Question about RCA F27442 27" TV
RCA 26in. ctc203 sometimes no picture has sound.
    Genius:
  • 1,694 Answers
Bad solder connection..small coil in horiz driver circuit near
center of circuit board....solder both leads even though they
look good..........................T.
Posted on Jan 08, 2008
Sound only on some channels on RCA CTC203 chassis
do a hard reset to this TV. Refer its user manual for details.
Oct 07, 2012 | RCA F20625 20" TV
The picture on the tv is blue red and green
http://www.retrevo.com/support/RCA-HD52W58-TVs-manual/id/402ci453/t/2/ Above is your user manual. www.electro-tech-online.com/.../36401d1261034747-rca-32-television-32v434t-need-help-repairing-atc010_training_manual-1-.pdf Above and below aew training manuals, these show you how they work, and how to isolate issues. www.scribd.com/.../RCA-Chassis-CTC203-TV-Trainning-Manual
It sounds like your "Mixer" has faulted, however what has "Caused" that, may be one of many things. This unit must have troubleshooting procedures to isolate the issue.
it is my professional opinion though that everyone should take their units to their manufacturers, RCA in your case, approved service center, contacting a local or head office, of your unit & getting an approved service center is just SO important, even worth the extra to ship it, you see, at those places, the Engineers, are trained on the equipment you have, they usually have parts on hand, and do the job quicker. Anyway do that and get a "Quote". This way, at least, you'll know weather to repair or replace
May 27, 2010 | RCA HD52W58 52" TV
Acer flat screen tv - sound no picture?
Acer AL2671W 26in problems: (1) sometimes sound but no picture, (2) or screen freezes pink etc. (3) or remote won't turn it on/off (4) or it gives up and says "no signal". Turning it off/on usually solves it temporarily.
Nov 17, 2009 | Acer AL2671W 26 in. LCD Television
Tv turns itself on and off frequently
Check to see if this is an RCA CTC203 chassis (listed on back of set) if so there is common problem with bad solder connections in the horizontal drive section - Otherwise state the model for more help.
Be sure to vote/rate me if this helped Thanks!
Oct 05, 2009 | RCA Televison & Video
Rca ctc203 model number f25305 no sound
replace La7612h this is the audio amp ic.
Jan 11, 2009 | RCA F25305 25" TV
TV is flickering
That unit is a ctc203 chassis and if it's never been in the shop before it's probably ring cracks in the HV or power supply circuit. Not an expensive fix at the shop and those chassis tend to be a bit of a bear dismantle (lots of smd). You might consider taking it in for a pro to look at it..
If not the chassis removes as a tray assembly and then dismantles from there. Good magnification, light, dmm and solder gun and you got it whipped..
Bill
Mar 02, 2008 | RCA F27442 27" TV
32" model# F32668
The F32668 uses the CTC203 series chassis and I usually see 2 problems when the set will not run. The first is poor solder joints on a small coil near the horizontal output transistor, but if thats the case the set tends to run for a while and randomly shut off. When the set clicks and never runs I usually find that the flyback (high voltage) transformer has shorted out inside. In this case the flyback should be replaced by an experienced tech.
Aug 05, 2007 | RCA F32668 32" TV
Tv F27442
The TV does not have a reset button. If you have no picture and no sound, there is something wrong with the chassis. In this case the set should be serviced by someone experienced in the RCA CTC203 chassis. If you have no picture but do have sound, then it is possible that the 2 controls in the 2 little holes in the back of the set are not adjusted correctly. This is quite possible since you said you put a screwdriver in there and got a fuzzy picture. The control on the bottom is called "screen" and is the overall brightness of the picture and the control on top is called "focus" and is the sharpness of the picture.
May 20, 2007 | RCA F27442 27" TV
26in rca colortrak 2000
Very common problem The Highvoltage transformer and the horizontal output transistor has to be replaced. If you have no tv repair experience, this is not a repair for you. seek a professional. Should cost about 175 to 225 for this repair. Good Luck
Jul 12, 2006 | RCA F32450 32" TV
RCA F27442 27" TV Logo
42 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
