Question about GE JVM1650 1000 Watts Microwave Oven
GE over the range Microwave shutting off
Our 2 yr. old GE microwave, Mod#JVM1650WH01 has a problem. It will run for about 2 seconds, then shut off and we have to reset clock, date, etc. Sometimes that works, sometimes I'd like to throw a hammer through it! This happened a few times right after we got it, and then it worked okay for about 1 1/2 years. Now it's doing it again, only this time it's very hard to recover! I think this product is defective and hope that GE will stand behind it.
  • 2 more comments
  • reddew3 Feb 25, 2008
    I also have a GE over-the-range microwave that shuts off after 2 seconds running, then I have to reset everything. Model # JVM1650CH02 4/05. I can not use it, but I have to leave it plugged in to use the fan and light. Why? I thought GE made quality appliances. This is the first step I'm taking to resolve this problem. I can not afford another one. Please Help!. Thank you. Debbie
  • Anonymous Mar 28, 2008
    MY GE JVM 1653BH01 has the same problem. require reset clock over & over again.
  • Anonymous Sep 26, 2008
    I had the exact same problem (and exact same model) In another post, someone mentioned the oven works fine if the front panel is tilted forward. The suggestion was to use one of those anti static bags behind the control panel. The bag blocks interference from the magnetron.Note you don't have to take down the oven to try tilting the front panel or to insert the bag.
  • ceraynor Dec 10, 2008
    I have the same problem same model is only 2yrs old and I called GE they want 79.95 just to come out and look at it and if we decide to fix it they will put the amount on the bill. It is apparent they have a problem with this and don,t want to take the responsibility for the problem. So goes the american company. It will be the last time I buy a GE
  • GE Master
  • 9,098 Answers
This is often due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown in the photo here:
http://207.234.249.73/mwd/wb27x10489_ge_mag_stir_kit.jpg
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
You say this is only 2 years old? I thought these models were much older... GE may cover it, but you'll have to contact them.
GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
I had the same problem in my 2005 JVM1650BH01 (balck). The solution posted by Guest (Sep 26, 2008) worked for me. Protecting the control panel via static bag. You can open the control panel by remving the grill at the top.
Posted on Dec 12, 2008
Don't buy any GE products, I also have the same problem. Less then two years old already had the Megatron replaced after 6 months
Posted on Sep 10, 2008
Ge over range microwave jvm6172sf1ss.....shut off while using, not any power. circuit breaker checked and is ok
Usually they are economically repairable. Best bet is a new one. the price of new is about 2 hours labor and you still have an old unit.
Feb 24, 2018 | GE Microwave Ovens
My ge microwave model # jeb1095sb03 shuts off after 1-2 seconds
Hi Bruce,
i think power supply problem,maybe loose contact of jumper wires or loose connections of PCB.
go for repair center,
regards,
nuwan
Jan 12, 2014 | GE Microwave Ovens
I have GE Profile microwave model PVM1870SM1SS and last week while running, suddently it shut off. There is no power, display buttons and stopped running. Please advise.
From the description a major part has failed, the magnetron is suspect because it suddenly shut down in cycle, if the unit is less than 7 years old it probably has a inverter board and tends to fail, also there is the possibility the keypad control board has stopped working. The microwave in my opinion is worth getting checked out and repaired, but it will be expensive.
Apr 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
GE microwave (JVM1650wh01) shuts off after running just a few seconds
MOST times this is because of a poor air circulation around the unit, especially those built into cupboards.
Make sure the vents are clear of the back wall and that there is a good airflow. The sensor detects temperature rise in about 20 secs and will turn it off.
If the air vents are OK then I would suspect a fault with the sensor itself. It has possibly shifted away from where it should be positioned( vibration). You may have to remove the outer shell casing and see if its in its cradle.
Please rate my help++++ThaNks for using FIXYA
May 16, 2010 | GE JVM1860 Microwave Oven
Microwave shuts off after running for five minutes
I'd be careful because you do not know what caused it to spark. How old is the microwave? Do you need a new one?
Jun 14, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Microwave shuts off after a few seconds.
I am surprised that the GE seervice tech did not explain to you why the microwave will still cook. By saying that transformer is damaged or shot really means that the internal windings may be shorted together so the transformer no longer has as many good windings to produce the original power it did when it was new. That is pretty clear. It will still function a little but the protection circuits inside the microwave would start to shut it down when it overloads by trying to pull more current than the windings inside the transformer can handle. You can replace the transformer yourself if you are a do it yourselfer and are confident around unplugging the transformer with All Power Off and unscrewing a couple of screws that hold it in place. It is pretty straightforward you just need to find the correct transformer (maybe you can buy one from GE or go to www.mwoparts.com which carry all the parts in microwaves for all models especially name brands like yours. Taking the cover off is of course easy. Good luck. Let me know how you do or if I can help you in any other way.
Jan 26, 2009 | GE JVM1630 Microwave Oven
Microwave stops running after 3-5 seconds
hade same problem upper door switch by past it microwave works
Nov 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650CH01 Microwave Template
You can download GE owner's manuals and installation instructions here.
Aug 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
809 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
