Question about Acer TravelMate 4200 Notebook
How do you reconnect the touchpad - Acer TravelMate 4200 Notebook
  • RW Goebel May 11, 2010
    How did it become disconnected?
  • Ralph Holmes
    Ralph Holmes Nov 09, 2017
    Tried to install a wireless mouse unsuccessfully and in the process turned off the pad control
  • 51 Answers
If you have a wired mouse around, you can plug that in, and use it to navigate to the control panel. In Mouse settings, you can re-enable touchpad.
Alternatively, some of the Travelmates have a keyboard shortcut to enable touchpad, Function-F7.
I hope one of these solutions helps!
Posted on Nov 09, 2017
What does eroor E6 Mean
The E6-F2 error code indicates a problem with the touchpad or the electronic oven control. E6-F2 specifically means the cancel key drive line is open. You can't cancel this error code, but sometimes removing the power from the oven and reconnecting it will cure it.This is usually a fault in the touchpad, but can also be caused by the electronic oven control. To test the oven you would need to remove the control panel and disconnect the ribbon connector from the touchpad to the oven control at the oven control. Clean the end of the ribbon and reconnect it. This will sometimes correct the problem by curing a weak connection. If the error code comes back you should replace the control panel which contains the touchpad. 8300427- black
8300428- white
8300516- biscuit
The part number for the electronic oven control is 8302319.
Apr 29, 2014 | Heating & Cooling
Fix toshiba touchpad
what's wrong with it?
May 10, 2012 | Computers & Internet
Display says E2 and F1
Hello there:
The F1 Error On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
  1. Disconnect the power
  2. Gain access to the back of the ERC
  3. Disconnect the ribbon cable that connects the ERC to the touchpad
  4. Check nothing will short when power is reconnected
  5. reconnect the power and switch on
  6. Watch for F1 and listen for the beep
  7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
  8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
Now as far as the f2 this is regarding the temperature sensor that is possiably bad once you have the f-1 corrected this other code may go away but if it doesent then you will need to replace the temperature sensor of the oven ok
Nov 20, 2010 | Whirlpool GS445LELS Gas Kitchen Range
Touchpad stopped working when a friend openned the laptop to fix the DC power pin. reinstalled driver, power cycled, disabled and enabled touchpad, still only works with mouse. keyboard works fine
Most probably, your friend disconnected the cable connecting the touchpad to the motherboard while disassembling the laptop to fix the DC power pin, & forgot to reconnect it back.
You will need to partially disassemble the laptop again & reconnect the touchpad to the motherboard.
Nov 13, 2010 | Toshiba Satellite A60 Notebook
What is an F1-8 Error?
Hello there
First your f-1 error code
And the 8 error is also conclusive along with the f-1 meaning that the erc or electronic range controle is faulty and should be replaced
Oct 12, 2010 | Maytag MER6772 Gemini Electric Kitchen...
What is f1 code
The F1 ErrorOn a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
Feb 18, 2010 | Kitchen Ranges
When using some of the programs such as MS-EXCEL, the mouse pointer behaves as it has a mind of it's own. It starts jumping up and down and behaves erratically not allowing the control using touchpad. I...
first, try cleaning the touchpad WELL with a cloth damp with windex. If still no good, you should try to remove the keyboard, disconnect and reconnect the touchpad cable that goes to the mainboard.
hope this helps
Mar 09, 2009 | Computers & Internet
F1 fault code on Jenn-Air jwg 8130
hi,
or follow the link for more info:
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-ranges.html#Admiral
thanks for your question.
Jan 03, 2009 | Jenn-Air JGW8130DD Gas Single Oven
HP NC6400 touchpad
Hi i am an ex HP employee
here are the steps
Remove the TouchPad Assembly
  1. Remove the T8-9 mm screw that secures the TouchPad assembly to the base enclosure.
  2. Turn the notebook right side up and open the display panel fully.
  3. Lift the rear edge of the TouchPad assembly and remove it from the top cover.
  4. Disconnect the TouchPad cable from the system board.
  5. Remove the TouchPad assembly from the notebook.
Replace the the TouchPad Assembly
  1. Place the TouchPad assembly over the palm rest.
  2. Reconnect the TouchPad cable to the system board.
  3. Toe the front edge of the TouchPad assembly into the top cover and lower the rear edge into position until it snaps into place.
  4. Close the display panel and turn the notebook upside down.
  5. Replace the T8-9 mm screw that secures the TouchPad assembly to the base enclosure.
I hope it works out
Jun 04, 2008 | HP Compaq NC6400 Business Notebook
Acer TravelMate 4200 Notebook Logo
253 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
