Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE XL44 True Temp F2 warning
On occasion my XL44 beeps and flashes a F2 warning when I use the oven. The only way to stop it of course is to shut it off for a while and then turn it back on and hope it won't flash F2 and beep till my dinner is done. It also seems not to heat up that well any more either.
  • 1 more comment
  • Chef Angie Jan 11, 2008
    I had the same thing happen tonight. It was set for 350 degrees; was baking a cake; all of a sudden I see smoke bellowing out of the oven and the F2 is flashing; fire alarms going off all over. The only way I could turn off was to cut the circuit breaker. I couldn't even turn the oven off - it kept going.
    What to do?
  • Nancy00 Mar 30, 2008
    I'm having the same problem sometimes it flashes F2 and other times it flashes F4. I don't have the manual for this stove because it was already installed in the house we bought. So I'm wondering if this is something bad and I should replace the stove or if it's just a little problem I can fix on my own. I have tried pushing all the buttons and nothing works but turning the stove off and back on again. Which totally sucks if you are making a pot roast and have to have the stove on for 3-4 hrs. I probably get up and turn it off and on about 5-6 times. grrr.... So now I'm online surfing the stove to see if I can find the answer to how to stop it from doing that.
  • Anonymous Dec 06, 2008
    Mine did this for the first time tonight...I turned in on broil, microwaved my enchilladas for a couple minutes, broiled them for a couple minutes and turned the oven back on and it seemed to start heating up again...
I had the exact problem with F2 . I had to have the computer chip replaced. I do not know how much that would cost. We live in Military housing and they took care of it. I hope this helps.
Posted on May 22, 2008
My ge xl44 gas range, installed in 2000, turns off and flashes an f2 code occasionally. Can you give me the reason?
F2 means: For an unknown reason, the oven temperature has exceeded a preset threshold.
G.E. recommends you try this:
Sometimes shutting off the circuit breaker that the range or oven is connected to for 30 seconds will clear the fault, error or function code, however there are some cases when further service may be required. If you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737
Here is the fault code guide link:
http://www.geappliances.com/search/fast/infobase/10009792.htm
May 20, 2010 | GE Kitchen Ranges
Describe your GE Profile Spectra XL44 Oven
My GE Profile Convection Microwave Oven will beep and display a F2 for no apparent reason. What is this?
Mar 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE XL True Temp gas range/oven. None of
your stove must be plugged in for the auto-pilot to work .do you hear a ticking noise when you turn on a burner?
Oct 07, 2009 | GE JGBP28 Gas Kitchen Range
Flashing F2 warning
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Aug 18, 2009 | Ovens
F2 error
F2 is a bad temp sensor, needs to be replaced.
Jun 23, 2009 | GE JKS06BFBB Electric Single Oven
GE true temp oven f2
This happens every time I clean my oven. It overheats, shows the f2 light and BEEPS loudly. The only way to stop it is to turn the oven off at the breaker box, wait until it cools (usually 2-3 hours), flip the breaker back on and start the process all over again until the unit is clean. If it's not to dirty, sometimes it's easier to juat use Easy Off.
hope it helped
Jan 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge gas oven/ranger xl44
The F2 is the code for the board seeing a temp higher than 600 degrees. It could be one of two things. The temp sensor is out of range, extreme high resistance. If you ohm it out it should read approx 1100 ohms at room temp. The other would be a welded bake relay on the board itself. Check the temp sensor first. If you are getting the F2 in the cleaning cycle, check the temp sensor, welded clean cycle contacts on the board or both contacts on the lock switch are closed at the same time. This is for the model posted JGBP90.
Nov 24, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
F2 Error
Traci, F2 is the error code for a overtemp in the oven compartment. It could be two things. The oven temp. sensor or the main board itself. Start with the temperature sensor. It should ohm out at 1080 ohms at room temp. This of course is the least expensive and probably your problem. The temp sensor is the probe that is in the back wall of the oven. It will remove from the front with two screws. There will be a harness that you can disconnect it from when pulling it out. Some one can ohm it out there. The other possibility is welded relay contacts on the main board. Let's hope it's the sensor. Part number WB21T10007. Catriver..post back.
Feb 12, 2007 | GE Profile JB968 Electric Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
1,845 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
