Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
My HooverDeluxe Elite Rewind became extra loud
My HooverDeluxe Elite Rewind became extra loud and the vacuum is vibrating so badly it is shaking my arm. The brush is spinning and the filter looks good. There are no clogs. Help!
  • 701 Answers
If the belt is really worn it can cause that. I wold try changing the belt if you haven't recently. Here are the belts you need:
Hoover Elite Rewind Belts
Posted on Nov 14, 2009
I purchased a eureka airspeed unlimited rEwing and it is soo loud..is it supposed to be?
That depends, is it just loud or is it loud from a vibrating noise? Does the machine shake? If not, then the machine is just loud unfortunately.
Feb 26, 2016 | Eureka Vacuums
How do I make the noise stop?
Seems like the bearing on the side of the roller has gone bad. If there is a dirt gone deep inside, it is hard to clean it. It can also go bad if the roller hits the uneven surface like the transition strip between carpet and tile. It can unbalance the roller causing it to go off its axis and get misaligned.
This is the roller for the Hoover Elite Rewind
http://www.ezvacuum.com/hoover-93002124-brushroll-for-u5509-u5511-u5512-elite-rewind-p-3607.html
May 20, 2013 | Hoover Elite Rewind Bagless Upright...
Very loud "jet like" noise,please
Vacuums are noisy, but shouldn't sound like a jet.....
Trying to find out what is wrong depends on what kind of noise it makes, i.e. high squeal, vibration, whining and where it comes from.
Here is a webpage with troubleshooting advice on noise in vacuum cleaners. Hopefully you should be able to track down the problem. http://www.ehow.com/how_7493926_fix-noise-vacuum-cleaner-motor.html
If you need further help with repairs, please reply back. Thanks,
Handie Andie
May 09, 2011 | Dirt Devil Reaction Twin Cyclone Upright...
Vacuum shaking badly right up to handle and very loud noise
Could be a broker motor retainer. There should be two motor retainers in this model, when one is borken, it causes the unit to
shake and vibrate.
May 13, 2010 | Hoover U5507900 Elite Rewind Bagless...
My deluxe elite rewind vacuum spits out dirt
The elite rewind does not have any fancy features. This sound like you have a blockage in the foot or base of the vac. remove the bottom cover to look under. Also check the hose, it can be in there as well.
Apr 16, 2010 | Vacuums
My vac is really loud now is that the belt??
Sounds like the brush roller is worn and making noise, take the complete vac to the repair shop for service. I've seen this cause damage to the front nozzle housing as well.
Oct 13, 2009 | Hoover Elite Rewind Bagless Upright Vacuum...
How do I clean the lifetime hepa filter
Check with the manufacturer. I have always had good response from Hoover.
Sep 23, 2009 | Hoover U5507900 Elite Rewind Bagless...
Hoover Elite Rewind
Something's rubbing. It is probably the beater bar rubbing against the base plate. Remove the base plate and check that your beater bar is back in the sockets of the vacuum frame correctly. If they get installed a bit off, it'll make a LOT of racket. Check it out!
Best regards, --W/D--
Aug 05, 2009 | Hoover Elite U5061-900 Bagged Upright...
Hoover Deluxe Elite Rewind does not pick up
Check the hose and take the bottom plate of the vacuum off to check for obstructions that you can't see right away. Use a wire coathanger (unwound) to push any clog through. I also have dogs and this vacuum. It does get clogged with fur occaisionally.
Apr 08, 2009 | Vacuums
My hoover elite rewind stopped running in the middle of vacuuming. Is it dead forever?
Cord may have gone bad, if so you will have to replace the cord rewind. Could be a problem with the switch, maybe the motor. Just have to have it checked out.
May 14, 2008 | Hoover Vacuums
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
446 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
