Question about Brother MFC 420CN All-In-One InkJet Printer
Will not print black all other colors work - Brother MFC 420CN All-In-One InkJet Printer
    Brigadier General:
  • 10,406 Answers
Replace the BLACK ink-cartridge.
Posted on Nov 14, 2009
Can i print in black if my printer has run out of coloured ink?
Hi judysimeon
Goto the printer settings page and change the settings to print in black . Normally it is set for color - when color and black will print - You will find the question Print in Color Or Black Each has a check box. Check the box for black. With this setting, everything will print in black including the color text and graphics.
Most printers let you do this. However, some printers keep telling you to replace the color cartridge.
Hope this will work for you.
Good Luck
luciana44
Apr 10, 2010 | Brother DCP 130C All-In-One InkJet Printer
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
Hp 2110 won't let me print
You have to change the Print -> Settings -> Preferences
O Print in color (this means color inclufing B&W)
O Print in Black (this means print in black only)
Select the Print in Black
When the printer says replace the color cartridge, just close the window instead of saying Yes or OK.
This is not the official HP trouble shooting solution. But, it often works
Good luck
luciana44
Jan 07, 2010 | HP Office Equipment & Supplies
Trying to print from microsoft word . Keeps printing in black. Color cartriges 75% full. What am I doing wrong?
  • Go through the Print menu (from Microsoft Word)
  • On the Print Dialog screen, select Properties
  • Click on the Color Tab
  • Make sure Color button is selected (not Black or Grayscale)
  • Press OK
When color is selected, the printer will print Black as well.
If Black is selected. the printer will not print color.
If this answer is helpful, please give a rating.
luciana44
Dec 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Non printing epson c20ux
Sounds like color cartridge ran out. Were u using color to print black?
Try new color cartridge.
Then if you don't need color go in and set to use black cartridge to print black (text).
If you need color on something only takes a minute to turn color back on.
Since printer worked you can go in and select black which uses the black cartridge and if it prints gives validity to a bad/empty color cartridge.
Good luck.
JC
Nov 27, 2008 | Epson Stylus C20UX InkJet Printer
Lexmark X1100 printer will not print black
I came up with a work around for printing black.
I changed the black cartridge with the color cartridge.
Then when I have a letter to print, I change change (or write) the letter text to yellow, red or blue.
Then I can print out a letter.
By printing the text as yellow, red or blue the cartridge will try to print with only 1 color, but will print out black.
If you do not use one of these primary printing colors the out put will be unusable.
I can not of course print out pictures.
Oct 04, 2008 | Office Equipment & Supplies
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Black blocked by magenta
One ovbious option would be to have a friend print it out.
I assume that is not an option.
Some printers just won't let you print if a single color is out. Yes, stupid. Try printing a blank page. If it fails, there is no other option but to replace the cartridge or print elsewhere.
If the blank page test works, this next option/test is worth a try...
Depending on the app you are using, you can specify the color breakdown of the colors you are using. In your case, it is possible that the text is set to a rich black (4-color) rather than just black.
If that is the case, to test this most quickly, make a new file, and create a new black (black2), set to 100 black, 0% other colors.
Type a wor and set it to print in that color and try to print it.
If that works, apply the same technique to your real document.
Hope it works. I've been stuck in the same situation, and some printers will just not let you print if a single color is out.
Good luck.
DigiChick
Jun 09, 2008 | HP Color LaserJet 2600n Printer
Lexmark z1300 printer - one cartridge
if you look at the options in the printer there should be an option to use the color cartridge to print black. How does this work? Well what the printer will do is mix all three colors to make a light black. This will eat up your color cartridge faster but is useful when you are out of black ink and you need to print
Apr 23, 2008 | Lexmark Z1300 InkJet Photo Printer
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
Brother MFC 420CN All-In-One InkJet Printer Logo
80 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
