Question about Toshiba TDP-S81U DLP Projector with Document Camera (TDP-S81U DLP, TDPS81UDLP, TDPS81U-DLP) Multimedia Projector
I have a dataprojector, no signal
I have a dataprojector, a toshiba i plugged it all in to my computer but it tells me theres no signal
Then 'No signal' or 'unsupported signal' messages are usually because your display is set too high. To see if this is your issue, hoop it back up too your computer & set the computer to the basic VGA resolution. Assuming you are using windows, right click a blank area on the desktop, click 'properties' on the dropdown menu, click settings. Write down the numbers in the 'screen resolution' and 'color quality' boxes, then drag the 'screen resolution' all the way down to then 'less' side. Then change the 'color quality' to the lowest setting. Click apply, then answer yes (the display will look UGLY - don't worry!!) Now connect your computer back to your projector. If it works, then the resolution you use on your desktop monitor is not supported on your projector. Experiment with different resolutions to see which one looks best on your projector.
Note for Laptop users-- By default the VGA connector on your laptop is off. To turn it on, look for a blue symbol on one of your function (F1, F2, F3...) keys. It looks like an old TV with a line on both sides 'O' (F4 on HP) Press & hold the blue <fn> button (on the lower left of the keyboard, usually to the left of control <crtl>) and tap the bleu button you just found. Let go & give you
Posted on Jun 12, 2011
Toshiba 19HV10E won't turn on
More information is needed:
Are the power on?
Are the power cable lose on the back side?
Are the power cable plugged into a socket?
Are there any lights indicating that it receives power?
If you switch it off and then on on the monitor itself, without a connected computer turned on, do you see a logo from Toshiba and then some text indicating no signal is received?
Sep 16, 2015 | Toshiba Computers & Internet
Hi, I am trying to connect my Dell computer to the Acer dataprojector, but it says searching.... as if t does not see the computer. I have switched them both off, restarted the projectro then the computer,...
Have you tried replacing the cable (sorry I have to ask). Make sure the Dell (model would be helpful) is sending the video out the video port (FN+F8 are the usual keys to press). Also try right click on your desktop and check your Graphics Options.
Dec 15, 2014 | Dell Office Equipment & Supplies
I own a Toshiba NB 205 Notebook PC. I connected my flat screen TV to the notebook so I can use the TV as the Toshiba's monitor. I purchased a male-to-male VGA cable and plugged it into the VGA port on...
you need to tell the computer to move the signal over ---look for a picture of 2 tv screens on the laptop usually F5 or F8 (use with Fn key)otherwise right click on the desktop>choose PROPERTIES>SETTINGS
Jan 01, 2011 | Toshiba Computers & Internet
My Toshiba television Model 13A23 is not working. There is no horizontal signal from Video Chroma Ic but the B+ voltage is present. Can you tell what can be cause of this problem?
pls check the jungle IC it genarate the horizontal signal croma ic used that signal may be failure in horizontal oscllator section
Aug 24, 2010 | Toshiba 13A23 13" TV
Problem just started. Getting na signal on TV.
1. Remove the video/display cable from both TV & Laptop.
2. Again Connect the two devices properly.
3. Press "Function Key+F5" to connect to the TV (External Display)
4. Also put your TV in "TV/AV" mode.
tell me if it don't helps...tc! :)
Jan 05, 2010 | Toshiba Laptop Computer Battery PA2510,...
"No signal" even though connected to computer
You probably have to tell the laptop to send a video signal to an external display--(i.e. <altF4 or <altF8) The proper function key will have a TV screen symbol on it. Default mode is "laptop only" By pressing and holding the alt, then pressing the appropriate function key, the laptop will switch to the next mode, laptop/external display. The last mode is external display only. By pressing the sequence again, you'll return to "laptop only" mode.
Sep 08, 2009 | Toshiba TDP-SP1 DLP Projector
My Toshiba TLP-XD2000 projector reads "unsupported signal" when it is plugged in to my Dell Inspiron 600m laptop. It has worked for about 8 months perfectly and then when I plugged it into another computer...
reset the settings to factory default. when you plugged it into the 2nd computer, it searched for matching resolution, to no avail. when you put it back with yours, it was on the default setting.
Jun 23, 2009 | Toshiba TLP S30 Multimedia Projector
Toshiba televsion is saying digital channel signal strenth is low
if you're using antenna, (most likely)you need to adjust your antenna to where it picks up the best signal. The picture comes in clear with good audio and doesn't pixelate often.
Feb 06, 2009 | Toshiba MD14FP1 14 in. TV/DVD Combo
Wirless radio switch for Toshiba 1410 S173
If it ain't the WiFi Antenna on switch (right side, towards the front), then it's an incompatible WiFi card (assuming it's just been added to the system).
Nov 26, 2008 | Toshiba Satellite 15" Flat Panel LCD...
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
301 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
