Question about Samsung Propel SGH-a767 Cell Phone
I have a samsung alias with a bad esn, and another one with good esn, can you switch the esn's on these two phones?
I got a sprint LG viper that has a bad esn how do I change it so I can activate it
Ask the seller for the ESN number, call the carrier of the phone and ask them can they run a check on the esn of that phone and they will tell you why the ESN is bad. upon fixing that issue (usually an unpaid bill) you should be good to go.
Oct 25, 2012 | Cell Phones
I760 cdma purchased from ebay usa global with verizon carrier
In order for you to do that you will need to get a Global Phone, every ESN (Electronic Serial Number) is only programmed for a specific carrier i.e. Verizon, if you want to take your phone over to India you will need a Global Phone check out the Samsung Renown or Blackberry Tour/Storm/Storm2
Apr 02, 2010 | Verizon Communications Samsung Alias Cell...
Why does my samsung alias keep taking pictures
Something is hitting the camera button on the side. Many phones have this issue and there's no way to fix it.
Feb 14, 2010 | Samsung Alias 2 SCH-U750 Cell Phone
Where do i get a usb driver from my alias 2
The Alias 2 is not supported by the Samsung PS Suite.
Jan 13, 2010 | Samsung Alias 2 SCH-U750 Cell Phone
How do I find the ESN on a Samsung SCH-A950 when the ESN label is not readable
settings and tools menu
phone info
sw/hw version
find the one that says MEID or ESN
Nov 04, 2009 | Samsung SCH-a950 Cellular Phone
Samsung alias earpiece speaker
Possible the earpiece has gone bad. Can you test with another earpiece?
Remove battery and examine metal contact points for dirt. Can clean with a pencil eraser.
Jul 19, 2009 | Verizon Communications Samsung Alias Cell...
Samsung instinct esn problems
ESN that sprint needs is the ESN DEC, it is an 18 digit number above a bar code under your battery directly on your phone. This is not to be confused with the HEX, which starts with an "A"
Apr 27, 2009 | Samsung Instinct Cell Phone
Cannot format memory card
The Samsung Alias can only use up to 2gb microSD cards. I had this same problem after purchasing a 12 gb card only to discover that I could not use it with this phone. Hopefully this will be fixed when they make the Alias 2.
Apr 13, 2009 | Verizon Communications Samsung Alias Cell...
Audio problems on my samsung alias phone
its the battery. same thing on my phone sometomes i flick the back of the battery casing and it seems to work.
Mar 16, 2009 | Verizon Communications Samsung Alias Cell...
Lock code for nam2 settings
Ok i sent an email to sumsung and i got this response
Thank you for your email. If you switched the NAM to NAM2 you will need to calculate the code. Listed below are the steps on how to do so:
1.Obtain the Hexadecimal ESN of the phone. The ESN should be printed on the sticker on the back of the phone, under the battery. The Hexadecimal ESN is the one with letters and numbers.
2.Open Windows calculator by going to Start -> Run -> type in "calc", then click OK
In the Calculator, click "View" then "Scientific".
3.Click on Hex and type in the Hex ESN
4.Click on Dec for the decimal conversion and use the last four digits for the code on the handset
5.Once the code is entered and the menu can be accessed, switch the NAM to NAM1
Jul 06, 2008 | Samsung Glyde SCH-u940 Cellular Phone
Samsung Propel SGH-a767 Cell Phone Logo
274 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
