Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Wd-62627 blinking green light - Mitsubishi WD-62525 62" Rear Projection HDTV
5 Suggested Answers
  • 103 Answers
SOURCE: Mitsubishi WD-62725 constant blinking of green light
Check the lamp to see if it is damaged(this is in your owners manual for removal)If not please contact me for more info
Posted on Apr 26, 2008
Slinteriors
  • 8617 Answers
SOURCE: Blinking green light for Model WD-52825. What
The usual cause is due to the DM not booting up due to failed capacitors. You can get the V26 DM repair kit at www.tvrepairworld.com which contains the replacement capacitors and the CD with detailed instructions.
Posted on Dec 20, 2009
  • 1039 Answers
SOURCE: mitsubishi WD-62627 had power blink then green
The chassi will have to be removed and sent to Mitsubishi to be rebuilt. Also PTS in Bloomington ,IN does this. The chassi is the box with all th input jacks and electronics on the left. This is very complicated but if you chose to do it let me know and i can give you some instructions. you may want to call mitsubishi or PTS and check on rebuild est first.
Posted on Mar 26, 2010
sethdileswar
  • 253 Answers
SOURCE: Mitsu WD-62725 green light blinking continuously.
pls check remote aur repair smps power supply of tv
Posted on Apr 05, 2010
2006 mitsubishi tv WD 62627. Tv wont come on i hear a click when I hit the power button. Blinks green on timer for about 60 sec then goes to solid yellow light on status. Error code 46.blew fan out.
Those blinks are fault indications. From the number of blinks occur at one time switch on, you can get an idea about the fault circuit section inside it. http://electronicshelponline.blogspot.com/ Visit the site linked here to know more details about the blinking codes.
Feb 18, 2017 | Mitsubishi Televison & Video
Wd 62628 lamp indicator light is solid yellow / orange what needs to be done
Your lamp cover is not installed. That is what causes the LED to light amber. Remove and re-seat the lamp cover door. There is a switch it hits to tell the TV the door is shut. This is to protect you from electrocution.
Sep 13, 2016 | Mitsubishi 915P026010 LAMP WD-52627,...
What is error code 42 on wd62627
Double check as no 42 is indicated on their site.
Nov 29, 2012 | Mitsubishi WD-52627, WD-52628, WD-62627,...
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Model WD 62627 When I plug it in all that comes on is the timer green light at the bottom of the tv.
Replace the lamp of your tv or check it first if damage, feel free to send feed back good day and best regards.
Aug 22, 2011 | Mitsubishi Televison & Video
I have the WD 62627 model. the lamp light is on, when i power up the tv, it comes on for like 6 to 10 secs then it turns off. Does this mean I need a new Lamp?
I would say that it probably is a bad capacitor on the power supply board of the tv. What you want to look for is any round cylinders with the tops pushed up at all. The replacements are usually really cheap, it might also be the lamp, but usually when lamps go they go completely while a bad capacitor is known to cause intermittent problems that escalate into a tv only working for about 5-10 seconds.
May 03, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62627 had power blink then green light blinks, unplugged over nite, now it comes on with loud static can't change volume, channel, no format, or menu
Mar 26, 2010 | Mitsubishi WD62627 62" HDTV
Mitsubishi DLP WD-62627 Shutting Down
I was going to say that sounds like the power side to me mate the board power board check it out before you spend any money make sure it's unplugged before you do any thing and where a earth strap ok to stop you getter a shock ok
Jul 10, 2017 | Televison & Video
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
125 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
