Question about Iwill ZMAX-AP Barebone
Power up problem
IWILL ZMAX-AP, usb ports at the front light up on connecting power, press the start button, there is a brief flicker of life then nothing, hold the start button in and the brief flicker of life just repeats. Removed everything (apart from CPU) does this mean the motherboard has a fault?
Hi there, just my 2 cents w., maybe its due to PSU, the power does not start completely when you have problems wit the PSU, just check this out, could the solution to your problem...Good Luck!
Posted on Jan 26, 2008
  • 46 Answers
Power supply issue. replace power supply
Posted on Jan 23, 2008
My controllers wont sync to the ps3 or charge on it but they charge when i plug them into the PC. i had the "Maximum power reached" message thing plop up then my ps3 crashed and now they dont...
yea i have noticed my ps3 isn't charging stuff either it only does charge when its turned on im pretty sure theres a setting to charge while the ps3 is off To sync:
  • Connect the USB cable (provided with the controller) into the data USB port on the top of the controller. Insert the other end of the controller into one of the two USB ports on the front of the system.
  • Power on the television and the Sony PlayStation 3. You are going to see a series of lights flicker on the top of the wireless controller.
  • Press the PS3 button in the middle of the controller. This tells the gaming system it is connected. A single light appears on the controller.
  • Remove the gaming controller from the PS3. You can now use it wireless. It is also possible to remove the USB cable from the PlayStation if it is blocking your field of view.
  • Jan 15, 2011 | Video Game Consoles & Games
    Dell xps m1710 no power, no codes flash.
    If you were getting the error message that the computer was overheating, you were lucky that it kept on going still . I would suggest to get the chassis fan replaced and then check.Most likely the chassis fan has died leading to the computer not starting .The extended overheating might even have caused a motherboard failure. As the AC adapter and power button light flickers
    Thanks for using Fixya
    proton
    Apr 26, 2010 | Computers & Internet
    Tower wont work but usb ports still work
    ummm mabey your monitor is bad...do the num lock key or the caps lock keys light up...mabey you need a new video card..numors things can cause this delema
    Nov 15, 2009 | Computers & Internet
    My system fan speed reads 0 rpm and the computer powers down
    Check to see if your fan is plugged in correctly.
    If it is and still doesn't work, try plugging the fan into another fan port.
    If it still doesn't work, your fan is probably busted.
    Oct 13, 2009 | Iwill ZMAX-AP Barebone
    Ps3 will not reconize intec in any way wireed or wireless. just invisible
    CONNECTION A:
    DO NOT INSERT BATTERIES INTO THE CONTROLLER; THE USB CABLE USED WILL SUPPLY THE POWER TO THE CONTROLLER.
    STEPS # 1 – TURN THE POWER ON TO THE PS3 CONSOLE.
    STEP # 2 – CONNECT THE USB CABLE TO YOUR PS3 CONSOLE AND CONTROLLER.
    STEP # 3 – NEXT PRESSE THE SYNC BUTTON ON THE CONTROLLER, THE CONTROLLERS LED INDICATOR’S LOCATED ON THE FRONT OF THE CONTROLLER WILL START TO FLASH RAPIDLY.
    STEP # 4 – CONNECT THE USB RECEIVER TO THE USB PORT ON THE PS3 CONSOLE.
    STEP # 5 – WHEN THW CONTROLLERS LED INDICATOR’S LOACTED ON THE FRONT OF THE CONTROLLER START FLASHING SLOW PRESS THE HOME BUTTON.
    WHEN THE CONTROLLER HAS ESTABLISHED A CONNECTION BETWEEN THE CONTROLLER AND THE USB RECEIVER ONE OF THE CONTROLLER’S LED INDICATOR’S WILL BECOME SOLID RED.
    Jul 12, 2009 | Intec PlayStation 3 Turbo Shock III...
    Controller will not connect to game
    To connect a controller to Xbox 360 console:
    Wired Controller:
    1) Simply plug in the controller into one of the three USB ports avaiable on the system. Two of which are on the front of the console( next to the power button, there is a small door, it is marked by two dots on top, open it and you will find the two USB ports, the third USB port is on the back of the system)
    Wireless Controller:
    1)Press and hold the Xbox guide button until the controller turns on.
    2) Make sure that the console is on, then press and release the connect button on the console( the button next to the memory card slots)
    3) Press and release the connect button on the Xbox wireless controller, if connected the ring of lights on the controller will stop blinking, one of which will now be constantly lit, The same will occur on the ring of lights on the console itself
    Mar 16, 2009 | Microsoft Xbox 360 Console
    Western Digital Passport 160 GB external HD won't load.
    WinXP SP2 blocks the use of the drive because it thinks it draws too much power. But there is a simple procedure to override this (from WD site):
    "Problem:
    Under Windows XP, an error message of "Power Surge on Hub Port" or "USB device has exceeded the power limits of it's hub port" is displayed when connecting a USB device to a USB port on a computer or Hub.
    Cause:
    Under some computers, USB devices are only allowed to draw a maximum of 500 milliamps (mA) per connection from the USB port on the computer system or from a USB hub. Under the Windows XP Operating System, with the release of Service Pack 2, if a device attempts to draw more than this (500 milliamps), a USB port balloon message is displayed to indicate this over current condition. When connecting a USB device that draws power from the USB bus, a very brief over current condition is sometimes detected by the OS, and the warning message is displayed.
    Resolution:
    This message has no affect on the functionality of the USB port. The USB hard drive should still function correctly on the USB port regardless of the error message. To prevent the USB Power Surge Alert message from displaying, please complete the following steps:
    Click on Start.
    Click on Control Panel.
    Double-click on the System Icon.
    Click on the Hardware Tab.
    Click on the Device Manager button.
    Click on the + next to Universal Serial Bus Controllers to expand the selection.
    Right-click and select Properties on any listing that displays USB UNIVERSAL HOST CONTROLLER.
    Click on the Advanced Tab.
    Check the box that says: Don't tell me about USB errors."
    This works fine, and the drive works fine afterwards. I suspect it actually draws less power than they say. Maybe it has a brief power draw spike on startup, but it's running power seems less. In any case, it works fine without the Y cable. I do think it is tacky that WD doesn't give the cable for free, since my $7 Sabrent 2.5" Hard drive enclosure came with a y cable.
    But most likely the drive will work fine for you. It is a lovely quiet drive, and takes up no space at all.
    Feb 01, 2009 | Western Digital Passport 160GB External...
    D-Link DI-534 Starting up problems
    Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
    try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
    Jan 08, 2009 | D-Link AirPlus DI-524 Wireless Router
    Computer wont turn on
    "Then I came across the recommendation to check the USB ports for damage. Saw some of the pins bent inside the port. Once I fixed them, the computer powered back on as normal! Small fix for big problem. Cheers - Parveen"
    My wife's Dell E510 also suffered from the orange blinking light on front, and would not power up this morning. I had just purchased a new power supply for another computer and swapped it with the Dell's. To no avail... Put the Dell back together and still no luck with a start. So I came across your site and remembered that recently the 6y'o had jammed a USB port in the front of the Dell and after bending that USB port back into shape every thing works again!
    Who would have thought that a free fix would be so easy!
    Thanks!!!
    Feb 09, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
    Iwill ZMAX-AP Barebone Logo
    106 people viewed this question
    Top Iwill Computers & Internet Experts
    Alun Cox
    David
    David
    Nathaniel Berrios
    Nathaniel Berrios
    Are you an Iwill Computer and Internet Expert? Answer questions, earn points and help others
