When I turn on my acerpowerFH computer the blue power light comes on and the monitor's light is orange. hen i turn the monitor off and turn it back on again it says "no signal" and the light turns orange again.
  • 838 Answers
It can happen for three reasons, 1. VGA cable is not connected or plugged properly, 2.VGA card is slidely loose on slot, 3.Screw are not tightend properly. First of all remove the cable and connect again , tighten the screws both cable ends. if it doesn't helps check the VGA card properly installed on motherboard (if not built in)...I think it will help you to fix...Thanks for subscibing Fixya...Good Luck
Posted on Nov 14, 2009
Dell wont turn on
i have a Dell ultrasharp u2410. I turn the screen on and you can see the blue light ascending, but hen it stops and only orange light comes on and nothing, I think it says in power save mode.
Jan 10, 2014 | Computers & Internet
Acer p223w monitor does not turn on
Try a different monitor, check the connections to the pc. When the monitor light changes to orange, press the spacebar to see if the light changes back to blue. Your pc power settings might need to be re-adjusted, is the pc going to sleep or hibernating too soon?
Jan 02, 2014 | Acer Computers & Internet
Please can you help us. when we turn the computer on the monitor light stays blue with the screen remaining black, when we turn the tower off the light stays blue when it usually has the orange standby...
There is probably a conflicting setting in your power management options. My recommendation is that you check the monitor setting in Windows and see how you have it set up. In Windows it is under CONTROL PANEL>POWER OPTIONS. There are a few differences between WINDOWS 7 and XP from here on out, but in general, do not select a scheme and do not select any hibernate, standby, or sleep modes. If you stick with a simple power saving option, like "TURN OFF MONITOR: After 15 mins." you should not have any further problems.
Many of the Windows "green schemes" will not work right with different combinations of BIOS, Hard drive, motherboard, and monitor. It is best to avoid them, unless you are very patient and willing to go the trial and error route. Good Luck!
Mar 08, 2011 | ViewSonic VX2235WM Monitor
Just today when watching a movie my monitor will go blank and the light at the bottom which is white when on will go dark and then turn orange like it's been turned off then about 20-30 seconds later it...
When the power saving options of the computer is turned on, after particular time the signal stops to the monitor and the orange light will come on, once you move the mouse or press keys on the keyboard, the cpu comes back from the power saving mode, the signal passes on to the monitor and there will be display.
Sep 05, 2010 | Acer H233H bmid Monitor
Monitor power light startup blue then go's to orange and screen go's black. And the power light is still orange, should it be blue?..
ou have a problem with your video card, take a look if is correctly connected and turn off the computer.
try to use your BIOS to reset it to the factory settings
Aug 11, 2010 | Gateway FPD1975W 19" LCD Monitor
I shut down my computer at night. When I come back the next morning the computer is off and the monitor is in standby with an orange power light (so far so good). When I turn the computer on, the monitor...
that blue light show and error or faulty problem internally or there a problem with in the connection or computer but first check the makers website or manual for troubleshooting.
Dec 13, 2009 | LG L1932TQ LCD Monitor
Computer powers up but monitor goes right to sleep?
when i power start my computer,,the light come on and seems to operate but the monitor doesn't come on,,,when switichin the monitor off and on , the blue light comes on and it reads monitor goin to sleep and the screen gets dark,,but the monitor orange light is on,,,pls help
Sep 21, 2009 | HP Pavilion MX70 17" CRT Monitor
I just bought a Acer 19' monitor and I'll trying to connect it to my Dell PC. It came with to cables (blue and white). The blue goesinto the back of the PC Tower but the white one fits nowhere. When the...
they all come with two cables. blue being vga, white being dvi cable. you only need to plug the blue into both ends (computer and into the monitor) and turn on. If it is still not working how many video cards are there on the computer? Do you have it plugged into the right spot and is it tight on both ends?
Jul 23, 2009 | Acer AL1916W 19" LCD Monitor
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Monitor has no picture
Yes! :)
Your monitor is not the problem. Check all the connections from the back of the monitor, to the computer.
"No Signal Analog" means your monitor is working perfectly, however is not receiving signal from the computer.
Didnt find any loose cables?
Try unplugging everything. Leave it unplugged for at least 5 minutes. You need to give the system time to drain all the excess power.
Again your monitor is fine, blue light > No signal > orange light is totally normal for your montior.
Oct 12, 2007 | ViewSonic VX922 19" Monitor Flat Panel
jasbo
jasbo
