Question about Smart Modular SV3170A
My LG CRT montor display nothing except green light when I turn on my computer.What can be the problem?
    President:
  • 2,030 Answers
Either a bad connection to the computer, or your monitor has gone bad.
Posted on Nov 14, 2009
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
The lg fratron ez. H713sh is flashing a green led and nothing is coming on e display, thought of connectng otha monitors bt didnt succeed.
If you get the same result with the other monitors, you may have to replace your VGA card.
First turn off the system.
Remove the VGA card from your computer.
Clean it and fix it again. This might fix the problem.
If you get the same result, replace your VGA card.
Jul 12, 2011 | LG Studioworks 552V 15" CRT Monitor
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
My montor is going green in place how can i fix it
move the speakers away from it the magnet is pulling the color out of the screen :)
Jan 27, 2010 | LG 19 Widescreen LCD Monitor, 1440X900...
Taking 5 min to warm up
if the monitors tub is old or cold its take sevaral minutes to warm up
Oct 02, 2009 | LG Studioworks 700S 17" CRT Monitor
700e Lg crt monitor problam power on eht on but not display
The normal crt monitor have a demo display when you unplug the vga cable to PC like this image below.. fd6b6b9.jpg
Note:
If the crt monitor green LED light steady and heater beam have light, the horinzontal and High Voltage supplied to tube is completely good. If you encountered this problem just focus on video section of crt monitor. But before you start... find the flyback transformer behind this they have two controls screen & focus. After you found it plugin the monitor use plastic precision or small screw philip driver for safety to high voltage at horizontal area choose screen control rotate it to clockwise direction follow this....
5b5166c.jpg If the display responses or from dim to lighter 100% you have a problem to ABL find this at the bottom of horinzontal section near at flyback transformer pins trace the line of ABL for dried solder, open resistor if nothing happen find the Video IC at chroma section and replace it. follow this...
3c6e89c.jpg For LG & Redfox you found LM1269NA Visit this site for seaching semiconductor matches www.alldatasheet.com Good luck.
Check this site for searching semiconductor
Aug 12, 2009 | LG Studioworks 700S 17" CRT Monitor
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
LG Monitor Display Problem
1. Mostly Loose contacts in video section that means CRT Neck board dry points checke it.
2.Pl check VGA Cable RGB signal pins 123 to ground 75 Ohms (on OK condition).
3.check 5v supply
4.check SDL and SCL signals.
Oct 05, 2008 | LG Studioworks 563N 15" CRT Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
DESKTOP COMPUTER TURN ON PROBLEM
In this case it is normally a voltage regulator near the cpu that is shorted and will need to be replaced.
Remove everything from the board, except the heat sink fan and plug in the big power connector, do not connect the 4 pin connector. Turn the power on as you were before.
Using a multimeter, check the voltages on those regulators. You should find them running in pairs normally, but make sure to check all of them and try to pick the odd one out.
Put your black lead to ground, and use some electrical tape to cover all of the red leads probe except for 2mm at the tip to help prevent shorting out anything else while you are there.
Apr 08, 2008 | Intel Motherboard
Smart Modular SV3170A Logo
51 people viewed this question
Top Smart Modular Computers & Internet Experts
David Payne
David Payne
Are you a Smart Modular Computer and Internet Expert? Answer questions, earn points and help others
