Question about Xante Accel-a-Writer 3N Laser Printer
Screenwriter 3 Fuser Problem
Does anyone know where I can get the MAX-UPPER FUSER ROLLER.  Xante Customer Service claims they do not sell this roller alone but tech support claims they do.  I just want the part so I don't have to spend $650 on a brand new fuser unit that I don't need.
THANKS!
  • Anonymous Mar 26, 2014
    fuser replace
MY FUSER IS DAMAGE CAN I BUY ONLY THE FUSER ROLLER
OR CAN YOU SPPLY
Posted on Aug 27, 2010
  • 233 Answers
Go here to the 3N section, email these guys and see if they can help you.
hope this helps
thanks for your rating
Posted on Jan 08, 2008
Xante screenwriter 5 will not go thru the fuser when printing. Paper seems to roll there. manual does not give instructions on removing fuser and visual inspection shows no paper caught in path.
Check for media jams in the paper exit area under the fuser cover.
SEE 8-13 for diagram of fuser cover location.
http://www.xante.com/download/Legacy-Color-Products/Colour-ScreenWriter-Series/Colour-Laser-Series/ColourLaser/Manuals/Troubleshooting%20-%20English/cl_troublesh.pdf
Hopefully this is all it is other wise it may be more sinister like the fuser roller has fused together -
I have had this happen on another printer . Because I did not remove the power before I removed the fuser unit in a different model and make of printer. And fused the rollers together like melted together in the fuser. I think you would get an error code if this was the case !
Apr 10, 2018 | The Office Equipment & Supplies
Plain paper jaming in fuser unit
must be fuser unit, look for these signs :
1- upper roller damaged
2- does not have a "polished " finish
3-lower roller has ripples /waves on it
Apr 08, 2014 | HP LaserJet 1320 Printer
The paper is crumpled in the lower part of the paper.
Maybe you have problems with the upper fuser roller, open the back door and try to see the upper fuser roller and lower pressure roller if you see any wrinkles or damage in any of the rollers that's is the problem, you can replace them just the upper fuser roller and the lower pressure roller but it will need advanced skills, the other option is change all fuser assembly but at higher price
Nov 26, 2013 | Brother HL-5250dnt Laser Printer
How to i clean the drum - there is a mark every few inches when i print
If the mark is persistent on each page and repetitive with very precise spacing, you need to determine which roller it's coming from. It could be coming from the transfer roller, before the fuser, the fuser itself, or the fuser pressure roller. Measure the spacing distance of the mark(s), then measure the diameter of the 3 above mnetioned rollers, multiply by pi (3.14159265) and compare the results to determine exactly which roller is causing the issue, then replace that particular roller. Hopefully it's not the fuser as you'd be better-off replacing the fuser film (main fuser roller lining). The fuser and pressure roller are a pain to source, and run abou $65+ for the pressure roller, and about $90+ for the fuser, not to mention this 2 last rollers will take about 1-1.5 hours to replace. They are not hard to replace using common tools. Don't forget to locate the printer service manual over the internet first.
Jun 12, 2012 | Canon imageCLASS MF5750 All-In-One Laser...
Fuser upper failure is the message i am getting on my xerox phaser 7300. can anyone help please
Hello, The fuser or fuser roller is what actually bonds or melt the toner on to your paper. There is probably some type of temperature sensor, that senses the temperature of the fuser. If its not hot enough or just plain dead, it will give out an alarm similar to what your getting. You probably need to replace the fuser unit. You have a lower fuser and an upper fuser. You might be able to get away with just replacing the upper roller. The roller has a heating element inside and that's what probably defective.
Hope this Helps
Thank You for your feedback
Jan 31, 2011 | Xerox Phaser 7300DN Laser Printer
Replacing upper fuser roller
there really is no need to remove the cleaning web when replaceing the upper fixing roller.... it stays in place and will not present a problem apon replacement
Jun 04, 2010 | Canon imageRUNNER 5000 Copier
Paper will stuck at the heater
HI i think you have a bad upper fuser roller thats why the paper rolled up with it or maybe there are finge clow are not good first of all just remove paper and just clean the upper fuser roller with fuser oil if yours fuser roller and finger clow are not damaged it will work fine enjoy
thanks
May 14, 2010 | Konica Minolta DiALTA Di200 Copier
I need to know how to replace...
The transfer belt cleanning blade is under the transfer belt.Remove 2 screw and change it.The bias transfer roller is mounted in two bushings,remove the bushings and 2 springs.The fuser unit : upper fuser roller,lower fuser roller and the cleaning rollers.
Aug 25, 2009 | Office Equipment & Supplies
Upper (gray) fuser roller needs replacing, (tear on 1 side).
If you are handy it is not hard to replace the upper fuser roller you will need a small phillips screwdriver and pliars
the fuser lamp goes through the fuser roler so youmust disconnect the power leads to the lamp and remove the lamp
You do have to release the back side of the drive
gear on the fuser roller
when you install the new roller be sure to put some silicone fuser oil on the cleaning pad
take your time good luck
Jan 04, 2009 | Office Equipment & Supplies
Xante Accel-a-Writer 3N Laser Printer Logo
465 people viewed this question
Top Xante Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Dudeman321
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
