Question about Samsung HL-S4266W 42" HDTV
Says check fan #2 on the screen when turned on and then after a few min the TV shuts down. would like to fix myself if possible. I do not have a service manual
    Genius:
  • Samsung Master
  • 1,667 Answers
One of the fans most likely has failed, or there are some parts overheating on one of the boards in the area of fan #2, or there is a fan velocity sensor fault.
If you open the back of the set, you can turn it on and watch to see what fan is not spinning. If all the fans are spinning then it is a board fault. If you see one fan that is not spinning, you can probably try to order one from the manufacture. When you replace the fan, and if it still does not spin, then there is a fan servo driver fault on the board that drives the fans.
In many of these sets, the fans are uPC controlled via servo drive amplifier circuits. The fan velocity is temperature controlled, something like what is used in many of the PC computers. If this board is at fault, it is best to replace it.
As for replacing boards, this can become trial and error to find the failed board. The authorized service shop will try the boards one-by-one until they find the board that is causing the fault. They will then be able to leave the new board in the set.
Very little component level service is supported for these boards. They are very sophisticated and very involved to troubleshoot. The service reps will replace boards to fix faults.
Jerry G.
Posted on Nov 14, 2009
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
Rca projection tv wont stay on but about 1 min then powers off and wont turn back on for about ten minutes then shuts off again after a min or so
Possibility Fan Cooler Issue Check at the back if your hear the fan going if not your fan cooler is burn out .... The Thermistor will shut off the TV automaticly to the unit for Over Heat
Sep 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
PSP will only power on about 10% of the time...
Just send it into to sony or buy another one sorry bud......
Oct 07, 2009 | Sony PlayStation Portable (PSP) Console
Tv goes off once i turn power on.
I had the same problem with mine. One of the two fans were out on mine. I replaced the $9.00 fan, no problems after that. I fixed it myself after taking it to a Toshiba authorized repair facility, they said it was junk, can't get parts. They said buy a LCD. They never even took the back off of the set. Forty bucks down the drain for nothing. Nine dollar fan was all it was.
Nov 13, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
50 inch samsung flat screen television
fan # 2 is having problems; maybe missing voltage or broken fan
good luck
Sep 10, 2008 | Samsung TXM3297HF 32" TV
Screen gets distorted
Mine is doing something very similar now.  I managed to do the Apple Hardware test and it came up with the Error Code 2 FAN/5/7:  Hard Drive.  This leads me to believe that the problem is the fan by the hard drive.  Your problem may be the same thing.  If so, it's just a matter of finding the part and the installation instructions (on the Apple web site).
Try the Apple Hardware Test from the Mac Os Software that came with the computer.  You install Disc 3 and shut down the computer.  Then turn it on and right away press C on your computer. This action will take you to the Hardware test.  Press one of the buttons that does the test and see what results you get.
If you get the same error code you might want to check out welovemacs.com for the fan.
May 11, 2008 | Apple iMac G5 Desktop
Sony Bravia KDL 52 keeps turning itself OFF
i had prob where my sony would switch off for a few secs thenh come back on . The solution was in menu / tv settings / sleep timer . Go into that and make sure its set to off. there are opions for off , 5 min 20 min 30 min etc... mine was set to nothing just blank.
Apr 06, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Lcd tv shuts down by its self
All you need to do is remove the back cover, then remove the metal cover that covered the power supply. Watch tv w/o cover, it won't shut down again. Try it and post here if it works.
Sep 12, 2007 | Televison & Video
Blue screen of death
What you Have Is a Main RCA Failure you Have a Cathode to Grid Short In your Picture Tube,The Tube shorts and Tells the Miainboard to shut Down...Good Luck
Jul 13, 2007 | RCA TruFlat 27F520T 27" TV
Samsung HL-S4266W 42" HDTV Logo
404 people viewed this question
Henry  Thomas
Henry Thomas
