Question about Indesit WA 115 Front Load Washer
How to cancel drying?
How to cancel drying programm? I opened the door before the programm finished as this took ages. Now I had too wash more clothes and washing machine continues to dry instead of start new washing program.
    Genius:
  • 1,044 Answers
Please press the reset switch which should be on the control panel or next to the loading door
Posted on Nov 14, 2009
Testimonial: "it works!! thanks"
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
My wash/dry cycle has finished but I can't open the door. Is there a manual release please?
turn the dial and listen for a click to release the door. no their is no manual release
Jan 06, 2015 | Electrolux Washing Machines
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
Fisher & Paykel dryer DE60F60EW1 has suddenly stopped working when I tried to change the program. How do I reset the machine
Here are a couple of possible reasons it stopped and solutions from the manual.
Adding/removing laundry in standby mode
If you want to add or remove laundry into/from your machine after the drying programme has
started, put the machine into Pause mode by pressing the START/PAUSE/CANCEL button. The
drying process will stop. Open the door at Pause position and close it again after adding or
removing laundry. Press START/PAUSE/CANCEL button to start the programme.
Any laundry added after the drying process was started may cause the already dried clothes in
the machine to intermingle with wet clothes and the result will be wet laundry after the drying
process is over.
It is not recommended to add laundry after the programme is started as it will increase the
programme time and energy consumption.
Childproof lock
There is a childproof lock to prevent any programme interruption due to the pressing of keys
while the programme is on. The loading door and all keys except the ON/OFF key on the panel are
deactivated when the childproof lock is active.
In order to activate the childproof lock, press on the StARt/PAUSe/CANCel and BUzzeR CANCel
buttons simultaneously for 3 seconds.
Fig.6 Using the
childproof lock
To start a new programme after the programme is over or to interrupt the
programme, the childproof lock should be deactivated.
To deactivate the childproof lock, press the same buttons for 3 seconds.
Two beeps will sound when the childproof lock is activated. A single beep
will sound when the lock is deactivated.
I was able to view the manual by a Google search and the third item on the Google search list was the manual, but it would only come up by selecting "quick view", otherwise it would crash the Acrobat reader plugin.
Jun 03, 2012 | Toys
Smells musty and not washing clothes well
"In washing in the HE washers I think that if you have more than 3 loads a week you should maybe wash your washer at least once a week. I have started wiping the door off and leaving it open between washing and that helps a
lot with the smell.
This is why I think if you could wash the washer once a week it would probably do better. You never had this problem in the old washers." Try this in your washer.
Dec 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to release child lock in seimens washing machine that is wash and dry D12-52 1200 rpm
Child lock will deactivate only in the original programme that it was activated in. If you have forgotten the orginal programme, try deactivating separately in each programme.
To deactivate child lock press the clock key for 5 seconds.
Nov 07, 2010 | Siemens WFXD8400UC Front Load Washer
When my bosch washing machine is finished its wash programme the clothes are very hot when I open the door
this sound like another thermostat problem its trying to boile every thing,,,change the thermostat first
Oct 23, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
The door on my indesit wd12x washer dryer will not open. The machine has finished the cycle and was on the tumble dry mode when it finished. The handle feels loose like a spring has sprung. Any...
slide in a piece of string around the door. if lock is on the right, pull round the door til the pieces of string are at left of the door and pull left quite firmly.
Oct 17, 2008 | Washing Machines
Beko WMA 1715s - won't respond
door lock switch could be your problem..
Aug 30, 2008 | Whirlpool LCR5232H Top Load Washer
Open Questions:
See all Indesit WA 115 Front Load Washer Questions
Indesit WA 115 Front Load Washer Logo
173 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
