Question about Asko 24 in. 1805 Built-in Dishwasher
Asko 1805 - inside light is on, none of the operation (front panel) lights turn on
    Problem Solver:
  • 5 Answers
Quite simple after all. If the main power button on the top left hand side of the door is pressed in (on). Whenever the door is openned their is a light in the DW which comes on like the fridge or oven.
Keeping the power button off turns the light off. For us this is good as we usually only close the door fully (catch catches) when we run the machine.This way we are not wasting electricity.
Posted on Dec 06, 2009
  • exitas Sep 28, 2010
    How about if the Power is On and there is light inside but the control panel isn't illuminated and doesn't allow to select the program. Any solution to fix it?
My dishwasher does not turn on I tested power to switch and it is good no lights on control module, no power to light
Find the tech sheet and locate the thermal cut-out, all units have one, some are mounted on the actual control board chassis and will blank the controls
Apr 26, 2016 | Asko 24 in. 1805 Built-in Dishwasher
FRONT PANEL Number 8071680-0
Try e spares on the internet may have one
Mar 04, 2014 | Asko 24 in. 1805 Built-in Dishwasher
Need replacement control selector pad mounted on top of door Asko 1805 fully integrated
Hello, Welcome to FixYa.
The part you`re looking for on the Asko 1805, as I understand your description ( please correct me if I misunderstood )...
the overlay/decor insert across the top of the control panel is Asko part # 80-708-88 (then a -0 for white or -33 for black depending on the color the last digit?digits change).
Check "repairclinic.com" part number 764259, retail for approx. $80.
Hope that answer`s your question. Let me know if I can assist you further.
Thank you for choosing FixYa today.
Please take a moment to rate the information I provided for you and a testimony if you fell it`s warranted.
Good luck.
Regards,
Macmarkus :)
Sep 04, 2010 | Asko 24 in. 1805 Built-in Dishwasher
All the lights are flashing on Asko 1805 dishwasher
Hi, You need to absorb the water in the overflow basen of the Asko dishwasher's and then push and hold a button to reset the error code...flashing LED's or turn the power off momentarily. You need to remove the lower kick plate and get to the basin with a wet-dry vacuum or sponge etc. Good luck. Let me know if I can assist you further. Thanks for visiting fixya and if you found this solution helpful please rate it accordingly. Macmarkus :)
Apr 08, 2010 | Asko 24 in. 1805 Built-in Dishwasher
Water Connections
In the US dishwashers are usually connected to the hot water supply. Although the ASKO 1850 I believe has an in line heater. Using hot water supply will reduce electrical useage.
Interestingly we use to have ASKO washer and it suggested only using cold water hook up as it heated its own water. I guess this was a feature if one's laundry area does not have hot supply, but it made no sense in CA to heat water with electricity.
Nov 11, 2009 | Asko 24 in. 1805 Built-in Dishwasher
Detergent door will not close on Asko model 1805 dishwasher
Here you must change complete detergent box. Or the electronic gives consantly power to trigger. Most likely one of these two.
Jul 18, 2009 | Asko 24 in. 1805 Built-in Dishwasher
Asko 1805 ALL lights flashing and no water coming out
High water level is often in the pan under the dishwasher.
  1. Unplug or turn off breaker.
  2. Remove kick panel.
  3. Remove water from pan.
  4. plugin/turn on breaker.
  5. watch for leaks.
May 30, 2008 | Asko 24 in. 1885 Built-in Dishwasher
Asko 1805 - all idnicator lamps blinking
Searched some more on this site and found the following from a guest (thanks). It solved my problem, the base where all the electrics and plumbing is located had a pool of water. I had to pull the unit out as I could not access this area from the front.
This is a common problem with the Asko1805. The machine is equipped with overfill protection. Water has leaked through to the bottom pan and has triggered the overflow shutoff float. You must get the water out of the bottom of the dishwasher. Unscrew the kickplate and the metal cover to access the bottom of the machine where the pumps and motors reside. Use a sponge to slop up the water in the pan. Blow dry the bottom. The machine will reset itself as soon as the water is gone.
Apr 19, 2008 | Asko 24 in. 1805 Built-in Dishwasher
Asko 24 in. 1805 Built-in Dishwasher Logo
273 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
