Question about Dirt Devil Breeze Bagless VacuumVacuum
My vacum will not pick up dirt and it is smoking a little from the bottom.
  • 715 Answers
Siunds like the beater bar has seized take bottom off and check belt and brush
Posted on Nov 14, 2009
My vacum cleaner won't pick when attached to the parts or bottom
Hi, it's Allie from Crucial Vacuum.
It sounds like your unit may have a blockage. Checking your hose for any blockages is very easy. Remove the hose from both ends and check for blockages, any leftover debris or clog will not allow the unit to have suction.
You can purchase direct your replacement belts, filters and rollerbrush from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dirt-devil-f1-kit.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Sep 04, 2014 | Dirt Devil Breeze Bagless Cyclonic Upright...
How to replace vacum belt on new Sharp EC-TU5306
remove bottom plate and pull brush roll out. buy a replacement belt and follow procedure to put back on. sounds like you have a clogged hose also.
Jan 29, 2013 | Sharp EC-TU5306 Bagged Upright Vacuum
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
c...
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
Eureka Maxima 12 amp vaccum cleaner is not picking what can be done to make it pick up?
remove and clean the filter ( tap and brush filter or use a air compressor to blow out filter ) --- also check the vacume hose near the floor attachment for any dirt and debris that may be clogging the line. this should bring your vacume to full operation.
c...
Jan 22, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
It wont pick up dirt and motor is very loud it was clogged but cleared it still loud belt is fine
check impeller that is the part that creates the suction in a vacum if impeller is broke that will make the vacum loud and vibrate
Oct 17, 2009 | Bissell 3910 Bagless Upright Cyclonic...
I recently ( approx. 2-3 months ago ) purchased a dirt devil. Now it is not picking up properly. When I push vacuum forward it picks dirt up a little bit, when I pull it back all the dirt falls out of...
Hi sounds like your line is stopped up somewhere , check ur suction an make sure your brushes are spinning, if they are try a wire clothes hanger to the hose at the bottom hose to dislodge anything that mite be stuck
Jul 01, 2009 | Dirt Devil Vacuums
The vaccum doesn't pick up dirt, it sprays out
There is probably a second or third filter (besides the canister) that needs to be cleaned.
I doubt that it's rotating the wrong direction.
Apr 25, 2009 | Dirt Devil M084600 Dynamite Bagless...
Vacum not sucking the dirt and the light is not turning on
loss of vaccum brush head not spinning check belt turn over remove bottem plate check belt assmble. remove any string or hair build up sear is the best bet for the belt
Mar 31, 2009 | Kenmore 34923 / 34925 Progressive Bagged...
Bissell turbo revolution
you can wash that sponge filter by hand but you must let it dry compleatly before putting it back in the machine, I found a filter pack for the lift off vacume at walmart, make sure teh bottom filter is clean as well. the lift off vacume has 3 filters there is one filter in the tray under the dirt cup, one in the top cup, and the hepa filter in the back the 2 foam filters must be clean or you can have reduced suction, the lift off vacume I have I found thrown away because they never cleaned it outthe brush was dirty and full of strings the belt was worn, the hose under the vacume was full and stopped up the hose in the back was compleatly stopped up all filters were compleatly clogged, and the hepa filter was missing entirely. Not to insult you or anyone but i've found that a lot of people are jsut to lazy to clean their vacume out it fills up with dirt they throw it away and get a new one, i've gottten many like new vacumes for this reason, this bissell is working like brand new now. and I just replaced the belt and all filters in it saving me approx. 150.00 for a new one
Dec 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Dirt Devil Vibe No Suction
Sounds like there is a clog somwhere. Check the hose - you can undo the hose with a screwdriver but because of that bend use a pipe cleaner or a long wire to see if there is anything blocking the tube. Next check the dirt channels from the bottom of the hose on the Dirt Devil Vibe once the hose has been taken off. Check that the bottom part is clear and then tip the machine over, remove the bottom sole plate (4 screws, 2 at the front and 2 at the back near the rear wheels) to check the roller brush - sometimes if there is an obstruction in the dirt channel from the roller brush suction will not get through.
Dont forget however that there are two filters on the Dirt Devil Vibe. The top filter has to be unscrewed and then unlocked. Tap it a couple of times to dislodge any dirt and then lift out the second part filter at the top of the bin.
Dont forget to rate if this advice works. Thanks.
Jul 30, 2008 | Windsor SR12 Sensor Bagged Upright Vacuum
Dirt Devil Breeze Bagless VacuumVacuum Logo
233 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
