Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Liftmaster mod 1245R (1999) has indicator light blinks 5 times. Door will not operate from hardwire button. Tried unplugging unit to reset but same 5 blink sequence returned. Held button in to reset but no difference. Only get clicking sound at control unit when hard-wire button pushed. Need help! Thanks.
  • 1 more comment
  • daviapc Nov 15, 2009
    Don, Thanks for help but door was not in open position. It was unattached to trolley that was in the full down position. The chain seemed tight when I connected the door to the trolley so I loosened the lock nuts and took some tension off the chain. Tried turning the travel controls and pressure controls to see it would operate but it only clicks when hard-wire button pushed. Thanks, Paul
  • daviapc Dec 31, 2009
    Thanks.
    Problem solved by replacing logic board that was zapped by lighning surge. Door was down when zapped, so trolley was at full door closed position. Logic board red/amber light would only blink 5 times and click when wall button or remote pushed. Attempts at resetting unit and jumping terminals as directed by mfgr did nothing leading to conclusion that logic board was likely fried. I Replaced logic board and opener worked like new. Suggestion for future: If any opener unit conks out while door is in full down position, strong suspicion should always be lightning or power surge damage to logic board and not replacement of the motor as I kept being told by FixYa Gurus. Best regards, Paul
  • marty metzger May 11, 2010
    Have no idea what you are saying. "get clicking at control unit". What is Control Unit? What indicator blinks 5 times; wall control, logic board led or saftey beam?
    President:
  • 3,197 Answers
If your door is in the open position and the trolley is jammed against the bolt just in front of the motor unit you need to remove the bolt and then run the opener until the door closes. While the door is closed locate the 'up limit control' on the side of the motor unit and turn the control a couple complete turns in the opposite direction of the arrow printed on the cover.
Posted on Nov 14, 2009
  • Don Maggard Nov 14, 2009
    Post back if you have problems
  • Don Maggard Jan 27, 2010
    Check the trolley.
  • 504 Answers
IF THE MOTOR MOVES 6-8" REPLACE THE RPM SENSOR. IF THE MOTOR DOESN'T MOVE AT ALL (AND IS NOT OVERHEATED) REPLACE THE CIRCUIT BOARD.
Posted on May 28, 2010
2 Suggested Answers
  • 3197 Answers
SOURCE: Liftmaster mod 1245R (1999) has indicator light
The trolley is most likely jammed against the bolt just in front of the motor unit. Remove the bolt and then run the door until it is closed. Now locate the 'up limit' control on the side of the motor unit. Turn this 2 complete turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Posted on Dec 07, 2009
Liftmaster mod 1245R (1999) has indicator light blinks 5 times. Door will not operate from hardwire button. Tried unplugging unit to reset but same 5 blink sequence returned. Held button in to reset but no...
Dec 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster mod 1245R (1999) has indicator lightLiftmaster mod 1245R (1999) has indicator light blinks 5 times. Door will not operate from hardwire button. Tried unplugging unit to reset but same 5 blink...
The LED flashing 5 times is the code for "RPM sensor or motor overload". Usually if it is the RPM sensor - which is a small printed circuit board just in front of the motor - it will run a few inches and then reverse. I doubt very much it is the motor. I would pull the logic board and check for loose or missing traces on the printed circuit. Especially if you have had any electrical storms or power surges.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
No response to remote on Liftmaster 1/3 HP model # 1245R
It has probablly lost sync.
Follow the procedure to reload the codes. One usually has to hit a reset button on the head and then follow a sequence to sync your remote to the head.
Sep 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage opener not responding with remotes, keyless pad, or wall console. Can hear it click but nothing happens. Green light in opener blinks 5 times. When i reset the green light stays on until i try to...
UNPLUG UNIT TO RESET.
IF IT STILL FLASHES 5 TIMES AND MOVES 6-8 INCHES REPLACE RPM SENSOR.
IF IT STILL FLASHES 5 TIMES AND DOESN'T MOVE REPLACE LOGIC BOARD.
Apr 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener Clicks only and LED blinking 5 times
Just fixed this problem tonight. Had the 5 blink/flash thing. Opened it up and saw that the motor wasn't spinning so it wasn't a bad rpm sensor. Jumped the red to black and then the blue to black to verify motor worked. At that point assumed it was the logic board not telling the motor to start, but I could hear the click of the relay. Pulled the logic board out and noticed a solder joint that had failed directly behind one of the relays. Resoldered that joint and the garage door opener worked again like a dream. Hope that helps someone else.
Feb 28, 2009 | Building Materials
Craftsman Garage door opener not working
First, check the springs in the actual door to make sure that they are not broke. Since you held the learn button down to reset the opener, you have to reprogram all of your remotes. This button only resets the remotes. It has nothing to do with the rest of the opener. To reset the opener, simply unplug it for a couple of minutes and then plug back in. Pull the handle on the door and see if you can operate the door manually with one hand. If it takes more than 15lbs to move the door, there is a problem with the door balance. If the springs are not broke and the door operates smoothly, the likely cause is the rpm sensor on the opener.
Feb 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opener moves foward about 10 inches then returns
UNPLUG THE UNIT FOR ABOUT 5 MIN. TO RESET TRY TO OPERATE IF IT STILL MOVES 6-8 INCHES AND FLASHES 5 TIMES THE RPM SENSOR IS YOUR PROBLEM - COULD JUST BE THE CUP HAS MOVED ON THE SHAFT. IF IT IS IN PLACE AND STILL NOT WORKING REPLACE THE PICKUP.
Dec 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Raynor 1245rgd navigator learn button blinks
5 flashes on operator and the short movement on the door indicates a bad RPM sensor. try to unplug the unit for 30 seconds, if this does not reset the motor, replace the RPM sensor
Dec 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Trouble changing passwordon model 940CB wireless keyless entry
easyer then that , you die! Open your garage door, take out the step ladder, a chair or get up on *********** in law's back, (here's your chance to be on her back for a change) press the read button of your unit (motor) a led should light up and on the key pad, key in the new 4 digits code and press enter, the light of the unit should blink javascript:; Post Solution
May 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
969 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
