GE Dryer DDE7900 squeaking.
GE Dryer DDE7900 making ''squealing and squeaking'' noises. Belt Drive need to be tightened or replaced? Idler spring has sprung?
    President:
  • 1,922 Answers
It could be the drum belt that has glazed from age or the front drum glides/rollers or even a rear bearing on the drum
Posted on Nov 14, 2009
Dryer makes a loud squealing noise when I try to dry a load of clothes, towels, anything
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 11, 2011 | General Electric G.E. DBXR300EGWS 6.0 Cu....
Dryer making a loud squeaking noise
Hi, You probably will need the following parts to fix the squeal;
6-3705180 Idler arm $6.78
6-3700340 bearing $16.04
[2] 6-3129480 Drum roller shaft $5.53
[2] 12001541 rollers $22.04
33002535 belt $23.80
MAKE SURE DRYER IS UNPLUGGED BEFORE WORKING ON IT
Remove two screws at front bottom, pull front out toward you and remove wires from door switch and remove. Remove front bulkhead and drum. Check all of these parts I listed and replace as needed. Hope this helps
Jan 28, 2011 | Maytag Neptune MDE5500AY Electric Dryer
When I raise the hood and with motor running looking to my left there is a belt running and a squeaking noise at idle coming from that area. The van is front wheel drive so motor sits in there sideways.
Has it just started with cold weather? Does it squeal at first then as the engine is revved, stop squealing.
If so its probably your alternator belt has worked loose and needs tightening. I'd check this out first, if you've not done it before ask a friend with some know how for guidance. But as a guide, there should be about an inch of give when flexed on the longest run between 2 pulleys, if more then probably needs tightening. If more than a couple of years old, replace with a new one.
If it still squeals after tightening/replacing, you could have a faulty water pump bearing or pulley bearing. Either would require replacement to pre-empt catastrophic failure and resultant engine damage.
Dec 20, 2010 | 1998 Oldsmobile Silhouette
How to tighten serpentine belt for 2003 Monte Carlo 3.8L
the belt is self adjusted by a spring loaded automatic belt tensioner, if the belt is noisy or seems loose either the belt size is wrong (if it was replaced recently) or the tensioner is defective or one of the belt idler pulleys is defective.
May 27, 2010 | 2003 Chevrolet Monte Carlo
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
Frigidaire dryer model # FDEB34RGS2 Squeaking
There is a tension pulley that holds pressure on the belt, as well as wheels that the drum sits on. A drop of oil on the bearing of each one should solve the problem, unless the wear has gotten too far, and need replacing.
Jan 01, 2010 | Frigidaire GLER642A Electric Dryer
When the dryer begins its process, a long loud "squeaking" sound erupts, the dryer still dries, but this sound may last 5 - 7 minutes, then the squeak diminishes to a soft squeaking sound the remainder of...
The noise is likely coming from a roller which keeps tension on the belt which wraps around the drum. This roller will sometimes squeal as it wears on the shaft to which is mounted Follow the instructions below to replace the Idler roller.
Pull the dryer out enough to get behind it. there is a lower black panel to be removed by taking out all the 5/16" screws around the edge. Swing the panel aside and look into it. You will see the motor to the right. The roller should be between you and the motor. The configuration looks like the picture at the link below.
The belt goes in the grooves on the motor pulley and the flat side runs around the idler pulley, according to the GE chart on this image.
http://www.applianceaid.com/images/belt-config.JPG
Oct 28, 2009 | GE Dryers
Loud squeaky noise when dryer starts, noise stops after several minutes
I would replace the belt that turns the drum. It is probably wearing out and that is causing your noise.
Jul 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Noisy dryer......when engaged...making squeaking/squealing noise.
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Dryer makes noise when turning like bearings going or belt squeek
check the following -
It's noisy
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley
Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel
Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
good luck.....
Mar 28, 2009 | GE WSXH208A Front Load Washer
Televison & Video Logo
304 people viewed this question
Top Televison & Video Experts
