Question about Ricoh CL4000DN Laser Printer
The images have colored lines through it after one color copy the image seems to "stick" and is not complete as though it is sticking to something inside resulting in a partial image on the page. Is the the fuser unit, or ??
  • Ricoh Master
  • 19,396 Answers
Hi.
If it has colored lines, then it is not the fuser, or at least, if it is the fuser, this is not the only fault.The fuser function is to warm up toner, this will not cause colored lines on document.
The first thing you have to do when you get toner streaks, is replacing toners and cleaning the inside of the machine.
If that does not fix it , then call support.
Here how to clean a printer, instructions are for B&W, but main steps are the same: Clean your laser printer safely with these tips
Regards.
Posted on Nov 14, 2009
Rioch spc320dn Maintenance Kit #406794 It say replace the imager? What is the imager?
In a laser printer the 'Imager' is probably the same thing as the 'Image transfer drum' - this cylindrical unit has the Image of the page to be printed electrostatically set by the laser - this electrostatic image is then transferred onto the sheet of paper and electrically charged toner sticks to the page to form the image - the fuser then heats the paper and toner to fix the image and stop it smudging - The Image Transfer Drum will only be able to carry out this function a certain number of times and will need to be periodically replaced - in a business setting this could be within 1 - 2 years, in a home user setting it could last much longer - It depends on the volume of pages printed during the printer's working life
Feb 17, 2015 | Ricoh Aficio SP-C320DN - 26 PPM Color...
Poor color printing
It means that the printer is not spraying properly all colors.
If the bar are regular, that means that the printhead is blocking the spry at regular times intervals.
Sometimes this problems is related to the printhead.
You find out if it is a faulty printhead by removing it, leaving in in isopropyl alcohol overnight or replacing it.
If printhead is fine then it is a problem with the control board.
Sep 14, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
Docucolor 12
check scanner unit which hit the opc drum, may be hide by something
Dec 27, 2013 | Xerox DocuColor 12 Color Copier
How do I change from internal memory to external memory on my camera?
You can copy all the images from the Internal Memory to a Memory Stick Duo media using the COPY option in the Memory Stick Tool Menu option.
Please insert the Memory Stick Duo media with sufficient free capacity into the Camera.
Select MENU--> Settings-->Memory Stick Tool-->COPY-->OK.
The original images in the Internal memory retain after copying. You may have to delete the contents of the internal Memory. Remove the Memory Stick media after copying, then format the internal memory. FORMAT in Internal Memory Tool.
You can only copy the images to the new folder created on the Memory Stick Duo which is created automatically. You cannot copy the images to a specific folder.
Thanks for using FixYa.
May 09, 2011 | Sony Cyber-shot W290 Digital Camera
Broken screen
What do you mean by impressions? Are you talking about ghost images from image sticking?
Jun 05, 2010 | Olevia LT23HVX 23 in. LCD Television
Having problems with color, i have to print 5 copies to get a good copy, as the color just runs down page
Just solved the same problem. Mine was the fuser. It is either the drums or the fuser. Print something with color then turn machine off before it hits the fuser. If toner does not show up running before it hits the fuser. Then you fuser is bad~$100.00. If the toner runs before it hits the fuser then the drums are the culprit. If the fuser is bad, it will not heat the toner enough for it to stick to the paper then the unfused toner gets on the roller of the fuser and repeats the image or part of it in equal increments down the page.
Feb 19, 2010 | OKI C5100 Laser Printer
Ghost lines horizontally (looks dirty) when making multiple copie
Check the cleaning blade of the OPC drum,the image transfer unit.
Aug 17, 2009 | Canon Office Equipment & Supplies
All copies and scanner outputs result in a totally black image
hi,
its could be hardware issue, if you tell me which printer, then we can try some reset on that machine..........
Regards,  raj_p5983
Jan 23, 2009 | HP PhotoSmart C4180 All-in-One Color...
Dark line when trying to make original copies.
The type of printer you have reads the image you want to copy by passing the paper in front of a image reader (it is like a wand with a light-slit on a side).
If someone passed in front of this reader a paper with something like dirt on it (or typing corrector not dry enough) some of that could stick ON the light-slit, so that the section covered with it cannot read any more the image you want to copy at that point!
Try to make a copy and look from above or aside where that light-wand is located, then try to clean it with a clean hanky. It could involve some technikal skills, maybe you have to loose some screws to get to it.
If dirt stick on it after this, try with some alcohol (no solvent please!). After cleaning the reader, copies should come out ok, please let me know.
Rate the solution please! Thx
Jan 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
Ricoh CL4000DN Laser Printer Logo
41 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
