Question about LG Washing Machines
Started washing 2 pairs of sneakers in the machine and then after awhile it just starts making a broken gear sound and the drum doesnt spin. it seems to start at first then it starts making noise and does not spin. I have to drain the water to get it to open and it will never finish the cycle. it stays on the time left no matter how long I wait. Wondering if has anything to do with the shoes or just a coincidence.
  • 2 more comments
  • zulova Nov 14, 2009
    if i start the cycle again it will start spinning then it will stop and grind again without it spinning. I did not take the laces off but they were short.
    the washer is a front laoder LG wm2277
    that's exactly what I hear is crunching sounds
    i have full warranty on the washer and one is coming out, I just wanted to know if I was able to fix it now instead of waiting, Thanks
  • LG Master
  • 4,806 Answers
If you can hear the motor going but the drum is not spinning then there is a possibility that the belt has snapped or has come off the fly wheel.
There is also the possibility that the sneakers have caused this.
Did you take the laces out of the sneakers?
Posted on Nov 14, 2009
  • 1 more comment
  • Lee Hodgson
    Lee Hodgson Nov 14, 2009
    From the sound that you are describing i am in no doubt that the bearings have gone.
    If its the front bearings then you will notice that the drum will have dropped a little at the front.
    If its the back bearings then you will hear crunching noises. Either way the balancing of the drum is interrupted so the cycle will stop.
    Some washing machines will complete a wash cycle but won't spin off because of the balancing sensor.
    I recommend that you have an engineer take a look at the machine.
    The bearings are not that expensive to replace but you need a special wrench to unscrew the bolt from the fly wheel, this why you may need an engineer to replace them for you.
    Regards.
  • Lee Hodgson
    Yes,
    The crunching sounds you are hearing are the smashed bearings grinding against the bearing ring.
    I think you are going to have to call an engineer.
  • Lee Hodgson
    It's highly unlikely that you are going to be able to fix the problem yourself unless you had the correct wrench for the job.
    Not only that some machines have to be completely disassembled so the drum itself can be extracted from the top of the machine to get to the fly wheel and the holding bolt.
    I don't recommend that you try fixing the problem yourself as you may void the warranty costing you a small fortune.
    I suggest you wait for the engineer to come and repair the problem for you. That way if there are any underlying problems that have not surfaced yet the engineer will be able to repair that/them too.
    Regards.
My Bosch washing machine won't turn the bowl
Hi Justene,
i Think its control circuit has a problem.
or the fuse for motor drive circuit is damaged.
please check with electrician.
regards.
nuwan
Jan 13, 2014 | Bosch Washing Machines
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Frigidaire front load washer model GLTF1240ASO makes a loud noise durring spin cycle
Most likely the drum bearings are gone, especially if you have some play. You need a bearing and seal kit which is fairly inexpensive but it is a pretty big job. The entire inner drum must come out so it requires the disassembly of quite a bit of the machine.
Jul 09, 2013 | Washing Machines
My washer will start but it will just make a winding sound
Sounds like the motor to drum belt or gear is broken. The motion generated by the motor is not getting to the drum because the belt is slipping or broken, or the gears are stripped causing the winding sound.
Sep 26, 2010 | Kenmore HE2 Plus Front Load Washer
Washing machine - terrible noise during spin cycle
sounds like the drum is rubbing on some part of an exterior wall of your washer,.or you have a bearing going, or worst case scenario you have transmission problems and need to get a serviceman in to check your machine.But firstI would call the manfacturer and explain the problem they may be able to resolve it over the phone give them model no. Make and year of manfacture they hopefully can help you with this
Jan 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Banging during the wash and spin cycle
sounds like drum is out of balanced call repairman they can rebalance drum this needs to be done ,once a year.
Dec 16, 2009 | Frigidaire GLTF530DS Front Load Washer
Whirlpool Model LSR8233EZ1
Transmission gearing failed or coupling.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 11, 2009 | Washing Machines
Sounds like a loose screw/bolt/nut during the spin cycle
There is nothing wrong with your machine. Don'f bother with the sound , You said you threw 2 pair of jeans, so its bottons are causing the sound against the drum during cycle. Finished your laundry and worry no more. To make sure, throw some another clothing asides form jeans, like shirts, and feel the normal silent of your machine.
Good Luck,
Eriez
Jun 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Broken kenmore washer
I have a Kenmore style master model #4217013 but it stopped spinning last night. Please let me know what to do.
Mar 27, 2008 | Washing Machines
Washing Machines Logo
35 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
