Question about Toshiba Satellite A205-S4607 Notebook PC
VIDIO STRAMING PLAYBACK STOPS EVERY 5 SECONDS AND GO THUR THE BUFFING cycle amd repeats the process over an over
    President:
  • 2,030 Answers
That is due to your internet connection, and the data not getting to your computer as fast as its reading it.
Try downloading the full file if you can then viewing it.
If thats not an option, try to improve your internet connection.
It is possible that the stream you are viewing is highly viewed, and the net traffic is slowing down the feed as well.
Posted on Nov 14, 2009
Water will not dispense on my Keurig Vue .Brewing process stops after a couple of seconds
It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO THAT...
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
Discard any residual vinegar in the resevoir and rinse thorughly.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste
Sep 29, 2013 | Keurig Vue Brewing System
How do you program the transmitter on a 1996 Lincoln Town Car?
1. Enter 5-digit permanent entry code into the keyless entry keypad.
2. Within 5 seconds of pressing last button of code, press the 1/2 button. All doors will lock then
unlock confirming you are in programming mode.
3. Press any button on first Keyless Remote within 5 seconds of pressing the 1/2 button. Locks will
cycle to indicate succesful programming.
4. If you are programming more than one Keyless Remote (Including any exsiting remotes) Press
any button on second keyless remote within 5 seconds of previous remote. Locks will cycle again
to indicate succesfull programming. (If the keypad light goes out before all remotes are
programmed the entire process must be repeated).
5. Press the 7/8 and the 9/0 buttons simultaneously on the keypad to exit program mode.
Mar 28, 2013 | 1996 Lincoln Town Car
What is cl it shows up where the minutes go
It is child lock, find the 2 buttons for child lock, hold them in for 5 seconds and it will be back to normal.
Apr 17, 2010 | LG WM1814CW Front Load Washer
Maytag neptune FAV6800AWW top load washer gets to 32 minutes left and goes no further. It starts to cycle for about 5 seconds and stops for about 35 seconds... over and over and over
Is the machine in Spin Cycle when this is happening? What part of the washer selected cycle does the Cycle Status LED say the machine cycle is in.
If it’s in the Spin Cycle I think you have a clutch issue. Do you take any error codes to the LED console display such as dC or uC?
If you stop the machine in that cycle and do a Spin Only cycle will it complete?
Do you want to DIY the fix? Let me know and I will try to help…..Rich
Feb 26, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer fills, runs 5 seconds and stops for 5
Major problems here. Sounds like a circuit board thing. If the machine is on the old side , ditch it and start new.
Oct 06, 2009 | Maytag Dishwashers
I need to program the key fob
. Enter 5-digit permanent entry code into the keyless entry driver door keypad. 2. Within 5 seconds of pressing last button of code, press the 1/2 button. All doors will lock then
Jun 29, 2009 | 1997 Mercury Grand Marquis
Asko W6761 - seems fine, starts to fill 40 seconds then stops!
Hello, my W6761 becomes the same. When it happens, you can clear the problem by "soft ware reset". Following is the procedure:
1. Power it on
2. Push Start/Stop buttom 5 times
3. Push "Enter", ">", "<", "Menu" buttons (from right to left)
4. Again, push "Enter", ">", "<", "Menu" buttons
5. Wait for 30 seconds that the above soft ware cycle resets the internal status
6. Power it off and on, again
7. You need to execute above "soft ware reset" within 15 seconds
Start washing and check to see if above reset the problem.
If it does not begin to work, repeat above "soft ware reset" cycle until it begins to work.
My W6761 once needed to repeat above cycle 7 times to solve the problem.
This problem happens in mostly in warmer season, so this will be related with high ambient or water temperature.
ASKO technician may replace the controller but even with the replaced controller, this problem often happens.
Tsunett
Mar 16, 2009 | Asko W6761 Front Load Washer
LP600 - Lamp Did Not Strike
Check for shorted flat pack diode in power supply.
Feb 04, 2009 | InFocus LP 600 Multimedia Projector
Black lcd screen when switch on
i had the same problem and couldn't find an anser anywhere, so i just hit it.
seems to work fine now :)
Jul 11, 2008 | Canon PowerShot S1 IS Digital Camera
Toshiba Satellite A205-S4607 Notebook PC Logo
32 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
