Question about Garden
Dies when i give it gas
The blower starts up and will idle forever. When I give it gas, it bogs down. If I then let off the gas it will go back to idle. If I continue to hold the gas it stops running.
  • 202 Answers
Sounds like your carburetor either needs cleaned or the needles need adjusted. Try turning them just a bit and continue trying to accelerate the engine. If your carb has adjustable needle screws, one will be the low speed adjustment and the other will be the high speed adjustment. You'll know when you have the right one when the motor starts to run just a bit better after adjusting the correct one.
Posted on Nov 15, 2009
Car idles fine, but sputters, bogs and dies if gas pedal is pressed.
new spark plugs this decade. (a tune up?0
the filter is part of all 60k tuneups. letting it clog wrecks good pumps.
my wild guess, its lack of fuel flow, do to old filter.
or low fuel pressure.
car is identical to a Corolla. so is not unique or rare as some Geo cars are.
the cam belt not changes, invites valve kissing piston tops. BOOM
end of engine. (costs more to fix then worth of car)
the word is bogging, my engine bogs
if if bogs WOT (wide open throttle) and dont catch up < ITS NOT THE TPS. ever.
tps bad causes short bogs, called hesitations.
The map sensor , is what measure air flow and the ECU matches fuel to this air flow.
my guess, is it does that, but fuel pressure is like 15PSI, bad.
Apr 14, 2015 | 1995 Geo Prizm
Ryobi gas blower tuff starting and bogs down, and dies
take the muffle off and run it if ok open the muffler a bur off the screen inside with a tourch
Mar 25, 2012 | Garden
Blower runs at idle then when you give it gas it bogs down until it shuts off
try to choke it part way and see if it still bogs down, if it does then check your exhaust screen, if partial choke helps it then check fuel lines for cracks, fuel filter for being dirty and also remember fresh gas too, if all else fails clean your carb out.
Nov 19, 2011 | Garden
I have a shihl br 340 leaf blower it starts but when I make it accelerat bogs down and dies ive tried ajusting the idle screws cleaned the carb not sure what to try next any sugestions
check the muffler for the exhaust being plugged, If not start checking your fuel lines and fresh gas, then fuel filter and ,all esle failes clean carb out.....hope this helps
Apr 25, 2011 | Garden
My 03 tahoe dies when it comes to a complete stop... I can start it but when I give it gas in the park position and let it come back down to a idle it dies... I have replaced all spark plugs and wires... I...
thats what it sounds like, a bad or clogged up fuel filter. if it bogs down when giving it gas, or going up a hill. its probably the fuel filter not letting enough fuel to engine. that is why it stalls at a stop. if this helps but not fully. check or clean idle air control motor. this is what maintains proper idle of vehicle. have a good day !!
Mar 31, 2011 | 2003 Chevrolet Tahoe
1987 Bayliner capri 85hp force starts and idles fine,after it
if u have a seperate onboard tank i bet its the vent valve is closed
Feb 21, 2010 | Raymarine Linear Feedback Unit For...
PB620 Echo Blower will not stay running
check and see if the muffler is plugged and it can't get rid if it's exhaust.
Aug 07, 2009 | Garden
Stihl leaf blower motor dies when i try to give it full throttle
If the low and high speed screw are adjustable give them a try. Start with one turn on the low and two turns on the high speed. If these screws are fixed then you will probably have to put a carburetor kit in the carb. I hope this has been of some help. Donnyb60
Mar 18, 2009 | Garden
Garden Logo
112 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
