Question about ASUS P5RD1-V Motherboard
P5RD1-V BOOT PROBLEM
I am not able to successfully boot from my ASUS p5rd1-v motherboard machine. I have replaced the RAM and also replaced the CMOS battery with a brand new one and also reset the CMOS using the jumper.
Sometimes the Initial ASUS Splash screen comes and gets stuck there.
Sometimes error message comes
Floppy Controller Failure
CMOS Checksum error
Press F1 or F2
but the keyboard doesnt function.
Sometimes I am left with Blank screen.
Please help
Please help....
    Novelist:
  • 111 Answers
The CMOS, which stands for complementary metal-oxide semiconductor, is the hardware component of a computer that supports the BIOS, or basic input output system. The two terms are often used interchangeably, and the two technologies work together to perform the same basic function. They maintain the low-level settings on a computer, letting the computer know, even before the computer's operating system starts, what kinds of hardware the computer has available, such as hard drives and video display adapters. A special battery located on the computer's motherboard powers the CMOS. To reset the CMOS on a Dell computer, briefly remove and then replace the battery
  1. Turn off the computer. Disconnect all cables and detach all devices, including USB devices, from the computer. Press and hold the computer's power button for 10 seconds after it has been unplugged. This grounds the system board.
  2. Step 2 Remove the computer cover. All Dell systems have a cover panel on the chassis that you can remove so that you can access the system's motherboard and internal components. For some Dell computer lines, such as OptiPlex, the computer cover is held in place by a release latch located on the back of the computer. Pull the latch to release the cover and then slide the over up and away. Other lines, such as Dimension, have large, slotted thumbscrews. Turn the screws counter-clockwise until they disengage from the chassis, the slide the cover off the computer. Dell computers often ship with the computer's user guide in CD form or with the guide pre-loaded on the system's hard drive. You can locate the instructions for removing the cover from your particular system in the user guide.
  3. Step 3 Locate the CMOS battery on the system's motherboard. CMOS batteries range in size from size and thickness from about the size of a nickel to about the size of a quarter. The CMOS battery will generally be labeled CMOS on the motherboard and will be the only battery openly exposed on the motherboard.
  4. Step 4 Remove the CMOS battery by prying it gently up out of its socket. The sockets are specifically designed to allow the battery to be replaced.
  5. Step 5 Wait 30 seconds, and then replace the battery in its socket. This will reset the CMOS. Replace the computer cover to complete the process.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Posted on Nov 14, 2009
I can't boot from sata CDs with my motherboard asus p5rd1
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
cmos is located in BIOS
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS recovery
hope this helps you
Aug 03, 2011 | ASUS P5RD1-VM Motherboard
Asus P5RD1-VM. Auto-power up, not boot sound and cannot power off
First of all you want to reset your BIOS. Instructions on how to do this can be found in the manual which is provided in the following link, the manual calls it "Clear RTC RAM" which is on page 35. While you are inside the computer, make sure all cables/connections are firmly seated.
Manual:
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5RD1-VM/e2440_p5rd1-vm.pdf
If this fails to clear up your boot issue, you need to go a little further into the computer. Make sure your computer is off and unplugged from the wall before continuing.
Next you need to remove ANY hardware that is not needed to boot. This means any add-on cards (expansion cards), hard drive, RAM, video card, CD/DVD drive, USB devices, firewire devices, speakers/microphones, keyboard and mouse.
After they are all disconnected, try booting. If it acts the exact same as it did before, you have to go further into the computer again. If it does something different, one of the components you removed was causing your boot problem. Replace them one by one, trying to boot between each component you hooked back up, I would first start with the RAM.
But, if the computer still does nothing upon boot, you need to bench test it. This means you remove the motherboard from the case and set it on a hard non-conductive surface (kitchen table or a work bench). Then you hook up the Power Supply correctly and attempt another boot. If now you hear beeps from the motherboard, your motherboard had somehow shorted to your computer case.
If you still get no beeps, your problem is either the motherboard or your CPU (processor). To narrow it down between those two, put your processor in another computer to see if it works.
If you go through all of those steps and get nothing, I would be looking mostly at the motherboard.
Hope this helps.
Jul 21, 2010 | ASUS P5RD1-VM Motherboard
Does not boot
To exclude a possible short, remove the MB from the case and place MB on to a couple phone books thats covered with a non static MB bag. Connect power supply, keyboard, mouse, primary hard disk drive, monitor and internal speaker. Also leaving CPU/heatsink assembly and memory connected.
Short the power-on pins by using a pen. See page
1-34 in you're manual, PWR BTN. If the system boots ok than there was a short with the MB while in the case. If the system does not boot than the MB is bad or the bios needs flashed. Keep the MB out of the case and follow the instructions on page 2-2 section 2.1.1
Link to Asus; http://usa.asus.com/Search.aspx?SearchKey=P5RD1-VM
Hope you find this helpful!
Mike
May 08, 2010 | ASUS P5RD1-VM Motherboard
P5rd1-vm - will RAID setting delete my data
Suggest you enter the bios and make a setting change. Open the manual to page 2-24.
The M1573 RAID function set this to [Disabled].
(This will stop the bios from loading the RAID controller.)
See boot menu page 2-31 section 2.6
Set section 2.6.1 Boot device priority as shown.
(The drive with windows installation on it should be in the boot order).
You can also unplug either the data cable or power cable of the slave drive to assure it does not boot. If you still receive a blue screen with the primary drive suggest you re-install windows or boot to the windows CD and create a new partition within the free space of the primary drive. Install windows complete including updating. When finished you'll be able to copy you're data to the new windows. Use windows disk manger program (diskmgmt.msc) in the run window to delete the old windows partition.
Some programs will need to be reinstalled.
Link to Asus; http://www.asus.com/Search.aspx?SearchKey=P5RD1-VM
Cheers'
Mike
Mar 14, 2010 | ASUS P5RD1-VM Motherboard
ASUS P5RD1-V FAILS TO BOOT
Pls check with USB key-board
I hope that this has been very helpful for you
Nov 14, 2009 | ASUS P5RD1-V Motherboard
ASUS P5RD1-V MOTHERBOARD BOOT PROBLEM
It sounds like you have a dead battery on your motherboard.  Just replace it and your settings will remain.
System won'n boot if i installed two RAMs
Is the old ram working if installed alone? If yes then maybe got error or grounded if both ram inserted. Try to blow air the ram slot in the board to eliminate dirt and then try to interchange the position of the ram and then try it again.
Hope this will work.
melnavz
Feb 12, 2009 | ASUS P5RD1-VM Motherboard
DDR2 RAM for P5RD1-VM
The ASUS P5RD1-VM takes the PC2700/3200 DDR SDRAM DIMMs. You can upgrade your ASUS P5RD1-VM to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory. For best system performance use the maximum amount of allowed Memory per slot for your system i.e. 1 GB.
Thanks
Iqbal
Apr 14, 2008 | ASUS P5RD1-VM Motherboard
Motherboard ASUS P5RD1-VM ram problem
More people should complain with Asus support. Checking Asus forums, you'll find there's an obvious problem with a PCI-E video addon + 2 used memory slots. In my case, I had 2Gb (1 + 1), mb with bios version 1104, and it worked fine; when I installed a new PCI-E card, the system was very... very sluggish. Now I have uninstalled 1 memory, I'm using only 1Gb of RAM with the PCI-E card, and it's working well.
Again: checking Asus forum, this is a reported problem, and a bios bug... Asus should release a new bios version, but they seem not to bother, as this is a relatively "old' mb...
Feb 16, 2008 | ASUS P5RD1-VM Motherboard
ASUS P5RD1-VM raid controller
1. put Motherboard Cd (come with p5rd1vm) in cd/dvd rom.
2. BIOS configur as boot from cdrom.
3. restart machin Motherboard CD boot with press enter
4. command line shows 4 option
5. Select 1st option for exact and proper copy ULi sata driver for winxp.
6. Insert floppy press enter
7.you see d copy procedure.
8.then this floopy insert when winxp setup asking F6 for additional driver.
Thank you.
YOGESH JADHAV
Sep 29, 2007 | ASUS P5RD1-VM Motherboard
ASUS P5RD1-V Motherboard Logo
216 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
