Question about HP PSC 1410 All-In-One InkJet Printer
Printer cannot print due to no communication with pc
    Master:
  • HP Master
  • 956 Answers
No prod.
First make sure connectors are have not been slightly removed?
ensure printer cable is located in bothj printer and rear of your poota?
Make sure power cables are all located.
Then if all checks are OK. The quickest ans is "Remove Printer Prog" then "Reinstall". if plug play, restart poota, let poota locate from auto load.
If not then reinstall from your printer setup disc?
Hope all is then fine.
Posted on Nov 14, 2009
Datamax s class printer not communicating with pc
1. Try to get a test page printed from the printer directly through the printer panel.
2.1 Check for the cable connector's both ends securly fitted to the PC and the printer.
2.2 Reboot the printer and the PC and check printing the test page.
3.1 Try swaping the connector with any spare from other printers.
3.2 Reboot the printer and the PC and check printing the test page.
3. Try Calling the Sevice Eng. or the Tech Support of the Printer.
Jun 09, 2012 | Datamax S-Class Thermal Printer
Not communicating with computer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Dec 22, 2011 | Lexmark X1240 All-In-One InkJet Printer
I have a wireless Z2420 printer and it will not print off my computer??? it was printing yesterday
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, try to print again to verify that the communication is back.
Nov 02, 2011 | Lexmark Z2420 Printer
My printer is giving me this error message "Batch
That's a batch error, more than likely due to a communication issue between the pc and the printer. If you reboot the printer, THEN reboot the pc you should clear that error.
This error sometimes occurs when the printer has been shut down whil logged into your software, which disables communications between pc and printer. The error indicates that the printer didn't receive enough data to properly print the batch of labels/tags.
Sep 14, 2011 | Paxar Monarch 9825 Thermal Label Printer
I have a lexmark 3500-4500 printer.it,s not scan.how can i solve this problem? Download: eType1.com/f.php?FNmVjz
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/e8EeXn. Type your model number, select your operating system, download and execute the file.
Scan communication problems could also be due to firewall issues. Make sure to allow full access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
Sep 13, 2011 | Lexmark X5470 All-In-One InkJet Printer
Hi - my x4550 lexmark printer wont print, can you help?
If your printer won't print when you're making a copy using the Copy button on the operator panel, it could be due to your ink cartridges. Try to re-seat your ink cartridges into the printer and make sure they are properly seated.
If you're not able to print from your computer, it could be a communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if usb-connected), reboot your computer and unplug/replug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Try to print again.
You may refer to this article for Wi-Fi connection issues: How to identify a Wireless Communication Problem and Resolution Tips
Aug 11, 2011 | Lexmark X4550 Multifunction Wireless Color...
My printer wont print at all
Are you able to make a copy using the copy button on the printer operator panel? If not, try to reseat your cartridges into the cartridge carrier. If yes, then the problem could be due to a communication failure between the printer and your computer.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Disconnect the printer from your computer. Reboot your computer. Unplug and re-plug your printer into the power source to reset it. When the printer turns on, reconnect it your computer. Try to print again.
You can also try to re-install the printer driver on your computer to repair any possible corrupted files necessary for printer communication and processes.
Jun 15, 2011 | Lexmark X1270 All-In-One InkJet Printer
My printer is paused and I can't get it to unpause.
Here are the problems due to which a printer gets stuck in pause and ways to fix it:
* Problems
* Reinstall drivers
* Verify Print Spooler service
Problems
There are several problems due to which your printer gets stuck in pause. Driver issues are considered to be one of the major problems as they allow printers to communicate with the Operating System of your PC. When there are problems with Print Spooler, your printer can get stuck in pause.
Reinstall drivers
In order to resolve the problems that occur when your printer get stuck in pause, as a first step, you will have to disconnect the printer and delete the printer from Device Manager. An outdated printer driver will also cause certain problems. Thus, you need to download the appropriate printer driver from manufacturers website and install it on your PC. It is also wise to update the driver frequently.
For More Detail
http://printers.iyogi.net/issues/printer-paused.html
Jan 22, 2011 | Office Equipment & Supplies
My computer is not communicating with printer.
This is the problem with the antivirius or firewall please disable them during printing......................
good luck..............
Apr 28, 2008 | Lexmark X1240 All-In-One InkJet Printer
HP PSC 1410 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
