Question about Hotpoint WMA30 Front Load Washer
Replace Belt Om WMA30 Washer
The belt has slipped off the washer, can anyone offer full instructions on how to refit it please?
  • wishwash Jan 09, 2008
    This will probably work but for some reason the drum wont turn so i can't walk it on to the fly wheel.
    Any possible reason why this may be happening?
    Thanks
  • 139 Answers
Yeh
If you pull out the machine from where ever it is... then feel around the top on the sides of the machine two oblong small screw covers.. remove the covers remove the star shaped screws. and lift the top up from the front side of the machine and push back and it will come off..
remove the little panel at the back 4 screws. you do this so you can adjust the belt to sit on the last grooves on the motor pulley..
Now to get the belt you have to do it from the top if your doing it alone.. So from the top of the machine you lower the belt donw and onto the motor pulley then you put the belt on the fly wheel and turn it so as it walks on the flywheel...
rember pulley first then walk it on the flywheel and remember to adjust on the pulley so it sits on the grroves nearest to you not the motor
Posted on Jan 08, 2008
  • Shaf Ahmed Jan 10, 2008
    Yes your bearings have gone on the machine and need replacing check my other post for full instruction on how to rep[lace the bearing
How do I replace the belt?
pull it out about a foot or two away from back wall and just tip it backwards. remove two bolts holding belt guard off and slip belt off and new one back on.
Oct 13, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
We put a heavy blanket in the washer and the load stopped suddenly with a washer full of water. It wouldn't spin or empty and made a weak sound but nothing worked. We had to manually empty the water....
Usually that means the drive belt is loose and slipping. You should be able to tighten or replace the belt.
To test the belt you have to remove the washer back.
Jul 29, 2011 | Kenmore Washing Machines
My washer wont spin or agitate and there was a burning smell
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Hope this helps... Please post back if you need more information.
Daniel
Jan 30, 2011 | Kenmore 24032\24036 Top Load Washer
I have a maytag washer, toploader which was working fine until recently. Now when it starts rotating, there is a burning smell all in the area. What causes it?
Hi
Your washer uses a belt to transfer the power to the tub from the motor. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer.
Remove the old belt & remove the bolt holding motor. Now remove the motor, remove & replace the plastic isolators with the new ones supplied with the belt on the motor spindles. After re-installing the motor & bolt adjust the new belt.
Please post back for any further assistance.
Daniel
Jul 31, 2010 | Maytag Dependable Clean Top Load Washer,...
My neptune washer smells like rubber burning when i wash clothes
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer.
The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer. Remove the old belt & remove the bolt holding motor. Now remove the motor, remove & replace the 2 plastic isolators with the new ones supplied with the belt on the motor spindles. After re-installing the motor & bolt adjust the new belt.
Daniel
Jul 26, 2010 | Maytag Neptune MAH6500A Front Load Washer
Load was to heavy and I smelt burnt rubber now no spin
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
Please check this diagram for the part number F28(drive belt)--
Thanks
Daniel
Jul 24, 2010 | Frigidaire FWS833A Top Load Washer
Maytag washer lat9416aaq belt slips in spin cycle put new belt on and springs
The motor is supossed to walk up the belt to let it slip enough so the pump can run and drain out the water before the drum spins at full speed( that's why it's spring mounted).
Check the pump belt, it should be snug but not tight, you should have some give when you squeeze the belt together, but it should not touch together. Don't use any belt dressing on it, it needs to slip. Make sure the washer is unpluged before you do anything.
Feb 05, 2010 | Maytag Washing Machines
Is the motor supposed to not be fixed to tension
The motor is spring loaded to keep tention on the belt. The belt is designed to slip. When the washer is full of water the motor starts at 1725 RPM and the belt is a little loose. As the drum empties its water the belt gets tighter and the speed picks up to spin the water out of the cloths. If the cloths are not comming out as dry as they should, replace the belt. As the belt starts to wear it becomes shiny and doesn't grip the pully properly and slips too much.
I hope this helps.
Jan 03, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Fitting new belt
Remove top cover and lower rear panel of washer
With some help, tilt washer forward, and fit belt round motor pulley first,slowly ease belt onto drum pulley and feed slowly round, turning pulley at same time, it will be very tight, so watch your fingers, you can align the belt after it is fitted. Please rate my solution.
Thanks.
Aug 19, 2009 | Washing Machines
Replace belt wma64
Remove top cover, tilt m/c towards you, this gives you more space to work in, and slip belt over motor pulley first, then gradually ease belt over drum pulley turning the drum with the belt,until it is on.
Keep your fingers from getting trapped as the belt is very tight
Sep 15, 2008 | Hotpoint WMA64 Front Load Washer
Hotpoint WMA30 Front Load Washer Logo
164 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
