Question about Acer Aspire One PC Notebook
Acer aspire one battery light flashes orange. When booting after a few seconds it shutsdown. Now all lights stay off. Can this acer netbook work without batery ? It doesn't seem to charge the batery
    Problem Solver:
  • 5 Answers
Finally I got it working again, after a lot of try's (just put the plug in for a few hours) the led was red again for a brief moment, then it starting to flash orange again.
I looked it up on a lot of forums, the problem is that the (old) bios doesn't charge the batery anymore when it is deeply discharged.
So I put the plug in and out for about 10-15 times , and the brief moment it is not flashing it's still charging. Until it is not deeply discharged anymore and then it is charging the batery like it did before.
But I still don't understand why it is not working without the batery inserted ??
Posted on Nov 22, 2009
SOURCE:
How to fix acer d255e blank screen
If ur OS dont boot u must chenge ur windows
If ur windows is boot u can install driver for vga output
Oct 31, 2017 | Acer Aspire One D255E13438 Netbook
Acer Aspire One NAV50 screen blank
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Oct 07, 2012 | Acer Aspire One Netbook
Acer aspire netbook wont turn on flashing white light on power button
Did you try to flash a new BIOS? If so, you might be in trouble and
need probably to reflash the new BIOS. (Look at Acer site for info).
But anyway try:
1. Push and hold the Power On switch for 4-6 seconds.
Try to Power On again.
2. If this does not work, do a Power Reset:
- Disconnect powersupply cable and pull out the battery.
- Hold the Power button for 60 seconds a few times.
- Place the battery and powercupply cable.
- Try to Power On.
Aug 04, 2011 | Acer Computers & Internet
Only a black screen, no indicator lights are nurning
I am using an Acer and it happened to me thrice. It is an easy fix.
Acer Aspire One BIOS Recovery The Acer Aspire One has a built-in BIOS recovery routine, which can boot into a minimal BIOS environment via a special boot block to re-flash the BIOS, even if the system does not pass POST and does otherwise not boot anymore. This procedure is also known as Crisis Disk.
First format an USB flash drive with FAT. It does not need to be bootable.
Download the latest BIOS, and extract all files. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the flash drive. The files must not be in a folder. Rename the BIOS file to ZG5IA32.FD before proceeding. It only works with this exact filename.
Turn the AA1 off, and verify both battery and AC adapter are plugged in.
Press Fn and Esc simultaneously, keep them pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press it once. The AA1 will now access the files on the flash drive and initiate flashing the BIOS. After a while the power button stops blinking, and the AA1 reboots by itself. Wait patiently.
If it doesn't reboot, but keeps blinking, wait at least a few minutes before turning it off, and try again. Good Luck
Jan 24, 2011 | Acer Aspire One PC Notebook
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
Flashing orange and yellow lights
Most likely your battery is dead.
If you are worried about your HD , the best thing to do would be to power it off.
Remove the battery and see if it will boot on the AC adapter.
If it boots , just get a new battery.
If not you have a motherboard issue and need to call Acer if it is under warranty.
Apr 22, 2009 | Acer Aspire 5003WLMi Notebook
My acer one netbook won't boot
This is a common problem with the Acer Aspire one. Apparently, the BIOS needs to be flashed using a flash disk with the required files.
Unfortunately, the files are not available at any website but you can take the Aspire one to any Acer service center and they should be able to flash the BIOS for you free of cost.
Mar 16, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One 6 Cell Battery Problem
you got a bad battery. If your old battery works fine, and the new one wont hold a charge, Take it back to the store and get another.
Dec 29, 2008 | Acer Aspire One AOA110-1626 Notebook
Flashing amber light
Attempt to boot the laptop with the battery removed and the AC plugged in. IF this boots ok it may very well be the battery circuitry which has failed.
Nov 26, 2008 | Acer Aspire 5315 Notebook
Acer Aspire One  PC Notebook Logo
4,317 people viewed this question
Ekse
Alun Cox
