Question about Husqvarna Garden
Starts but turns off when choke is turned off . Seems gas air mix is off but no adjustments are possible
  • 44 Answers
Sounds like your "sucking air", get it running with choke on and slowly spray carb cleaner around carb at mating surfaces, i.e anywhere theres a gasket, if it bogs or stalls replace defective gasket/s
Posted on Nov 14, 2009
My husqvarna 128ld starts and idles fast but only with the choke half on. Give it gas or take the choke off and it dies.
Possibly a fuel starvation issue, incorrect fuel air mix or an air leak within the fuel system
Nov 25, 2011 | Husqvarna Garden
My brand new UST 1200W generator engine start OK (single pull) when choke on but won't stay up when choke is off. I changed oil after the first 4 hrs of use. Has this to do with the gasline I used?
It is possible that it may be having trouble if you have some bad gas but I would be more inclined to check the float to make sure it is not hanging up and allowing to much gas to get to engine. I would adjust idle and fuel mix screw all the way shut and then start opening them up about 1/4 turn at a time and try to start and run between adjustments.Only try to start it once or twice in between adjustments to avoid flooding. If you can get it to run good then turn screws one more time or until engine starts missing a little then slowly close until it runs smoothly.Hope this helps you. Thank you.
Aug 29, 2011 | Gentron 1000w rated 1200w peak portable...
Ryobi CS30 Trimmer starts and runs in full choke and half choke but stumbles and stalls on run. Not up to full rpms when in full choke and half choke....
You probably need a slight carburetor adjustment. Try to turn the L mixture screw (the one near the bottom of the carburetor on the air filter side, closest to the engine) 1/8 to 1/4 of a turn counterclockwise. These mixture adjustment screws ( L and H) have odd heads on them and conventional tools won't turn them. I use an automotive type plastic wire connector (around 22 gauge) with a ring terminal end which I can hold. Tap the plastic end of the wire terminal connector onto the head of the screw with a small hammer and this will enable you to adjust the L screw. This adjustment will increase you high speed side and possibly allow it to run off choke in a regular manner.
May 21, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have an old stihl 020 av chainsaw, the problem I'm having is when you start it and it's running the as soon as you go to give it gas it want to bog out and die even if you just try to give it alittle gas...
Look for your choke lever and make sure that it is operating properly. When the engine is choked, the butterfly valve in the engine is across the opening, causing the engine to take less air, and more fuel. As the engine begins to warm up, there is less need for the choke to be closed. If your choke valve is remaining closed, the engine will die when you pull the trigger.
Best regards, --W/D--
Jan 31, 2011 | Garden
Does not run at full speed unless choke is at 1/4 setting. I checked the air screen and it is clear. I replaced the gas with new fuel 50:1 mix.
its a blocked carb or filter
clean out all the fule pipes and filters
"""even the one in the fule tank on the end of the pick up pipe""" and retune carb when starting up again
ps,, iv never liked running on a 50:1 mix?
i do 40:1 if it smokes a little ,,,,,its got oil in it!
Oct 27, 2009 | Homelite Consumer Products MightyLite...
How do i adjust carbuerator
Start your adjustment by turning both screws (gas and air) all the way in and then back them out one and a fourth turn. Start from there. Hope this helps.
Jun 18, 2009 | Homelite Mighty Lite Lawn Trimmer
Slow starting tiller
Anytime an engine uses a gas/oil mix there is a possibility that the carbon this mix produces clogs the muffler making air flow next to impossible. First check to see if it will run better without the muffler. If it does you will need to clean the muffler by removing it and burning the carbon out with a torch. If this isn't the problem, then it may by your carb. Remove it, clean well with carb cleaner, replace the diaphragm if needed for as the diaphragm gets older it becomes stiff and will not pump the gas to the engine. When you reinstall the carb, turn the adjustment screws all the way in and the one and a quarter turns out to start with, making further adjustments from there after it starts. Hopefully one of these is your solution.
Jun 17, 2009 | Garden
Weedeater starsts and ildes won't run or accerate
It sems to me like your engine chokes itself on a too rich fuel mix, a clogged air filter may cause this condition. Of course there is always the possibility of a needed carburetor adjustment but I would definitely check the air filter first if this machine used to work fine.
May 30, 2009 | Troy Bilt Tb70ss Gas Trimmer
Chainsaw runs out of gas.
From your description, it sounds like your carb is running too lean. Make sure the spark arrestor screen is free of carbon build-up and the air filter is in place. Warm the saw up. With the saw at idle, adjust the Low adjustment screw to slightly enrich the mixture. If you turn it to run the fastest possible when idling, it is too lean. When the Low setting is right, you will be able to increase the RPM without it dying. If the High setting is way too lean, it may also die when you open up the throttle. If you run the saw too lean, it willl overheat and sieze.
Mar 29, 2009 | Echo Garden
Garden Logo
688 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
