Question about Curtis-Mathis CM27101S TV
Curtis mathis tv
It went off,as if you turned it off .it was humid ,when i tried to turn it back on all i hear is a ticking sound,please help me. thank you
  • trifle Jan 08, 2008
    thank you so much.......a place to start...i appeciate that...
  • 233 Answers
The Fly-back transformer is bad, it's arcing "ticking sound" it needs repair get estimate first because it might not be worth repairing depending on the cost of the transformer and labor
Hope this helps
thanks for the rating
Posted on Jan 08, 2008
6ya staff
SOURCE:
I can't access the advanced settings on my Curtis-Mathis TV
is it possible to connect my toshiba regza rv75 tv to the internet
Dec 15, 2013 | Curtis-Mathis CM19011 TV
I have a universal remote control that I want to use with my Curtis Mathis TV. What code do I need to use to make the remote compatible with the TV?
Hello
Thee digit universal remote code for Curtis Mathis are:-
000/ 001/ 004/ 009/ 015/ 031/ 049/ 105/ 109
Four digit universal remote codes for Curtis Mathis are:-
0031 0105 0130
0004 0009 0000 0049
0109 0358 0001 0015
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jan 10, 2011 | Curtis-Mathis CM25011 25" TV
Nedd to reset TV manually...... remote is not working
I have a curtis Mathis model number cm19102 . I have no remote. It is stuck on no more than 14 channels. Then the word line comes up on blank screen. How can I get it to get more channels
Jul 17, 2010 | Curtis-Mathis CM27101S TV
No sound
Check on the manual control on the tv itself Vol + - buttons see if functions normallyTry website like Remotes.com to buy a remote same as an exact original remote.
Jul 16, 2010 | Curtis-Mathis CM27101S TV
Philips universal remote needs code for Curtis Mathis Tronics TV
Try these
Curtis Mathes
0047 0466
0016 0054
0060 0093
0145 0030
0154 0451
0166
Please rate my help++++Thanks for using FIXYA
Jun 09, 2010 | Curtis-Mathis CM19011 TV
Curtis mathis tv turn tv on some times turns on just fine some times just sound no picture
open the enclosure of your tv..using a soldering iron resolder the CRT board.A CRT board is a small board attache to picture tube resolder all the components there..good luck!
please rate my help tnx.
Jun 04, 2010 | Televison & Video
19 inch curtis mathis tv
This is the closed captioning, even though it may not contain writing in the block. If you can access the main menu then you can try and turn the CC to off. Otherwise you are stuck with it.
Please rate this answer if it helped.
Feb 12, 2009 | Curtis-Mathis CM19011 TV
TV has sound, but no Picture
Does your sound go thru the tv or a sound system ??? when ya turn tv off then on does it show anything like its coming on ??
Nov 16, 2008 | Curtis-Mathis CM19011 TV
GP4100 A102 Curtis Mathis TV
I don't know this set in particular. Try pressing a channel number on the remote and see if it takes back to the tuner.
Jerry G.
Apr 16, 2008 | Televison & Video
Curtis mathis universal control code for 13 in tv cm13102
We also bought a universal remote to program a Curtis Mathis TV. We found the code by using the code search method. It works everything but the channel program feature. Does anyone know how to access that? BTW the remote is a GE 24921. Thanks
Mar 09, 2008 | Curtis CM13102 13" TV
Curtis-Mathis CM27101S TV Logo
95 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Vitally Alcher
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
