Question about LG enV VX9900 Cellular Phone
How to replace a env2 front screen - LG enV VX9900 Cellular Phone
My env2 was dropped. the outside screen works but
it's a good time to go get a new phone. that much damage would cost more in repair that it would to either replace or upgrade to a new phone.
Mar 23, 2010 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
My env2 is having spazes the ok button and the
take this to the verizon repair store nearest you and explain your problem..when mine starting freezing up it was just a download of new software it needed because of a glitch when they first came out.
Aug 14, 2009 | Verizon Communications enV2 Cellular Phone
Inner Screen doesn't work on env2
it will be demaged.
contact repair centre because the upper layer can be replaced with less expence.
but do the same in your presence.
Jul 26, 2009 | Verizon Communications enV2 Cellular Phone
My env2 is like broken.
the black screen with the rainbow is a clear indicator that you've cracked the internal screen.
Not fixable unless you replace the screen.
Jul 24, 2009 | Verizon Communications enV2 Cellular Phone
Env2 inner and outer screen do not work
just take it to the verizon store and they should replace it, water damage is very serious and messes everything up as you can see
Jun 19, 2009 | Verizon Communications enV2 Cellular Phone
I dropped my env2 phone, today and the whole inner screen went black. I want to fix it but how?
i had the same problem i dropped my env2 and the inner screen went black. i tried 2 fix it but just ended up getting a new phone. you can try 2 live on the outside screen or i was able 2 bend the screen and get it to work for a while. i hope i was helpful
Jun 05, 2009 | Verizon Communications enV2 Cellular Phone
Front keys will not work on my lg env2
Mine does the samething. Call customer support and let them know your phone is not working and you need a replacement. Mine is getting replaced. Mine started as just the "ok" button now it's moved to the 4-5-6 row. very frustrating.
May 31, 2009 | LG enV VX9900 Cellular Phone
Software update on Env2
One of the biggest problems with this phone is the OK button not working, and the front keypad doing the same eventually. Everyone I know with this phone has the EXACT same problem.
Mar 13, 2009 | LG enV2 VX9100 Cell Phone Car Charger
The env2 is a great dissapointmant
You will have a one year warranty so you can get if fixed for free.The problem is Your display is dead! Both the panel and the LCd screen. I advice that you pressure them for a replacement since its the 3rd time. Either ways you can get it fixed/replaced for free.
Good luck,
Sai.
Mar 12, 2009 | Verizon Communications enV2 Cellular Phone
LG enV VX9900 Cellular Phone Logo
832 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
