will be buying a $300.00 clutch very soon. I know from experience. You possibly have been hearing a loud unusual roar from engine area for awhile and wondered where it was coming from. As these bearing will usually squall a cry for awhile before they die.
Mar 28, 2009 | Garden
Garden Logo
1,143 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
